The Visible 'Bot — Parallax Forums
The Visible 'Bot
ajwardajward Posts: 1,130
edited 2013-08-03 01:29 in Robotics
Since I got my stepper motors, I've wanted to use them in something kinda neat (neat to me anyhow). I'm working on a sun following solar panel, but I really like things than move around under their own power. This week I went to Tap Plastics and scored some cool scrap/cutoff pieces. I started assembling Clyde this morning.
The deck is clear 3/16" acrylic sheet. Each main wheel is two discs of 1/8" clear acrylic with about half the thickness milled away around the circumference. Bolted together they make a nice groove for an o-ring tire (If I can find the right size!). The "tail wheel" is a 1" acrylic ball just glued to the bottom of the deck. Of course, it doesn't move but he's just going to be an indoor critter so it doesn't matter too much.
Each stepper mounted with a couple of Parallax L shaped brackets. I got the hubs from eBay in a convenient 5-pack! Setting up a Homework Board to drive everything.
Time for dinner, then back to the lab! ;-)
Amanda
  • WhitWhit Posts: 4,194
    edited 2013-06-29 17:25
    What robot?
    Looks like another great project Amanda!
    edited 2013-06-29 17:57
    Amanda, you are on a roll lately. I will definitely be curious how well those steppers work for you.
    Btw how did you mill the acrylic wheels and find the center? My plywood experiments with a Dremel circle cutting jig haven't turned out as nicely.
  • BrainStrainBrainStrain Posts: 30
    edited 2013-06-29 19:39
    Cutting circles or any other shape can be challenging without the tools that make it easy. If you are successful at cutting circles with a Dremel, even if they are not as nice as you would like, you can clean them up very well on a drill press. Make sure you use a compass to draw the circles so that you know you have good centers marked. Small drill presses don't cost much and you will never regret buying one. You can never get the drilling precision you would like to have if you only have a hand-held drill. I would cut the circles out on my band saw, but whatever you use, after they are cut you can spin them in your drill press and use it kinda like a vertical lathe. You can mount the circles in the drill press with the needed size bolt, nut, and a couple of washers. Then spin the disks and round them off almost to perfect circles with a file. In this case the circles are thin enough that you might be able to spin them all together on the same bolt. If that works they will all be the same size, or close enough when you finish. Then you can use a file again to cut a groove in the edge of each disk for an O-ring. You might want to play around and make a couple of jigs as tool rests to help hold the file. Good luck.
    edited 2013-06-29 20:01
    One more thing. I could not sleep tonight if I failed to mention safety. Power tools are dangerous, even small cute ones. If you are not experienced with power tools, make sure you are aware of the primary hazards they present. Maybe you can find some safety videos on You Tube. For example. You can find circle cutters for drill presses at any hardware store, but they are not really good for large circles. You may find that there is a style of circle cutter with a drill at the center and an adjustable arm that swings at the radius to cut any size circle you would like. Those circle cutters will break your fingers and otherwise mangle your hand before you have time to blink. Oh, and you can't hand hold the piece while you are cutting it. You'll have to clamp it down on two sides. Don't want to scare anyone, but I nicked a couple fingers on a table saw once. It is something you never forget.
    edited 2013-06-29 20:16
    Clear Clyde is clever!
  • GenetixGenetix Posts: 1,777
    edited 2013-06-29 21:56
    Nice looking bot but the name Clyde was the orangutan with Clint Eastwood in the early 80's.
  • ajwardajward Posts: 1,130
    edited 2013-06-30 01:32
    Martin_H wrote: »
    The discs were just some pieces I found in the scrap bin at Tap. Half a dozen of them and I thought if I didn't grab them for something I'd regret it. The edges were already milled so all I needed to do was find the center and drill the mounting holes.
    Finding the center was pretty easy using this gadget. (Thanks to PJ for the tip!!)
    Got it for $4.99 at the local ACE Hardware.
    500 x 500 - 67K
    cf.jpg 66.7K
    edited 2013-06-30 01:48
    Genetix wrote: »
    Nice looking bot but the name Clyde was the orangutan with Clint Eastwood in the early 80's.[/QUOTE
    I'm sure he won't mind me using it! ;-)]
    edited 2013-06-30 11:52
    Also might have been Visible Vic/Vince or Transparent Tran/Travis...
    edited 2013-06-30 11:54
    CLEARLY Clyde needs one of these transparent breadboards: http://www.ebay.com/itm/180758250443?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    edited 2013-06-30 12:05
    I finished up the mechanical stuff with Clyde this morning and went on to wiring up everything.
    Power comes from a 6xAA battery pack under the deck, mounted as far forward as possible to gain traction. Tho' as I feared, the plain wheel doesn't have enough traction to move very effectively. Then I noticed the old tires from Sid... the Scribbler wheels are about .020" bigger than Clyde's wheels. A bit of a struggle getting them to slip on but, they do fit nicely and give him a bit of grip.
    Um... yeah, some cable management is called for here. ;-)
    1024 x 612 - 67K
    1024 x 612 - 61K
    1024 x 612 - 77K
    1024 x 612 - 51K
    edited 2013-06-30 14:08
    Clyde has some really Hot Wheels!!
    (no offense, erco! :smile:)
    I'll have to go hub shopping on ebay.
    EDIT: I didn't realize we were playing name games: Ivan the Invisible
    edited 2013-06-30 14:19
    Looks good! What are those 2 square boards in the back?
    edited 2013-06-30 14:45
    Genetix wrote: »
    That's the front actually. Think BoeBot Layout. Those are the driver boards for the stepper motors. Probably a better way of mounting them, but this is just one of my many projects to occupy way too much free time! :-)
    edited 2013-06-30 16:46
    ajward wrote: »
    Genetix wrote: »
    Heaven forbid you use a Pololu Orangutan controller and voice control for navigation on this bot, in which case you could simply say...?
    Ahem, in which case you could simply say...?
    edited 2013-06-30 17:08
    Amanda: You can lose those two controller boards, just get a ULN2803, which can handle 8 lines. Here's my Boebot on steppers. Trust me, you want to keep the weight balanced over the drive wheels, like almost no weight on the skid. You'll see why in testing.
    Clarence would be a good name too.
    1024 x 768 - 112K
    1024 x 768 - 98K
    edited 2013-06-30 20:35
    ajward wrote: »
    I remember that post of P.J.'s - I will have to go look at my ACE too.
    edited 2013-06-30 21:17
    Cap screws also.
    edited 2013-07-02 10:23
    Amanda: I forgot to mention, I used two 18650 Li-Ion batteries in my steppper Boebot with good results. That's just over 8V fully charged, going straight to the motor driver. A little extra voltage helps these "5V" steppers move faster more reliably. You can see the battery holder in my pics on the rear end of my bot, where it helps take some of the weight off of the ball roller.
    edited 2013-07-02 13:01
    Yup! I'm powering the board with 9 volts (6xAA cells) and the driver boards from Vin. He's working pretty well. I'm starting to figure out some simple navigation... my first square closed only a couple inches off the mark! :-)
    edited 2013-07-02 13:45
    Ah yes... you never forget your first square: http://www.youtube.com/watch?v=hzNgYpJdfDs
    But sadly that trip is a dark, one-way road that leads to shadowy late nights and much harder.... maneuvers.
    Like figure eights! :)http://www.youtube.com/watch?v=9l32qYXJfTg
    edited 2013-07-02 19:09
    The second attempt at a square. The first was off just a bit and the room was too dark. The aiming point is a piece of electrical tape on the sticky note.
    http://www.youtube.com/watch?v=RAzFl2v43FE&feature=youtu.be
    Got straight lines and angles figured out. Now to discover the secret of curves! The joys of exploration!
    Amanda
    edited 2013-07-02 20:04
    Sweet run! Your Bot's a real "square".
    edited 2013-07-02 20:11
    Great job Amanda! Like a pro...
    Thanks for the idea erco. I just got a 10 pack of the ICs from China. ($2.38)
