Scratch built EDDIE
I built this EDDIE totally from scratch. I used a old Dell PC mother board, i scratched built the controller card using a 40 pin propeller chip. i have a 4.5 inch monitor up front, 5 12 volt batteries and i made a charger from the dell power supply.
There were a couple different versions of the Eddie code out there. One for the early position controllers and then a later version for the higher resolution quadrature encoders. Do you have encoders on the main drive wheels and if so what version did you use?
Robert
WOW!
Hello Robert,
I used ST VNH2SP30 30A Motor Driver for the H-Bridges, and replicated all of the other circuits. The encoders are the newer ones from Parallax, and i used the newer software. I want to add an arm to my Eddie soon. My arm is going to be scratched built also.
Danny
Danny
