The WireWorld Computer - Page 3 — Parallax Forums
13567
  • AribaAriba Posts: 2,694
    edited 2013-05-10 19:32
    David Betz wrote: »
    That was it! Thanks!! I wonder why Baggers used a non-standard frequency?
    Because he took the value from Chips driver. Chip seems to have a very forgiving multisync monitor that does not care much about the right frequencies as long as the ratio of the vertical and horizontal timing is correct.
    My monitor is very picky and insits on the right frequencies.
    The problem is that if you use the right pixel-frequency most resolutions show some jitter in the pixels because the PLL makes not a smooth signal. But for 800x600 (40MHz) it seems to work well. This will be better on the real chip.
    Andy
    edited 2013-05-10 19:40
    Ariba wrote: »
    Andy
    This was a problem I always had working with Andre's boards. He always used non-standard timings that worked fine on the CRT monitors he used but almost always gave me trouble. He kept telling me to just us a CRT monitor myself. Unfortunately, I don't have one anymore. Thanks for the alternate timing!
  • pedwardpedward Posts: 1,642
    edited 2013-05-10 19:49
    Chip supplied that frequency. On the P1 the rule with the PLL is to try and use values with as few on bits as possible within the top 5 bits. This is because the counter is cycling on an off and generating sub-frequencies for each 1 bit below the top bit. This creates jitter and sidebands on the outputs. I don't know if the P2 has the same exact restrictions, but Chip picked values that were the next highest modulus fore the dot clocks. The VGA demo uses 30MHz when 25.175Mhz is standard.
    40MHz is sort of the opposite, $1600_0000 is the next "even" iteration bigger than 40MHz and yields 41.25 Mhz. I found that the analog output was more noisy with $1555_5555.
    FWIW:
    $1555_5555 = 1_0101_0101_0101_0101_0101_0101_0101
    $1600_0000 = 1_0110_0000_0000_0000_0000_0000_0000
    $1800_0000 = 1_1000_0000_0000_0000_0000_0000_0000
    edited 2013-05-10 19:56
    pedward wrote: »
    FWIW:
    Hmmm... I guess this means that only some monitors will work with the P1 and maybe also the P2? Or maybe I just have bad luck in choosing monitors and always pick ones that are intolerant of timing deviations. Is there no way to generate accurate timing or must we always rely on monitors not being that picky?
    edited 2013-05-10 20:43
    Thanks to Andy I got my VGA output working and am now able to load the "ww1024x600.bin" (well, really "WW1024~1.BIN") from an SD card. Now I just have to get the actual Wired driver working and I should finally be able to see this demo run. I had some trouble along the way because p2load doesn't know how to patch images before downloading them like propeller-load. Variable patching is how propeller-load tells the program being loaded what pins are used for things like the SD card. I fixed that by adding rather ugly explicit code to mount the SD card in my main program. I either need to add variable patching to p2load or merge the p2load features into propeller-load.
    Here's the ugly code:
    #include <stdio.h>
    #include <stdint.h>
    #include <dirent.h>
    #include <propeller.h>
    #include <sys/sd.h>
    #define LEN_16      0x00000001
    #define LEN_32      0x00000002
    #define LEN_64      0x00000003
    #define LEN_128     0x00000004
    #define LEN_256     0x00000005
    #define LEN_512     0x00000006
    #define LEN_1024    0x00000007
    #define READ        0x00000000
    #define WRITE       0x00000008
    #define MEMORY_SIZE             (16 * 1024 * 1024)
    #define BLOCK_SIZE              64
    #define BLOCK_SIZE_IN_LONGS     (BLOCK_SIZE / sizeof(uint32_t))
    #define ALIGN                   16
    #define FILE_NAME               "WW1024~1.BIN" // "ww1024x600.bin"
    typedef struct {
        volatile uint32_t **p_vbptr;
        volatile uint32_t *p_vidramptr;
        volatile uint32_t *sdram_cmd_entry;
        void *hubram_addr;
    } VGA_PARAMS;
    extern _Driver _SimpleSerialDriver;
    extern _Driver _FileDriver;
    _Driver *_driverlist[] = {
      &_SimpleSerialDriver,
      &_FileDriver,
      NULL
    #define DO   	44
    #define DI      45
    #define CLK     46
    #define CS      47
    int main (int argc,  char* argv[])
        extern char binary_SDRAM_Driver_obj_start[];
        extern char binary_VGA_Driver_obj_start[];
        volatile uint32_t sdram_cmds[5] = { 0, 0, 0, 0, 8 };
        uint8_t buffer[BLOCK_SIZE + ALIGN];
        uint32_t *bufferp = (uint32_t *)(((uint32_t)buffer + ALIGN) & ~(ALIGN - 1));
        uint32_t addr, data, data_start;
        int count, errors, i;
        FILE *fp;
        volatile uint32_t *vbptr;
        volatile uint32_t vidramptr = 0x00000000;
        uint8_t vgawork[4096 + ALIGN];
        uint8_t *vgaworkp = (uint8_t *)(((uint32_t)vgawork + ALIGN) & ~(ALIGN - 1));
        VGA_PARAMS vga_params = { &vbptr, &vidramptr, &sdram_cmds[2], vgaworkp };
        _SD_Params sd_config;
        sd_config.AttachmentType = _SDA_ConfigWords;
        sd_config.pins.ConfigWords.CONFIG1 = (DI<<24) | (DO<<16) | (CLK<<8) | 1;
        sd_config.pins.ConfigWords.CONFIG2 = CS<<24;
        coginit(2, binary_SDRAM_Driver_obj_start, (void *)sdram_cmds);
        coginit(0, binary_VGA_Driver_obj_start, (void *)&vga_params);
        if (dfs_mount(&sd_config) != 0) {
            printf("SD mount failed\n");
            return 1;
        if ((fp = fopen(FILE_NAME, "rb")) == NULL) {
            printf("Open of '%s' failed\n", FILE_NAME);
            return 1;
        addr = 0x00000000;
        while (fread(bufferp, 1, BLOCK_SIZE, fp) == BLOCK_SIZE) {
            sdram_cmds[1] = addr;
            sdram_cmds[0] = (uint32_t)bufferp | LEN_64 | WRITE;
            while (sdram_cmds[0])
            addr += BLOCK_SIZE;
        fclose(fp);
        for (;;)
        return 0;
    edited 2013-05-10 21:36
    Merge, don't re-invent. I knew this was the point at which you would reach the precipice.
    edited 2013-05-10 21:39
    pedward wrote: »
    Yeah but I kind of like p2load better. It's a lot simpler. Unfortunately, propeller-load has grown into kind of a monster. It tries to do too many things I think.
    edited 2013-05-10 21:42
    I converted the Wired driver itself but it doesn't seem to work. Maybe Baggers will take a look at it to see if he can spot what I did wrong. All I tried to do was pass all of the parameters into the driver using ptra rather than having them hard coded. I'm sure I messed something up in the process though.
    Wired_Driver.spin
    Here is the ugly C code that launches this driver. I'll try to clean it up and add some comments tomorrow.
    #include <stdio.h>
    #include <stdint.h>
    #include <dirent.h>
    #include <sys/sd.h>
    #define ALIGN                   16
    #define FRAME_SIZE              (1024 * 600)
    typedef struct {
        void *hubram_addr;
    } VGA_PARAMS;
    typedef struct {
        void *workram;
        uint32_t sdram_frame0;
        uint32_t sdram_frame1;
    } WIRED_PARAMS;
      &_FileDriver,
      NULL
    #define DO   	44
    #define DI      45
    #define CLK     46
    #define CS      47
    void LoadSDDriver(uint32_t configwords[]);
        extern char binary_Wired_Driver_obj_start[];
        FILE *fp;
        uint8_t workram[4*1024 + ALIGN];
        uint8_t *workramp = (uint8_t *)(((uint32_t)workram + ALIGN) & ~(ALIGN - 1));
        WIRED_PARAMS wired_params = { &vbptr, &vidramptr, &sdram_cmds[0], workramp, 0, FRAME_SIZE };
            return 1;
            return 1;
        addr = 0x00000000;
            addr += BLOCK_SIZE;
        fclose(fp);
        coginit(cogid(), binary_Wired_Driver_obj_start, (void *)&wired_params);
        return 0;
    edited 2013-05-10 22:20
    David Betz wrote: »
    Ahh, well then that is what spawn forks and competing projects!
    Can it be broken apart into separate shared object libraries so the useful stuff can be reused in p2load?
    edited 2013-05-10 22:23
    pedward wrote: »
    Probably. Some of it is fairly clean but some of it is pretty crufty. It would take some work to split it apart. One thing I'd kind of like to remove is SD card writing. I think it would be better to have a separate program that could read/write SD cards over the serial interface to the Propeller.
    edited 2013-05-10 22:31
    David Betz wrote: »
    Wired_Driver.spin
    #include <stdio.h>
    #include <stdint.h>
    #include <dirent.h>
    #include <sys/sd.h>
    #define ALIGN                   16
    typedef struct {
        void *hubram_addr;
    } VGA_PARAMS;
    typedef struct {
        void *workram;
    } WIRED_PARAMS;
      &_FileDriver,
      NULL
    #define DO   	44
    #define DI      45
    #define CLK     46
    #define CS      47
        FILE *fp;
            return 1;
            return 1;
        addr = 0x00000000;
            addr += BLOCK_SIZE;
        fclose(fp);
        return 0;
    What are you doing with vbptr? I see it's declared and passed to the Wired Driver, but the driver spins until there is something written, who writes to it?
  • BaggersBaggers Posts: 3,019
    edited 2013-05-11 01:01
    The Video Driver sets it to 1, signifying a vertical blank ( well, the end of the displayed frame, for maximum time between that and the start of the new frame )
    As for the timing, yes, it was used from Chip's driver.
    I'll have a look at the C wire-world later today.
    Do you have a project zip?
    edited 2013-05-11 05:40
    Baggers wrote: »
    I'm attaching a zip file containing all of the source as well as a built .elf file. The C code loads the SDRAM driver, loads the image from the SD card into SDRAM, loads the VGA driver, and then finally overwrites the C code with the Wired driver. By the time the demo is running there is no C code running anymore.
    sdramtest.zip
    Thanks for offering to take a look at this!
    David
    Edit: I introduced a typo when I added comments to my C code. I've replaced the attached file with updated code fixing that bug.
  • RaymanRayman Posts: 15,739
    edited 2013-05-11 06:44
    I hadn't heard of WireWorld before... It's interesting..
    edited 2013-05-11 06:49
    Rayman wrote: »
    The static starting image looks interesting. I can't wait to see it in action!
    edited 2013-05-11 07:32
    Okay, I think I have Baggers' demo working. I misread the original code and modified it to using dynamic parameters incorrectly.
    Original code:
    hub_loc long    SDRAM_COMMANDS+$08
    sd_loc  long    SDRAM_COMMANDS+$0c
    hub0_rd long    WORKRAM+$000+7
    hub1_rd long    WORKRAM+$400+7
    hub2_rd long    WORKRAM+$800+7
    hub1_wr long    WORKRAM+$c00+8+7
    I essentially translated the last line to this:
    hub1_wr long    WORKRAM+$400+8+7
    I did this because I figured hub1_wr was just a variant on hub1_rd but was mistaken.
    In any case, the program is now doing something. I'm seeing one row of pixels at the bottom of the display that seems to be displaying garbage. Otherwise, the original image is changing with each frame although I'm not sure what I should expect to see so I don't know if it is working correctly. The digital display at the top shows "00019". Is this a counter demo? Should I expect it to change to "00020" if I let it run long enough?
    Anyway, I've attached the working code.
    Thanks Baggers!
    sdramtest.zip
    edited 2013-05-11 08:06
    David Betz wrote: »
    I followed the link in the top post and found that this is computing prime numbers. How long should it take to go from 19 to 23?
    edited 2013-05-11 10:25
    Back, glad you got it working David :)
    Yes, you're right, it's a prime number counter, apparently, the start image, is from about 4 million iterations of the thing, so it's a bit slow, but does work, on a fast PC, maybe when we get the final P2 chips, I'll multi-cog it, and see how fast we can get it ;)
    edited 2013-05-11 10:34
    Baggers wrote: »
    Have you ever run it long enough to reach 23? How long did it take? I'm wondering if mine is really working correctly. Also, this C wrapper might be of use to some of you PASM driver developers since it can load images from an SD card a lot faster than you can send them over a serial link.
    edited 2013-05-11 11:11
    If it's animating ie the electrons are moving around the circuit, then it's working, it will take a long time, as even on a fast PC it took a while to go from 19 to the next digit, so we need to speed it up, before realistically watching it, unless you want to leave it on overnight :D lol
    edited 2013-05-11 11:50
    Baggers wrote: »
    Yes, the electrons are moving around the circuit. I guess I'll just leave it for a while to see if it ever moves to the next prime. Maybe Parallax will send me a second DE2-115 board so I don't have to disturb this program! :-)
    edited 2013-05-11 12:39
    One can dream :)
    edited 2013-05-11 21:19
    My coworker had this running on his PC for a few hours. I can't tell you how fast it runs as we never saw the display change to the next prime.
    We could see lots of gates gating and flip-flops flip-flopping but no change in output.
    I might not expect to live long enough to see it change on a Prop.
    edited 2013-05-12 04:44
    I let my version of Baggers' WireWorld demo run for over 24 hours and it finally switched from 19 to 23 so it *is* working.
    I guess I've had enough fun with that demo now and will move on to other things. Is anyone here interested in the framework I setup for loading and starting PASM drivers built using PNut? The main program I wrote for this WireWorld demo can load an image and then start drivers. It's written in C so I image that will make it unappealing to some here but it does serve a useful purpose. I've noticed that a number of the drivers here are awkward to use because they have demo code built in that must be removed to use the simply as drivers. This is why it took me a while to get the WireWorld demo working. Using the C framework lets you write drivers that can be compiled independently with PNut and merge them with a main program that allocates memory and loads these drivers. Since C has support for the FAT filesystem on the SD card it is also possible to load data from the SD card which I imagine is much faster than sending it across the serial port. It would also allow for standalone operation combined with flashing the main program into the SPI flash.
    edited 2013-05-12 05:10
    Yay!! Glad it worked David :D
    I'll start looking at working with C too.
    edited 2013-05-13 10:03
    David, was there a project file, that I can load in SimpleIDE?
    or do you just use the makefile to build it?
    edited 2013-05-13 10:33
    Baggers wrote: »
    Sorry, I don't use SimpleIDE so I don't have a project for this. I can look at making one but I won't be able to do it until tomorrow probably.
    edited 2013-05-13 10:51
    No worries David, I'll use the makefile then :)
    edited 2013-05-13 11:01
    When I type
    make run
    I get
    propeller-elf-gcc -mlmm -mp2 -Os -c -o sdramtest.o sdramtest.c
    make: *** [sdramtest.o] Segmentation fault: 11
    Any ideas?
    edited 2013-05-13 11:03
    Baggers wrote: »
    When I type
    make run
    I get
    Any ideas?
    Ugh. This is under Windows?
