Propeller II programing questions to Chip - Page 7 — Parallax Forums
123457»
  • AribaAriba Posts: 2,695
    edited 2013-04-07 09:02
    There are other such Pseudo-Instructions. I've found that TESTB reg,#bit is the same as ISOB reg,#bit NR
    Andy
  • SapiehaSapieha Posts: 2,964
    edited 2013-04-09 15:00
    Hi Chip.
    How I can in PNut write that table.
    tab1_  org  $         '';direct commands
           Byte "list"                                                        ' Any place in assembly code
           Word list         ''shr 8 + 128,list and 255                                 ' Any place in assembly code
           Byte "run"
           Word run             ''shr 8 + 128,run and 255    '<----------------- Original in 8080 assembly BYTE,BYTE
    edited 2013-04-10 00:58
    Hi Chip.
    Forget it.
    I found my problem --- If I use WORD's it adds 0 to fill LONG's --- That disturbed my scan routine.
    Now That are fix
    edited 2013-04-10 01:29
    Ps to previous post.
    That function for me.
           Byte "list"
           byte $80+list>>8,list         ''shr 8 + 128,list and 255
           Byte "run"
           byte $80+run>>8,run             ''shr 8 + 128,run and 255
    edited 2013-04-19 03:11
    Hi Chip.
    Are $1F6,$1F7 (INDA, INDB] direct addressable else can this position can be used for other usage ?
    And INDA, INDB can only be addressed by SETINDA,SETINDB
    edited 2013-04-21 14:55
    Hi Chip.
    What are difference between this 2 RET instructions
    And Can You give syntax examples on one that are different from Propeller 1
    ''000111 ZC0 1 CCCC 000000000 000000000    |   RET        |           | ''Return from subroutine            4 *
    ''111010 001 1 1111 000000000 000000000    |   RET        |           | ''Like JMP, but assembler handles details
    edited 2013-04-21 18:24
    Sapieha wrote: »
    Hi Chip.
    My list shows opcode 111010 as CFGPINS & INCMOD.
    There is opcode 111010 which is JMPRETD, a delayed JMPRET.
    edited 2013-04-21 18:39
    Hi Cluso.
    Thanks.
    Cluso99 wrote: »
    edited 2013-04-21 18:47
    Hi Cluso.
    I have.
    I see I need test them by PNut.
    010111 ZCR 0 CCCC DDDDDDDDD SSSSSSSSS        JMPRETD D,S     ''jump to S, store return in D      1
    000111 ZCR 0 CCCC DDDDDDDDD SSSSSSSSS        JMPRET  D,S     ''jump to S, store return in D      4 *
    000111 ZCR 1 CCCC DDDDDDDDD nnnnnnnnn        JMPRET  D,#n     ''jump to 0..511, store return in D 4 *
    111010 000 I CCCC DDDDDDDDD SSSSSSSSS   |   CFGPINS     |   D/#n    | Setup pins masked by register &#8220;D (0-511)&#8221; to register
    111010 ZCR I CCCC DDDDDDDDD SSSSSSSSS   |   INCMOD      |   D,S#n   | Increment D between 0 and S. Wraps around to 0 when above S
    edited 2013-08-02 00:28
    Hi Chip.
    Have You any updates on Instructions, counters block diagrams and other things we can have play with ?
  • cgraceycgracey Posts: 14,293
    edited 2013-08-02 10:09
    Sapieha wrote: »
    Hi Chip.
    Not yet.
    I'm getting close to having the new Spin interpreter running. This is taking all my work time, for now.
  • eldonb46eldonb46 Posts: 70
    edited 2013-08-02 13:14
    Chip, by chance, are you including new SPIN constructs to access the four tasks per COG of the Prop II?
    see: http://forums.parallax.com/showthread.php/141706-Propeller-II?p=1122712#post1122712
    Eldonb46
    edited 2013-08-02 13:42
    Hi Chip.
    Thanks for reply.
    Good look with SPIN
    Not yet.
    edited 2013-08-02 14:33
    Chip,
    I think all of us are looking forward to Spin for Prop2 :-) so it is really nice to hear it is close!
    Not yet.
    edited 2013-08-02 16:38
    eldonb46 wrote: »
    Eldonb46
    Yes. The interpreter uses the top half (actually, less) of cog RAM, as well as the top part of the stack RAM, PTRB, INDB, and SPB. This leaves free for PASM code (which could be multitasking): the first half+ of cog RAM, the first part of stack RAM, PTRA, INDA, and SPA.
    edited 2013-08-02 16:55
    Hi Chip.
    Look's as nice solution
    edited 2013-08-03 06:32
    Chip,Now that is interesting.
