PropBOE Stack-on module {PropBOE I/O Shield}: Open Source / assembly & .dip attached
Oldbitcollector (Jeff)
After spending the weekend deep in PropBOE demos, I realized that I really missed having some I/O options.
What do you guys think of something like this? It would sit on top of the breadboard zone and provide IR, Keyboard, and Wii compatible connections.
If there's some interest, I'll finish this up and do a run of them.
Edit: Loaded final image.
Edit2: The boards are in! I tossed together a quick test unit to check it out. Perfect!
Jeff
Jeff
I'll take 20 sets. Please include the connectors, if possible. Contact me when they're ready.
Jeff
Image updated in OP
Jeff
I'm waiting for female SIP connectors (I just chopped down a 40pin connector for a quick/dirty test) -- Images are in the first post.
Now my PropBOE is awesome!
Jeff
Give us a heads up when we can buy a couple.
http://propellerpowered.us/index.php?route=product/product&path=25_60&product_id=216
Detailed assembly instructions and test programs are available at: http://propellerpowered.com/forum/index.php?topic=428.0
Jeff
I'll make sure that a couple are set aside for you! No problem!
Jeff
These are also compatible with the new Propeller Activity Board.
Jeff
Oh, you cruel purveyor of temptation!!!
Jeff
Nothing would surprise me about your service!!
There is plenty of prototyping space on this product, shouldn't be too much of an issue to drop in the memory and Bluetooth connections.
Jeff
Sure, but it's very inconvenient. I expect the volume will be high compared to some other things. I'll do a module with just flash now and add bluetooth later. If I finish the design by Sunday, I can have protos ready for the Expo. My plate overfloweth .....
Drop in Vdd/Vss/four data connections for those inexpensive Bluetooth modules.
Jeff
Does anyone have the documentation and sample code for this board?
If you do, can you please supply a link, or up-load the files (the files are no longer on propellerpowed.com)?
zappman
I'll get into my source materials and post up some documentation. Please give me the day.
Jeff
Thanks for your quick reply
zappman
Jeff or anyone else on the forums,
I am still looking for the documentation and sample code for this board, can anyone please help me out?
zappman
Sorry for the delay. I'm not sure what has become of my original documentation for this board.
Attached is an image that should help you get the unit built.
The idea here is to provide duplication of the existing PropBOE/Activity Board connection on the left side,
then provide breakout access to Keyboard, Wii, and IR connections on the Right.
The keyboard circuit is "parallax standard" and will work with existing code in obex. The wii and IR connections have code in obex as well.
Since this is a discontinued product, I'm posting the DIPTRACE .dip file with the build image. This product should now be considered Open Source under the Creative Commons license.
If there is interest, I have a good batch of PCBs. I'll make them avaible as PCB only for $4.00 each which includes shipping to the US. PM me.
Jeff
Thank you for all the information in your post, including the Diptrace files.
I believe, I have the information I need to use the Keyboard, Wii, and IR connections on the board.
I am going to try to use the Wii connection with my "Wii Classic Pro" controller.
Later, I want to use the IR receiver to respond to commands from an IR remote control.
zappman
