p2load: A Loader for the Propeller II - Page 9 — Parallax Forums
1567911
  • SapiehaSapieha Posts: 2,964
    edited 2013-03-31 20:35
    Hi David.
    I added 0.5 sec wait time before COG-1 starts Monitor
    AND it works
    Now I can stop COG-0 by monitor and Monitor are running in COG-1
    edited 2013-03-31 21:14
    Hi David.
    Now I can say ----> -c 1,1000:0 function
    p2load -v Head.obj prog.obj,1000 -c 1,1000:0 -t
    You can test by rename attached files xxx.obj and run p2load command line in example
    Prog.spin
    'Stop COG-0 Spawn monitor on COG-1
    DAT
    Monitor        org        0
                    getcnt    time
                    add    time, delta
                    waitcnt    time, delta
                COGSTOP        0
                    setcog    #1
            coginit monitor_pgm,monitor_ptr
                long        $FF[10+32]
    ''------------ DE2-115 Test LED, Switch -------
    '' --- Port A ---------LED --------------------
    LEDS    long $
    _LED15    byte 29                    '' DE2-115
    _LED16    byte 30                    '' DE2-115
    _LED17    byte 31                    '' DE2-115
    '' --- Port B ---------------------------------
    _LED0     byte 32                    '' DE2-115
    _LED1     byte 33                    '' DE2-115
    _LED2     byte 34                    '' DE2-115
    _LED3     byte 35                    '' DE2-115
    _LED4     byte 36                    '' DE2-115
    _LED5     byte 37                    '' DE2-115
    _LED6     byte 38                    '' DE2-115
    _LED7     byte 39                    '' DE2-115
    _LED8     byte 40                    '' DE2-115
    _LED9     byte 41                    '' DE2-115
    _LED10    byte 42                    '' DE2-115
    _LED11    byte 43                    '' DE2-115
        long 0
        long 0
        long 0
    '' --- Port A ----------SW --------------------
    KEYSW    long $
    _KEY1    byte 29                    '' DE2-115
    _KEY2    byte 30                    '' DE2-115
    _KEY3    byte 31                    '' DE2-115
    _SW0      byte 32                    '' DE2-115
    _SW1      byte 33                    '' DE2-115
    _SW2      byte 34                    '' DE2-115
    _SW3      byte 35                    '' DE2-115
    _SW4      byte 36                    '' DE2-115
    _SW5      byte 37                    '' DE2-115
    _SW6      byte 38                    '' DE2-115
    _SW7      byte 39                    '' DE2-115
    _SW8      byte 40                    '' DE2-115
    _SW9      byte 41                    '' DE2-115
    _SW10      byte 42                    '' DE2-115
    _SW11      byte 43                    '' DE2-115
                long    0
                long    0
                long    0
                long    0
    monitor_pgm    long    $70C            'ROM entry point for monitor
    monitor_ptr    long    90<<9 + 91        'Pins for one monitor
    time    long    0
    delta    long    30000000
    Mend        long $
    MBoxX        byte    $0[($0FFF-Mend-$E8F)-4]        ''/4-(6*4)]
    MBoxXa        org    $
            long    MBoxXa
    F:\-Morph-Temp\_NANO_\Emulator\P2Terminal_cordic\p2load._M>p2load -v Head.obj  p
    rog.obj,1000 -c 2,1000:0 -t
    Trying COM1
    error: hardware lost
    Trying COM9
    Found propeller version 32 on COM9
    Loading 'Head.obj' at 0x00000e80
    Loading 'prog.obj' at 0x00001000
    [ Entering terminal mode. Type ESC or Control-C to exit. ]
    === Propeller II Monitor ===
    00000- 50 72 6F 70 32 2E 30 20 00 20 7C 0C 03 CA 7C 0C   'Prop2.0 . |...|.'
  • pedwardpedward Posts: 1,642
    edited 2013-04-01 01:02
    Makefile needs an addition on line 62:
    all: $(TARGET)
    Otherwise Eclipse, and pretty much any Unix environment, won't automatically build without an "all" rule.
    Also, I recommend replacing the hardcoded OS selection with some auto-detection.
    edited 2013-04-01 01:09
    David Betz wrote: »
    Okay, I guess I don't need to understand this fully since I'm not writing video code. In any case, I shouldn't be bothering you with these questions. Is should read Chip's documents myself or his sample code. Sorry!
    Chip was only able to test the synthesized logic component of the Prop2 using an FPGA. The memory and I/O pad frame were designed schematically and implemented in silicon by Beau. They won't have a true-blue Prop2 test chip until the shuttle run arrives.
    Chip cheated DACs on the FPGA by bringing out the 9 bits of the DAC to R2R ladders, but the limitation in FPGA is that only COG 0 has them brought out to hardware. Surely if you had a Stratix 3 like Chip, there would be enough pins to bring all DACs out to real hardware, but that's pointless.
    I recall Chip mentioning something about them getting a couple of silicon chips with the I/O hardware implemented, to test that they worked, but there was some complication with that test run.
    Everyone has their fingers crossed that diligence and intelligence will result in 1 test run before they commit to a production run.
    edited 2013-04-01 04:35
    Cluso99 wrote: »
    David:
    I seem to be having a problem starting my program where I compile from $0 with fillers to $1000. The code loads fine but does not execute - I can see this by using your program to do an -m to start the monitor after loading hub. This is really nice because you can actually see what is in cog after the loading.
    This is the command (I downloaded the latest v0.003)
    p2load -v -s lsd_036.obj -h
    My program is attached. It waits 5 secs and then boots the Rom Monitor. It appears that the cog (cog0 because I am on DE0) does not boot or gets lost???
    Using -t gives the same result.
    I tried the -c option and it fails with
    c:\Propeller_II\P2Load>p2load -v -s lsd_036.obj -c 0,1000:0 -t
    Trying COM8
    Found propeller version 32 on COM8
    Loading 'lsd_036.obj' at 0x00000e80
    Timeout waiting for ACK/NAK
    error: send start packet failed
    Attachment not found.
    The default behavior of the loader is to start the program 0xe80 unless either -h or -r are used to change the start address to something else. The -h option changes the start address to 0x1000 and the -r option allows you to set it to whatever you want. For example, "-r 1000" will do what you want. Also, if you are loading a .elf file produced by the GCC linker the default start address is 0x1000 so the -h option is not needed in that case.
    edited 2013-04-01 07:46
    Cluso99 wrote: »
    David:
    Trying COM8
    I just thought of something that might help here. I should probably check for the special case of using "0" as the COG number in the -c option and treat it the same as if you had specified the -r option. In other words:
    -c 0,1000:0
    would be handled as if you had entered
    -r 1000,0
    The reason using the -c option didn't work for you is that you loaded something over the top of the second-stage loader and that killed the rest of the load. The -r option tells the loader how to restart COG 0 once the load is complete and the second-stage loader is no longer needed. I'll add that later tonight if I get a chance.
    edited 2013-04-01 08:16
    fyi, p2load compiled cleanly under Ubuntu 12.04
    edited 2013-04-01 08:18
    That's good to hear! Thanks for the report.
    edited 2013-04-01 09:15
    I've updated the top post with version 0.004 that treats "-c 0,xxx:yyy" as if you had entered "-r xxx:yyy".
    edited 2013-04-01 10:19
    You are welcome :)
    I did find a defficiency in the terminal mode - if you exit with a ^C, it leaves the shell messed up.
    Not a big deal, I went back to using GtkTerm for serial I/O, and use p2load to load.
    Is there a way of getting PNut to make the obj without downloading?
    David Betz wrote: »
    edited 2013-04-01 10:28
    You are welcome :)
    Oops, sorry about that. I'll look into fixing that later. You can exit by entering ESC in the meantime. That should leave the terminal in a good state.
    You can get PNut to generate the .obj file by selecting the "Compile Current and View Info" F9 option in the "Run" menu.
    edited 2013-04-01 10:39
    Thanks!
    ESC worked great.
    You must use a different version of PNut, mine does not have that menu entry :(
    David Betz wrote: »
    edited 2013-04-01 10:46
    Thanks!
    ESC worked great.
    Hard to say. My copy says "Prop 2 IDE 0.0". Hard to believe there was a version before that. Maybe version -1? :-)
    edited 2013-04-01 10:51
    Hi
    My one to -- Don't have F9 option
    David Betz wrote: »
    edited 2013-04-01 10:55
    Sapieha wrote: »
    Hi
    I thought I read a message somewhere that Chip had updated PNut to load files larger than 2K. Maybe when he did that he figured no one would need p2load anymore so he removed the F9 option?
    edited 2013-04-01 15:59
    I use ctrl-L
    edited 2013-04-01 17:46
    David: I think you missed the first part of my problem. The -h didn't work for me. Am I doing something wrong?
    Postedit: Just tried v0.004 and the same problem...
    This does not work...
    p2load -v -s lsd_038.obj -h
    and this does work...
    p2load -v -s lsd_038.obj -c 0,1000:0
    edited 2013-04-01 19:39
    Cluso99 wrote: »
    Oops. I think the -h option got broken when I added the -r option. Sorry about that.
    edited 2013-04-01 19:52
    Cluso99 wrote: »
    Okay, I think I have this fixed. I'll build a new Windows version and upload it in a few minutes.
    david-betzs-macbook-pro:Downloads dbetz$ p2load -s -h LSD_036.obj -t
    Found propeller version 32 on /dev/cu.usbserial-A700fKXl
    Loading 'LSD_036.obj' at 0x00000e80
    edited 2013-04-01 19:55
    Thanks David. Perhaps with your latest changes, the -h and the -r options are no longer required as we have the -c solution which is far more powerful.
    At some time, you may consider adding a value option to the -s command?
    edited 2013-04-01 20:02
    Cluso99 wrote: »
    They're more powerful but they're also more of a pain to type. The -h option was intended to select the "high" address for the COG image following the convention of leaving the space between 0xe80 and 0x1000 for globals and mailboxes. I guess the -r option could be removed since it the same thing can be done with -c now with only two extra characters. I'm not sure if it's worth making yet another change though. I've posted far too many versions of p2load as it is! :-)
    edited 2013-04-01 20:11
    I've updated the top post with a new version of p2load that I hope fixes the -h bug that Cluso reported. Sorry about that!
    edited 2013-04-01 20:34
    Thanks David. The -h now works!
    edited 2013-04-01 20:43
    Cluso99 wrote: »
    You're welcome. Sorry for the bug!
    edited 2013-04-02 05:10
    Are people generally happy with the way p2load works at this point? Are there any issues that still need addressing or can I consider it stable for the moment?
    edited 2013-04-02 05:14
    Hi David.
    For me it is stable at the moment.
    If I find any problem -- will report.
    David Betz wrote: »
    edited 2013-04-02 05:54
    Sapieha wrote: »
    Hi David.
    Thanks Sapieha!
    edited 2013-04-02 07:35
    I am about to produce a document for P2Load and reference that in the monitor document where appropriate. For longer term reference, where do I point people to get the current version?
    edited 2013-04-02 07:56
    potatohead wrote: »
    Good question. The sources are part of the PropGCC project on Google Code but my official method of distributing it so far has been the top post of this thread.
    edited 2013-04-02 07:57
    potatohead wrote: »
    And, THANKS for offering to make a document describing p2load! I'd be happy to review anything you come up with.
