p2load: A Loader for the Propeller II - Page 7 — Parallax Forums
15791011
    edited 2013-03-30 10:54
    Sapieha wrote: »
    Hi David.
    I think I don't understand something.
    F:\-Morph-Temp\_NANO_\Emulator\P2Terminal_cordic\p2load._M>p2load -v driver_NTSC.obj -r e80:0
    Trying COM1
    error: hardware lost
    Trying COM9
    Found propeller version 32 on COM9
    Loading 'driver_NTSC.obj' at 0x00000e80
    Loading 'e80' at 0x00000e80
    error: can't open 'e80'
    Okay, I think I've fixed this. Try downloading the Windows version in the top post again. You don't really need "-r e80:0" though since that is the default. Well, not quite. The 0xe80 address is the default but the default value for param is 0x20000 which is the highest address in hub memory. That is used by PropGCC programs to set the initial stack pointer.
  • SapiehaSapieha Posts: 2,964
    edited 2013-03-30 10:58
    Hi david.
    Thanks.
    I know e80 are default -- But it was simplest for me use any already existing binary My one need parameter 0
    Will test new one and report.
    David Betz wrote: »
    edited 2013-03-30 11:04
    Hi David.
    .obj,1000 -r 1000:0
    Trying COM1
    Trying COM9
    Loading 'driver_NTSC.obj' at 0x00001000
    Loading '1000' at 0x00000e80
    error: can't open '1000'
    David Betz wrote: »
    edited 2013-03-30 11:13
    Sapieha wrote: »
    Hi David.
    .obj,1000 -r 1000:0
    Trying COM1
    Trying COM9
    Odd. I just tried this on the Mac and it worked. Maybe I uploaded the wrong version? I guess I'll try again. Maybe I should put a version number in p2load.exe so we can tell what version we're using.
    edited 2013-03-30 11:16
    Hi David.
    Shall wait You write -- Correct downloaded -- v.x number can help
    David Betz wrote: »
    edited 2013-03-30 11:26
    Sapieha wrote: »
    Hi David.
    I just uploaded again. If you type "p2load -?" after you install it you should see the first line indicate version 0.001 and today's date.
    edited 2013-03-30 11:36
    Hi David.
    It look's that it work -- Need made more test's
    Thanks.
    .obj,1000 -r 1000:0
    Trying COM1
    Trying COM9
    David Betz wrote: »
  • BaggersBaggers Posts: 3,019
    edited 2013-03-30 11:48
    David Betz wrote: »
    Glad to be of assistance. Can I ask you for a favor though? How about a binary of that image you send before that will display correctly on my TV? :-)
    I too am glad to be of assistance :D
    16bitimages.zip
    edited 2013-03-30 11:51
    Baggers wrote: »
    16bitimages.zip
    Ah, that looks much better! Thanks!
    edited 2013-03-30 12:17
    Hi David.
    Can I specify in any way --- What COG to use with -r else -c flag?
    David Betz wrote: »
    edited 2013-03-30 12:42
    Sapieha wrote: »
    Hi David.
    The -r option always uses COG 0. The -c option uses COGNEW so you get whatever COG is available. Practically speaking though, you will get COG 1, COG 2, etc since there is nothing running on any of those COGs at load time.
    edited 2013-03-30 12:48
    Hi David.
    I'm have thinking more universal thing -- That give me full control.
    p2load._M>p2load -v driver_NTSC.obj,1000 -r 2,1000:0
    David Betz wrote: »
    edited 2013-03-30 12:50
    Sapieha wrote: »
    Hi David.
    I don't have time to do that right now. Why does it even matter the COG number where something is running? You always interact with a COG via a mailbox, right? When do you ever use the COG ID unless you need to stop the COG?
    edited 2013-03-30 12:57
    Hi David.
    Thanks for reply. Will find any way do do what I will.
    But as You know --- On emulators we can only use COG-0 for Display driver so I can't auto-start MIN Program in it.
    So I need start it in any of other COG's --- As it i this MAIN COG that will look in BOXES to fin and load drivers in corect places.
    David Betz wrote: »
    edited 2013-03-30 13:01
    What I do for now is that my video driver cog, in its initialization, launches another cog.
    Sapieha wrote: »
    Hi David.
    edited 2013-03-30 13:02
    Sapieha wrote: »
    Hi David.
    It would be possible to accept a COG number for the -c option but the loader is running in COG 0 and that is the COG that is always started using the -r option.
    edited 2013-03-30 13:03
    Same here. Optionally a supervisor COG could fire everything off, then restart itself as the video COG.
    edited 2013-03-30 13:37
    Sapieha wrote: »
    Hi David.
    I didn't know you had to run the display driver in COG 0. Why is that? Anyway, I have no control over which COG is running the loader. It's decided by the ROM bootloader.
    edited 2013-03-30 14:53
    Sapieha wrote: »
    Hi David.
    Sapieha,
    Are you saying that without this ability to select a specific COG, you are unable to use p2load?
    edited 2013-03-30 15:04
    Hi David.
    That I have never said else thinking.
    You have write Very nice tool that are very usable.
    I can use AND will use it -- Only thing without that need re-manage some of my files and save space in Display Driver for Supervisory part
    But that have be simplified for me and many others
    David Betz wrote: »
    Sapieha,
    edited 2013-03-30 15:19
    Sapieha wrote: »
    Hi David.
    Sorry that you have to rearrange things. If you can think of a better way let me know. As I said, the only thing I could easily do is allow -c top select a specific COG. To do that with -r would be difficult. It would require that I relaunch the loader on another COG.
    edited 2013-03-30 15:23
    Hi David.
    If You can that -- that can help --- If -c can be specified multiple times
    David Betz wrote: »
    edited 2013-03-30 15:30
    [edited --droid phone barely posts here]
    The DAC emulation output only exists on COG 0. I think everything else is on the other COGS. Pin emulation isn't complete either, but what there is exists on the four DAC pins on COG 0.
    And that is why we need to put the display on COG 0 for now.
    Oh, and no more Excel macros to format a monitor load file. (I know, but it was stupid easy) The load is really fast now!
    edited 2013-03-30 18:59
    Sapieha wrote: »
    Hi David.
    I made the change you requested to the -c option. You can now do either of these:
    -c addr:param
    -c id,addr:param
    Be aware that no spaces are allowed around the comma or colon. The same applies to the -r option and to the comma following a file to load. I'll upload a new Windows version shortly after I ask another question in a separate message.
    edited 2013-03-30 19:16
    I just posted a new Windows version with Sapieha's -c option feature making it possible to load into a specific COG. You can't really load into COG 0 though since that is the COG that is running the second-stage loader. The default baud rate is now 230400 as well. This is version 0.002.
    edited 2013-03-31 01:02
    Hi David.
    David Betz wrote: »
    edited 2013-03-31 02:06
    David, many thanks for your efforts. Hopefully I can get time to try it tonight.
    edited 2013-03-31 03:06
    David: I just downloaded the latest windoze build from using the link in the first post (identifies as v0.002 2013/3/30).
    It fails to download my file correctly using
    p2load -v lsd_035.obj -s
    It apears that p2load is not skiping the $E80 zero bytes at the start of the file, so my code is loading into $1D0. My older version of 2012/12/07 works fine on the same obj file.
    I tried the -m -t and they work fine so thanks for that :)
    edited 2013-03-31 04:19
    Cluso99 wrote: »
    You have to put -s before the filename now because you can have more than one file on a single command line and -s applies to the next file.
    edited 2013-03-31 05:51
    thanks david. i will try again tomorrow.
    btw did you find the problem with setcog ?
