My First SMD Soldering Attempt
OK, So I got my new Solder Station, I got this kit http://www.appliedinspirations.com/appliedcontent/Projects/SMD-Soldering/SMD_SolderingKIT.html
which looks to be a great starting point. I am about ready to embark on my first SMD soldering experience. Any insight that you pros have I could sure use right about now!!!! I want to do this using only my solder station so please no oven baking advise right now. That will come in due time. I have several solder tips from very fine to fairly large. I think the caps are going to be the hardest as it says to heat them up first but not to touch the terminals, so how am I suppose to heat them? Hot air maybe and use that over the board also?
As for the caps, I'm not sure. Pick them up with tweezers from the sides. Do you have hot tweezers on your station?
Also a tip, when Im having trouble keeping an IC or something in place, due to pitch size, I dab the bottom with super glue, line it up wait a few minutes then solder. Make sure to practice aligning it on the pads a few times before using glue though.
EDIT: I found it on raymans site. Looks too easy!
No pcb, magnet wire. This was done using precision tweezers (fine point kind can be found in the female beauty section) (they are so fine they are sharp like a needle)
Precision point needle nose pliers.
Precision point temperature controlled solering station. (Sodr-tek) is a good brand.
Proper tip tinner, AND sponge cleaner.
And fine solder with some real Pb (or even a better solder that has Ag in it? Ive never worked with high silver content solder..)
I don't need a magnifying device to do this, but I would prefer one.
Makes it much faster.
I built 48 of these with no magnifier.
Wow! Just WOW!
I don't use pcbs or magnifiers because the very little money I have goes into buying prop chips, and the object frame. ( I need more than 48 of them, that is just the minimal.)
Heres a link http://forums.parallax.com/showthread.php/127983-55-Parallax-Propeller-s-Parallells-Processing-of-Permanent-Perturbations./page2
Wow, yeah, really good tips there for hot air or iron, various packages, etc. Nice.
