Is there a PST equivalent to run on Ray's LCD screens?
I would like to be able to display what I have been displaying on PST on my pc to the LCD display instead. How does one go about this? Is there already some code out there for this?
Thanks.
Don
Thanks.
Don
I may not have a scrolling text example exactly like you want, but the "PSB_VGA_Demo" on this page:
http://www.rayslogic.com/Propeller/Products/PSB/PSB_Display.htm
should be fairly easily adapted to do what you want...
I tried adding this method to get it to print a string from the dat section (I added the str method from FDS) your print method was already there:
PUB print(c) | i, k case c $00..$FF: ' character? k := color << 1 + c & 1 i := k << 10 + $200 + c & $FE screen[row * cols + col] := i screen[(row + 1) * cols + col] := i | 1 if ++col == cols newline $100: ' clear screen? wordfill(@screen, $200, screensize) col := row := 0 $108: ' backspace? if col col-- $10D: ' return? new line? newline $110..$11F: ' select color? color := c & $F PUB str(stringptr) '' Send zero terminated string that starts at the stringptr memory address repeat strsize(stringptr) print(byte[stringptr++])but it doesn't work right. In the beginning section of your demo you write to the screen like this:
repeat i from 0 to 25 print(something[i])but I was hoping to make it work more like FDS in that when it hits a zero terminated string it quits etc....
To get smaller text, you have to work magic on the assembly language driver and provide any necessary font tables ... doable, but not a trivial change.
Mike- I didn't see any str method in his demo or driver. The str method is what I added and treated the print as if it were tx.
I got it working but I'm curious as to why the text does not stay on the screen after it is displayed unless there is a repeat loop or a long pause it will disappear.
I'm trying to make this work as though it is a terminal. And just like FDS & PST if I send the charachters to it they remeain on the screen. Help me understand this object.
CON _clkmode = xtal1+pll16x _clkfreq = 80_000_000 cols = 30 rows = 17 screensize = cols * rows VAR long lcd_status 'status: off/visible/invisible read-only (5 contiguous longs) long lcd_enable 'enable: off/on write-only long lcd_videobase 'video base @word write-only long lcd_colorbase 'color base @long write-only long lcd_backlight 'Used to control LCD backlight word screen[screensize] long col, row, color long boxcolor,ptr long stack[100] OBJ vga : "PSB_LcdDriver" 'Modified to also drive TFT pub launch cognew(begin, @stack) repeat PUB begin: I Start 'Pins already defined in LCD driver print($100) ' clear screen print($113) ' set background color to black repeat i from 0 to 13 ' send message this way print(message[i]) col := 0 row := 6 print($114) str(@message) repeat '<<<<<< if this repeat is removed then the text goes away. Why? i := cnt waitcnt(i += 22500000) 'spcl := $30101020 waitcnt(i += 22500000) 'spcl := $10301020 '' Start terminal - starts a cog '' returns false if no cog available PUB start print($100) 'start driver lcd_enable:=1 lcd_videobase := @screen lcd_colorbase := @vgacolors lcd_backlight:=3 '1=bright, 16=medium, 32=dark vga.start(@lcd_status) '' Stop terminal - frees a cog PUB stop vga.stop '' Draw a box PUB box(left,top,width,height) | x, y, i ptr := top * cols + left boxchr($0) repeat i from 1 to width boxchr($C) boxchr($8) repeat i from 1 to height ptr := (top + i) * cols + left boxchr($A) ptr += width boxchr($B) ptr := (top + height + 1) * cols + left boxchr($1) repeat i from 1 to width boxchr($D) boxchr($9) PRI boxchr(c): i screen[ptr++] := boxcolor << 10 + $200 + c '' Print a character '' '' $00..$FF = character '' $100 = clear screen '' $108 = backspace '' $10D = new line ''$110..$11F = select color PUB str(stringptr) '<<<<<< I added this method from FDS '' Send zero terminated string that starts at the stringptr memory address repeat strsize(stringptr) print(byte[stringptr++]) '<<<< I changed this from tx to print PUB print(c) | i, k case c $00..$FF: 'character? k := color << 1 + c & 1 i := k << 10 + $200 + c & $FE screen[row * cols + col] := i screen[(row + 1) * cols + col] := i | 1 if ++col == cols newline $100: 'clear screen? wordfill(@screen, $200, screensize) col := row := 0 $108: 'backspace? if col col-- $10D: 'return? newline $110..$11F: 'select color? color := c & $F ' New line PRI newline : i col := 0 if (row += 2) == rows row -= 2 'scroll lines repeat i from 0 to rows-3 ' wordmove(@screen[i*cols], @screen[(i+2)*cols], cols) 'clear new line ' wordfill(@screen[(rows-2)*cols], $200, cols<<1) ' Data DAT message byte "This is a test", $10D byte "This is line 2", 0 vgacolors long long $00000000 'black red is C000C000 '<<<<< changed this to get black background long $C0C0C0C0 ' red was $C0C00000 long $08A808A8 'green long $0808A8A8 long $50005000 'blue long $50500000 long $FC00FC00 'white long $FCFC0000 long $FF80FF80 'red/white long $FFFF8080 long $FF20FF20 'green/white long $FFFF2020 long $FF28FF28 'cyan/white long $FFFF2828 long $00A800A8 'grey/black long $0000A8A8 long $C0408080 'redbox spcl long $30100020 'greenbox long $3C142828 'cyanbox long $FC54A8A8 'greybox long $3C14FF28 'cyanbox+underscore long 0So 2 questions-
1. Why is a repeat needed after the strings are sent?
2. Why doesn't the message from dat trigger a newline with the embedded $10D?
As for the display disappearing, the LCD driver sets some pins in the context of the caller's cog which - when you exit (no repeat) - return to their default state(s) therefore turning off the display.
Thanks. Gets me every time... changed the code to this. Changes marked (and it works):
PUB print(c) | i, k case c $20..$7E: '<<< changed from $00..$FF k := color << 1 + c & 1 i := k << 10 + $200 + c & $FE screen[row * cols + col] := i screen[(row + 1) * cols + col] := i | 1 if ++col == cols newline $100: 'clear screen? wordfill(@screen, $200, screensize) col := row := 0 $108: 'backspace? if col col-- $00D: '<<<< changed from $10D newline 'return? $110..$11F: 'select color? color := c & $FI don't quite understand this. Can you explain it in a different way?
DAT message byte "This is a test", $0D byte "This is line 2", 0Effectively, in order to keep the display switched on, you have to keep cog A alive.
A I'm aware it's conditional but given the described behaviour it's most likely active.
Does it have to be done this way?
Thanks for the suggestion. That works for now.
Thanks for your help.
Don
run through this method:
PUB print(c) | i, k case c $20..$7E: '<<< changed from $00..$FF k := color << 1 + c & 1 i := k << 10 + $200 + c & $FE screen[row * cols + col] := i screen[(row + 1) * cols + col] := i | 1 if ++col == cols newline $100: 'clear screen? wordfill(@screen, $200, screensize) col := row := 0 $108: 'backspace? if col col-- $00D: '<<<< changed from $10D newline 'return? $110..$11F: 'select color? color := c & $Fsomehow equates to a color from this:
DAT message byte "This is a test", 13 byte "This is line 2", 0 vgacolors long long $00000000 'black red is C000C000 '<<<<< changed this to get black background long $C0C0C0C0 ' red was $C0C00000 long $08A808A8 'green long $0808A8A8 long $50005000 'blue long $50500000 long $FC00FC00 'white long $FCFC0000 long $FF80FF80 'red/white long $FFFF8080 long $FF20FF20 'green/white long $FFFF2020 long $FF28FF28 'cyan/white long $FFFF2828 long $00A800A8 'grey/black long $0000A8A8 long $C0408080 'redbox spcl long $30100020 'greenbox long $3C142828 'cyanbox long $FC54A8A8 'greybox long $3C14FF28 'cyanbox+underscore long 0I have found the little program that Ray has on his website to configure the longs in the dat table for specific colors but I don't understand how they are referenced by the code above.
Well, the parameter is $113 which will trigger
$110..$11F: 'select color? color := c & $Fin the case statement ($113 is within $110..$11F). The code will extract a 3 ($113 & $00F) from the parameter and therefore select color 3 for subsequent output.$20..$7E: '<<< changed from $00..$FF k := [COLOR="#FF0000"]color[/COLOR] << 1 + c & 1 i := k << 10 + $200 + c & $FE screen[row * cols + col] := i screen[(row + 1) * cols + col] := i | 1 if ++col == cols newlineYou'll see the color variable being used to construct the word value written into the character buffer (screen[]). The VGA driver knows about the palette (see start method, lcd_colorbase) and internally selects the right colour during the display loop.Given that the selectable colour is in the range of 0..15 it suggests long indices into the colour table.
long $FF80FF80 'red/white long $FFFF8080The structure is dictated by the way the ROM font is encoded and stored. Even characters require an FBFB palette entry (Forground/Background), odd characters FFBB. So for red on black you'd need $C000C000 for the first entry and C0C00000 for the second. Put them into e.g. slot 0 and 1 then select colour $110 (slots are colour*2 + 0 and colour*2 + 1).Ok now that helps a ton. I tried what you mentioned and my table looks like this:
DAT message byte "This is a test", 13 byte "This is line 2", 0 vgacolors long long $C000C000 'black red is C000C000 '<<<<< changed this to get black background long $C0C00000 ' red was $C0C00000 long $08A808A8 'green long $0808A8A8 long $50005000 'blue long $50500000 long $FC00FC00 'white long $FCFC0000 long $FF80FF80 'red/white long $FFFF8080 long $FF20FF20 'green/white long $FFFF2020 long $FF28FF28 'cyan/white long $FFFF2828 long $00A800A8 'grey/black long $0000A8A8 long $C0408080 'redboxthe characters are red on black background but there is a funky background all around it. I don't know where that comes from. If I can get this figured out then I should have enough to get along on my own.
Here's what it looks like:
Thanks again.
Don
