NXT 2.0 or Parallax BoeBot - Page 5 — Parallax Forums
1235»
    edited 2012-11-26 18:00
    Legos melt from a fire like that, but the BoeBot's beautiful aluminum chassis is forever.
    Keep it. Love it. Learn all it can teach you! :)
  • hapaluahapalua Posts: 149
    edited 2012-11-26 18:01
    Im thinking about it
    edited 2012-11-27 00:57
    Good, keep thinkin' 'bout it. All Real roboticists cut their teeth on a BoeBot. Still looks good on your shelf (and robotics resume) years later. And it's nice to have a common chassis with all the other fans here to share code. We make our own challenges & contests for kicks & giggles.
    http://forums.parallax.com/showthread.php?138125-Erco-s-Figure-Eight-Challenge
    edited 2012-11-27 17:33
    Whats up gang?
    edited 2012-11-28 15:55
    anyone who has lego mindstorms wanna show me some videos?
    edited 2012-11-28 16:00
    My son and I built a new robot last week. I can't post a video until the weekend, but I might be able to on Saturday.
    edited 2012-11-28 16:03
    Cool! Cant wait to see the robot!
    edited 2012-11-28 16:04
    Google Lego Mindstorm and you will find TONS of videos.
    edited 2012-11-28 16:07
    I bet! Anyone ever watch that tv show Small Wonder back in the day?
    edited 2012-12-09 14:55
    LEGO RIS 2.0 or NXT 2.0? Which is the better robot kit? Also has anyone heard of a successor to the NXT 2.0?
    Thanks!
  • KB3JJGKB3JJG Posts: 95
    edited 2012-12-09 15:30
    the RIS was the first programmable lego kit, the NXT line was it's sucessor, we are on the second iteration of the NXT line, 2.0. As far as the next NXT kit, that is several years off so don't hold your breath, you don't need more power than the NXT brick provides to read sensors and move motors hence there is ZERO reason to upgrade it. I have the NXT 2.0 kit as well as tons of extra parts I bought off ebay. I bought it to get my kids into robotics, they are 7 and 5 and it is great. Once you figure out how to program in the NXT interface, you can branch out and work with the NXT hardware in a number of different programming languages.
    edited 2012-12-11 17:00
    What kind of ,extra, parts did you get off of ebay?
    edited 2012-12-14 17:36
    Gears, trusses, extra wires you name it, here is a project my son and I did, a vertical marble pump. It is still built, I will make a video of it in action this weekend.
    960 x 541 - 67K
    edited 2012-12-14 19:47
    @erco,
    That's the first & only Mindstorms I ever bought. I then got hooked on PARALLAX stuff!
    Anyone know where I can sell my Mindstorms kit besides amazon.com? :)
    EBAY!
    you should try it and use EBAY!
    other pople do....
    Enjoy!
  • NWCCTVNWCCTV Posts: 3,629
    edited 2012-12-14 19:51
    It looks like hapalua needs one!!!!!
    edited 2012-12-15 12:04
    Yes I need one haha!
    edited 2012-12-15 18:46
    Im going to try to get that LEGO RIS 2.0 back . I still miss it! =( Even if it is less powerful than the NXT 2.0.
    edited 2012-12-15 18:54
    Does anyone else have a LEGO NXT and like to share information about it?
    edited 2012-12-17 14:25
    Okay... Who here thinks I am being lazy about the boe bot and creating a robot arm and all that... Should I put the NXT 2.0 on hold and continue working with the boe bot and whats a microcontroller kit
    and see if I can build a robotic arm that plays chess from scratch?
    edited 2012-12-17 14:48
    Yes, yes, and by all means! :)
    edited 2012-12-17 15:43
    However there is one more problem! I dont have a machine mill or work shop tools to build robots out of metal. Can I use foam or wood?
    edited 2012-12-17 17:16
    Yes, yes and by all means! :smile: Foam, wood (plywood), metal, tubing, plastic, etc., etc. Not all robots are metal.
    A BOEbot in the hand is worth some blocks in the bush! (well, you get the idea!)
    edited 2012-12-17 19:56
    Don't forget Popsicle sticks.
    edited 2012-12-17 21:22
    Sweet! I had forgotten about Duane's popsicle stick robot. I can't find it now, but there's a simple walker made of freebie paint stir sticks on LMR, IIRC. Exotic materials and a machine shop are fun, but not required, hapalua. Time to get crackin'!
    edited 2012-12-17 22:24
    ....so grab a big bag of Popsicles and watch your excuses melt away!!!!
    (come on guys, you didn't expect me to let that one just sit there???)
    edited 2012-12-18 09:28
    That was exactly the reason for making the popsicle stick robot. To show you don't need a lot of expensive tools or supplies to build a robot, not even a relatively complex one like a hexapod.
    I still plan to rebuild the popsicle stick robot but with beefier servos. I concidered using shorter pieces of stick for the joints but then it wouldn't really be a popsicle stick would it? Besides, I've used the servos from my first one in the frame Paul K. gave me.
    edited 2012-12-18 10:19
    Did we mention Plywood ??? It's not if you have the best equipment in the game, just show up and play!!
    Now, it has a ping pong ball attached to the back end with some cable ties....build cost did increase a bit! :lol:
    edited 2012-12-26 18:55
    So I am in the process of building a robot arm utilizing the two servos from the boe bot kit and one servo from whats a micro controller kit. Is it possible to make this chess playing arm
    using the PBASIC code? or do i have to use a programming language like JAVA?
    edited 2012-12-26 18:56
    Ooops I should start a new thread on building a chess arm . Sorry people!
