Is there a reason you dont see 3 wheel drive bots?
So in yet another idea to get more power in sand and rid my bot of a caster I started thinking why not use a matching third wheel set up on a stepper/servo for rubber motion which can turn in sync with the differential drive and then put a gear motor and hbridge on that wheel also..
Searching for 3wd robots only turned up omni designs
If you're wanting to go in sand you could use a 4WD. Each side can run off the same motor, or you can use four motors, if they're small and cheap enough. Here's the general idea usign small servos:
http://www.budgetrobotics.com/item/4WD-Base-Chassis-233
Both 4WD and 6WD chassis are the preferred method for travelling over loose earth. They even beat out tracked, because the sand gets into the mechanism much more readily.
-- Gordon
Apparently NASA thinks they work for traveling over loose mars as well.
Less bad joking and more hall-hacking, Duane!
