PropBasic - shiftin/shiftout "speed" parm 5 - definition requested — Parallax Forums
pmrobertpmrobert Posts: 678
edited 2012-11-27 08:25 in Propeller 1
In a statement "shiftout spi_tx, spi_clk, msbfirst, %11101\5, so_speed" I can plug values into so_speed and increasing numbers definitely speed up the SPI transaction in an ascending manner to a certain point where the MCP3208 ADC chip doesn't respond. I'm not particularly fluent in PASM and see that changing that fifth parameter changes a couple of waitcnts in the emitted code. I've searched far and wide but am unable to find a definitive description of what unit this parameter is in. I can use up to 33 in a cog mode code task and 5 in the same task but running LMM mode; this matches Bean's statement elsewhere that LMM is 5-6 times slower than the equivalent cog mode code. Can anyone help me?
-Mike
    edited 2012-11-25 16:39
    Until someone comes up with a number (I'd assume baud but this doesn't seem to fit), can you post the emitted code? Should be easy to figure out.
    Then again, it could be table driven, 0 meaning lowest speed and going up from there.
  • pmrobertpmrobert Posts: 678
    edited 2012-11-25 17:22
    Here's the emitted code with a value of 33 dec:
    PUB Init(pv_DataStart, pv_VP_Watch)
      _Fixup(pv_DataStart, pv_VP_Watch)
      Return ((pv_DataStart >> 2) << 18) + ((@__INIT >> 2) << 4)
    DAT
      ORG 0
    __INIT
                      mov           dira,__InitDirA
                      mov           outa,__InitOutA
        ''        **      SPI INTERFACE DETAIL       **
    ' SPI_CS0				PIN 0		HIGH		' SPI Chip Select - MCP3208 - 12 bit, 8 channel ADC 0 'SPI_CS0				PIN 0		HIGH		' SPI Chip Select - MCP3208 - 12 bit, 8 channel ADC 0
    ' SPI_CS1				PIN 1		HIGH		' SPI Chip Select - MCP3208 - 12 bit, 8 channel ADC 1 'SPI_CS1				PIN 1		HIGH		' SPI Chip Select - MCP3208 - 12 bit, 8 channel ADC 1
    ' SPI_CS2				PIN 2		HIGH		' SPI Chip Select - MCP3208 - 12 bit, 8 channel ADC 2 'SPI_CS2				PIN 2		HIGH		' SPI Chip Select - MCP3208 - 12 bit, 8 channel ADC 2
    ' SPI_TX				PIN 3		LOW		' SPI master out serial in to slave - TX 'SPI_TX				PIN 3		LOW		' SPI master out serial in to slave - TX
    ' SPI_RX				PIN 4		INPUT	' SPI master in serial out from slave - RX 'SPI_RX				PIN 4		INPUT	' SPI master in serial out from slave - RX
    ' SPI_CLK				PIN 5		LOW		' SPI clock from master to all slaves 'SPI_CLK				PIN 5		LOW		' SPI clock from master to all slaves
        '' ADC0 Details
        '' MAP			ADC0.0
        '' IAT			ADC0.1 - Post turbo
        '' CLT			ADC0.2
        '' BARO		ADC0.3
        '' O2			ADC0.4
        '' TPS			ADC0.5
        '' EGT			ADC0.6
        '' IAT2		ADC0.7 - Pre turbo
        '' ADC1 Details
        '' ADC1.0
        '' ADC1.1
        '' ADC1.2
        '' ADC1.3
        '' ADC1.4
        '' ADC1.5
        '' ADC1.6
        '' ADC1.7
        '' ADC2 Details
        '' ADC2.0
        '' ADC2.1
        '' ADC2.2
        '' ADC2.3
        '' ADC2.4
        '' ADC2.5
        '' ADC2.6
        '' ADC2.7
        ''        **    SPI INTERFACE DETAIL END  **
    ' 	  chan var long                                           '	  chan var long
    ' 		adcchip var long                                         '		adcchip var long
    ' 		adchubvar var long                                       '		adchubvar var long
    ' 		adc_cnt var long                                         '		adc_cnt var long
    ' 		c1 var long                                              '		c1 var long
    ' 		c2 var long                                              '		c2 var long
    ' 		so_speed con 33 ' cog only, non-LMM max speed, 2881 Hz, 347 usec '		so_speed con 33 ' cog only, non-LMM max speed, 2881 Hz, 347 usec
        '		'so_speed con 5   ' LMM max speed, 474 Hz, 2108 usec
    __DO_5                                                       '		do
                      mov           c1,cnt                       '		c1 = cnt
                      mov           adcchip,#0                   '		for adcchip = 0 to 2
    __FOR_adcchip_11
                      mov           chan,#0                      '			for chan = 0 to 7
    __FOR_chan_12
                      cmps          adcchip,#0 WZ, WC            '				if adcchip = 0 then
        IF_NE         jmp           #__ELSE_24
                      or            dira,SPI_CS0                 '					high spi_cs0
                      or            outa,SPI_CS0
                      or            dira,SPI_CS0                 '					low spi_cs0
                      andn          outa,SPI_CS0
                      jmp           #__ENDIF_24                  '				elseif adcchip = 1 then
    __ELSE_24
                      cmps          adcchip,#1 WZ, WC
        IF_NE         jmp           #__ELSE_25
                      or            dira,SPI_CS1                 '					high spi_cs1
                      or            outa,SPI_CS1
                      or            dira,SPI_CS1                 '					low spi_cs1
                      andn          outa,SPI_CS1
                      jmp           #__ENDIF_24                  '				elseif adcchip = 2 then
    __ELSE_25
                      cmps          adcchip,#2 WZ, WC
        IF_NE         jmp           #__ELSE_26
                      or            dira,SPI_CS2                 '					high spi_cs2
                      or            outa,SPI_CS2
                      or            dira,SPI_CS2                 '					low spi_cs2
                      andn          outa,SPI_CS2
    __ELSE_26                                                    '				endif
    __ENDIF_24
                      mov           adchubvar,#0                 '				adchubvar = 0
                      mov           adchubvar,adcchip            '				adchubvar = adcchip * 8
                      shl           adchubvar,#3
        '				adchubvar = adchubvar + chan
                      adds          adchubvar,chan
                      cmps          chan,#0 WZ, WC               '				if chan = 0 then
        IF_NE         jmp           #__ELSE_27
                      mov           __temp1,SPI_TX               '					shiftout spi_tx, spi_clk, msbfirst, %11000\5, so_speed
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#24
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0029
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      djnz          __temp4,#__L0029
                      jmp           #__ENDIF_27                  '				elseif chan = 1 then
    __ELSE_27
                      cmps          chan,#1 WZ, WC
        IF_NE         jmp           #__ELSE_28
                      mov           __temp1,SPI_TX               '					shiftout spi_tx, spi_clk, msbfirst, %11001\5, so_speed
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#25
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0030
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      djnz          __temp4,#__L0030
                      jmp           #__ENDIF_27                  '				elseif chan = 2 then
    __ELSE_28
                      cmps          chan,#2 WZ, WC
        IF_NE         jmp           #__ELSE_29
                      mov           __temp1,SPI_TX               '					shiftout spi_tx, spi_clk, msbfirst, %11010\5, so_speed
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#26
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0031
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      djnz          __temp4,#__L0031
                      jmp           #__ENDIF_27                  '				elseif chan = 3 then
    __ELSE_29
                      cmps          chan,#3 WZ, WC
        IF_NE         jmp           #__ELSE_30
                      mov           __temp1,SPI_TX               '					shiftout spi_tx, spi_clk, msbfirst, %11011\5, so_speed
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#27
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0032
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      djnz          __temp4,#__L0032
                      jmp           #__ENDIF_27                  '				elseif chan = 4 then
    __ELSE_30
                      cmps          chan,#4 WZ, WC
        IF_NE         jmp           #__ELSE_31
                      mov           __temp1,SPI_TX               '					shiftout spi_tx, spi_clk, msbfirst, %11100\5, so_speed
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#28
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0033
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      djnz          __temp4,#__L0033
                      jmp           #__ENDIF_27                  '				elseif chan = 5 then
    __ELSE_31
                      cmps          chan,#5 WZ, WC
        IF_NE         jmp           #__ELSE_32
                      mov           __temp1,SPI_TX               '					shiftout spi_tx, spi_clk, msbfirst, %11101\5, so_speed
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#29
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0034
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      djnz          __temp4,#__L0034
                      jmp           #__ENDIF_27                  '				elseif chan = 6 then
    __ELSE_32
                      cmps          chan,#6 WZ, WC
        IF_NE         jmp           #__ELSE_33
                      mov           __temp1,SPI_TX               '					shiftout spi_tx, spi_clk, msbfirst, %11110\5, so_speed
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#30
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0035
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      djnz          __temp4,#__L0035
                      jmp           #__ENDIF_27                  '				elseif chan = 7 then
    __ELSE_33
                      cmps          chan,#7 WZ, WC
        IF_NE         jmp           #__ELSE_34
                      mov           __temp1,SPI_TX               '					shiftout spi_tx, spi_clk, msbfirst, %11111\5, so_speed
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#31
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0036
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      djnz          __temp4,#__L0036
        '				'elseif chan = 8 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %10000\5, so_speed	'Diff - 0=+, 1=-
        '				'elseif chan = 9 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %10001\5, so_speed	'Diff - 0=-, 1=+
        '				'elseif chan = 10 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %10010\5, so_speed	'Diff - 2=+, 3=-
        '				'elseif chan = 11 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %10011\5, so_speed	'Diff - 2=-, 3=+
        '				'elseif chan = 12 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %10100\5, so_speed	'Diff - 4=+, 5=-
        '				'elseif chan = 13 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %10101\5, so_speed	'Diff - 4=-, 5=+
        '				'elseif chan = 14 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %10110\5, so_speed	'Diff - 6=+, 7=-
        '				'elseif chan = 15 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %10111\5, so_speed	'Diff - 6=-, 7=+
    __ELSE_34                                                    '				endif
    __ENDIF_27
                      mov           __temp1,SPI_RX               '				shiftin spi_rx, spi_clk, msbpost, adc_cnt\13, so_speed
                      andn          dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#0
                      mov           __temp4,#13
                      mov           __temp5,cnt
                      add           __temp5,#24
    __L0037
                      xor           outa,__temp2
                      waitcnt       __temp5,#24
                      xor           outa,__temp2
                      waitcnt       __temp5,#24
                      and           __temp1,ina NR, WC
                      rcl           __temp3,#1
                      djnz          __temp4,#__L0037
                      mov           adc_cnt,__temp3
                      or            dira,SPI_CLK                 '				low spi_clk
                      andn          outa,SPI_CLK
        '				'adc_cnt = spi_rx
                      mov           __temp1,adchubvar            '				wrlong adc(adchubvar), adc_cnt
                      shl           __temp1,#2
                      add           __temp1,__adc_adr
                      wrlong        adc_cnt,__temp1
                      adds          chan,#1                      '			next
                      cmps          chan,#7 WZ, WC
        IF_BE         jmp           #__FOR_chan_12
    __NEXT_chan_12
                      adds          adcchip,#1                   '		next
        IF_BE         jmp           #__FOR_adcchip_11
    __NEXT_adcchip_11
                      mov           c2,cnt                       '		c2 = cnt - c1
                      subs          c2,c1
                      wrlong        c2,__h_adc_loop_cnt_adr      '		wrlong h_adc_loop_cnt, c2
                      jmp           #__DO_5                      '		loop
    __LOOP_5
                      mov           __temp1,#0                   'ENDTASK
                      waitpne       __temp1,__temp1
    __InitDirA       LONG %00000000_00000000_00000000_00101111
    __InitOutA       LONG %00000000_00000000_00000000_00000111
    SPI_CS0          LONG 1 << 0
    SPI_CS1          LONG 1 << 1
    SPI_CS2          LONG 1 << 2
    SPI_TX           LONG 1 << 3
    SPI_RX           LONG 1 << 4
    SPI_CLK          LONG 1 << 5
    ____STRING_adr   LONG 0
    __clkfreq_adr    LONG 0
    __h_adc_loop_cnt_adr LONG 0
    __adc_adr        LONG 4
    __verpm_adr      LONG 100
    __veload_adr     LONG 180
    __ve_table_adr   LONG 260
    __ign_table_adr  LONG 1060
    __h_rpm_adr      LONG 1860
    __h_load_adr     LONG 1864
    __h_ve_interp_adr LONG 1868
    __h_ign_interp_adr LONG 1870
    __calc_us_h_adr  LONG 1872
    __ECUUP_adr      LONG 1876
    __VERSION_adr    LONG 1885
    __OOPS_adr       LONG 1943
    __CMD_LIST_adr   LONG 1966
    __REBOOTING_adr  LONG 2100
    __ADC_TXT_adr    LONG 2172
    __ADCL_TXT_adr   LONG 2205
    __ADC0_TXT_adr   LONG 2254
    __ADC1_TXT_adr   LONG 2263
    __ADC2_TXT_adr   LONG 2272
    __US_TXT_adr     LONG 2281
    __HZ_TXT_adr     LONG 2301
    __ULINE_TXT_adr  LONG 2308
    __VE_adr         LONG 2314
    __IGN_adr        LONG 2323
    __remainder
    __temp1          RES 1
    __temp2          RES 1
    __temp3          RES 1
    __temp4          RES 1
    __temp5          RES 1
    __param1         RES 1
    __param2         RES 1
    __param3         RES 1
    __param4         RES 1
    __paramcnt       RES 1
    chan             RES 1
    adcchip          RES 1
    adchubvar        RES 1
    adc_cnt          RES 1
    c1               RES 1
    c2               RES 1
    FIT 492
    CON
      LSBFIRST                         = 0
      MSBFIRST                         = 1
      MSBPRE                           = 0
      LSBPRE                           = 1
      MSBPOST                          = 2
      LSBPOST                          = 3
      HOME                             = 1
      GOTOXY                           = 2
      CRSRLF                           = 3
      CRSRRT                           = 4
      CRSRUP                           = 5
      CRSRN                            = 6
      BEEP                             = 7
      BKSP                             = 8
      TAB                              = 9
      LF                               = 10
      CLREOL                           = 11
      CLRDN                            = 12
      CR                               = 13
      GOTOX                            = 14
      GOTOY                            = 15
      CLS                              = 16
      so_speed                         = 33
    PUB _Fixup(pv_DataStart, pv_VP_Watch)
      __h_adc_loop_cnt_adr += pv_DataStart
      __adc_adr += pv_DataStart
      __verpm_adr += pv_DataStart
      __veload_adr += pv_DataStart
      __ve_table_adr += pv_DataStart
      __ign_table_adr += pv_DataStart
      __h_rpm_adr += pv_DataStart
      __h_load_adr += pv_DataStart
      __h_ve_interp_adr += pv_DataStart
      __h_ign_interp_adr += pv_DataStart
      __calc_us_h_adr += pv_DataStart
      __ECUUP_adr += pv_DataStart
      __VERSION_adr += pv_DataStart
      __OOPS_adr += pv_DataStart
      __CMD_LIST_adr += pv_DataStart
      __REBOOTING_adr += pv_DataStart
      __ADC_TXT_adr += pv_DataStart
      __ADCL_TXT_adr += pv_DataStart
      __ADC0_TXT_adr += pv_DataStart
      __ADC1_TXT_adr += pv_DataStart
      __ADC2_TXT_adr += pv_DataStart
      __US_TXT_adr += pv_DataStart
      __HZ_TXT_adr += pv_DataStart
      __ULINE_TXT_adr += pv_DataStart
      __VE_adr += pv_DataStart
      __IGN_adr += pv_DataStart
    and with value 5:
    DAT
      ORG 0
    __INIT
                      mov           dira,__InitDirA
                      mov           outa,__InitOutA
        '' ADC0 Details
        '' MAP			ADC0.0
        '' CLT			ADC0.2
        '' BARO		ADC0.3
        '' O2			ADC0.4
        '' TPS			ADC0.5
        '' EGT			ADC0.6
        '' ADC1 Details
        '' ADC1.0
        '' ADC1.1
        '' ADC1.2
        '' ADC1.3
        '' ADC1.4
        '' ADC1.5
        '' ADC1.6
        '' ADC1.7
        '' ADC2 Details
        '' ADC2.0
        '' ADC2.1
        '' ADC2.2
        '' ADC2.3
        '' ADC2.4
        '' ADC2.5
        '' ADC2.6
        '' ADC2.7
        '		'so_speed con 33 ' cog only, non-LMM max speed, 2881 Hz, 347 usec
    ' 		so_speed con 5   ' LMM max speed, 474 Hz, 2108 usec      '		so_speed con 5   ' LMM max speed, 474 Hz, 2108 usec
    __DO_5                                                       '		do
    __FOR_adcchip_11
    __FOR_chan_12
                      or            outa,SPI_CS0
                      andn          outa,SPI_CS0
    __ELSE_24
                      or            outa,SPI_CS1
                      andn          outa,SPI_CS1
    __ELSE_25
                      or            outa,SPI_CS2
                      andn          outa,SPI_CS2
    __ELSE_26                                                    '				endif
    __ENDIF_24
                      shl           adchubvar,#3
                      adds          adchubvar,chan
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#24
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#106
                      add           __temp5,cnt
    __L0029
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#106
                      xor           outa,__temp2
                      xor           outa,__temp2
    __ELSE_27
                      cmps          chan,#1 WZ, WC
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#25
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#106
                      add           __temp5,cnt
    __L0030
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      xor           outa,__temp2
                      xor           outa,__temp2
    __ELSE_28
                      cmps          chan,#2 WZ, WC
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#26
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#106
                      add           __temp5,cnt
    __L0031
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      xor           outa,__temp2
                      xor           outa,__temp2
    __ELSE_29
                      cmps          chan,#3 WZ, WC
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#27
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#106
                      add           __temp5,cnt
    __L0032
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      xor           outa,__temp2
                      xor           outa,__temp2
    __ELSE_30
                      cmps          chan,#4 WZ, WC
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#28
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#106
                      add           __temp5,cnt
    __L0033
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      xor           outa,__temp2
                      xor           outa,__temp2
    __ELSE_31
                      cmps          chan,#5 WZ, WC
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#29
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#106
                      add           __temp5,cnt
    __L0034
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      xor           outa,__temp2
                      xor           outa,__temp2
    __ELSE_32
                      cmps          chan,#6 WZ, WC
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#30
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#106
                      add           __temp5,cnt
    __L0035
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      xor           outa,__temp2
                      xor           outa,__temp2
    __ELSE_33
                      cmps          chan,#7 WZ, WC
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#31
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#106
                      add           __temp5,cnt
    __L0036
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      xor           outa,__temp2
                      xor           outa,__temp2
    __ELSE_34                                                    '				endif
    __ENDIF_27
                      andn          dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#0
                      mov           __temp4,#13
                      mov           __temp5,cnt
                      add           __temp5,#160
    __L0037
                      xor           outa,__temp2
                      waitcnt       __temp5,#160
                      xor           outa,__temp2
                      rcl           __temp3,#1
                      mov           adc_cnt,__temp3
                      andn          outa,SPI_CLK
        '				'adc_cnt = spi_rx
                      shl           __temp1,#2
                      adds          chan,#1                      '			next
                      cmps          chan,#7 WZ, WC
    __NEXT_chan_12
    __NEXT_adcchip_11
                      subs          c2,c1
                      jmp           #__DO_5                      '		loop
    __LOOP_5
    SPI_CS0          LONG 1 << 0
    SPI_CS1          LONG 1 << 1
    SPI_CS2          LONG 1 << 2
    SPI_TX           LONG 1 << 3
    SPI_RX           LONG 1 << 4
    SPI_CLK          LONG 1 << 5
    __adc_adr        LONG 4
    __VE_adr         LONG 2314
    __IGN_adr        LONG 2323
    __remainder
    __temp1          RES 1
    __temp2          RES 1
    __temp3          RES 1
    __temp4          RES 1
    __temp5          RES 1
    __param1         RES 1
    __param2         RES 1
    __param3         RES 1
    __param4         RES 1
    __paramcnt       RES 1
    chan             RES 1
    adcchip          RES 1
    adchubvar        RES 1
    adc_cnt          RES 1
    c1               RES 1
    c2               RES 1
    FIT 492
    CON
      LSBFIRST                         = 0
      MSBFIRST                         = 1
      MSBPRE                           = 0
      LSBPRE                           = 1
      MSBPOST                          = 2
      LSBPOST                          = 3
      HOME                             = 1
      GOTOXY                           = 2
      CRSRLF                           = 3
      CRSRRT                           = 4
      CRSRUP                           = 5
      CRSRN                            = 6
      BEEP                             = 7
      BKSP                             = 8
      TAB                              = 9
      LF                               = 10
      CLREOL                           = 11
      CLRDN                            = 12
      CR                               = 13
      GOTOX                            = 14
      GOTOY                            = 15
      CLS                              = 16
      so_speed                         = 5
    The PropBasic code is:
    ' TASK Code - ADC_LOOP
    TASK adc_loop
    ' ADC0 Details
    ' MAP			ADC0.0
    ' CLT			ADC0.2
    ' BARO		ADC0.3
    ' O2			ADC0.4
    ' TPS			ADC0.5
    ' EGT			ADC0.6
    ' ADC1 Details
    ' ADC1.0
    ' ADC1.1
    ' ADC1.2
    ' ADC1.3
    ' ADC1.4
    ' ADC1.5
    ' ADC1.6
    ' ADC1.7
    ' ADC2 Details
    ' ADC2.0
    ' ADC2.1
    ' ADC2.2
    ' ADC2.3
    ' ADC2.4
    ' ADC2.5
    ' ADC2.6
    ' ADC2.7
    	  chan var long
    		adcchip var long
    		adchubvar var long
    		adc_cnt var long
    		c1 var long
    		c2 var long
    		do
    		c1 = cnt
    			for chan = 0 to 7
    				if adcchip = 0 then
    					high spi_cs0
    					low spi_cs0
    					high spi_cs1
    					low spi_cs1
    					high spi_cs2
    					low spi_cs2
    				endif
    				adchubvar = 0
    				if chan = 0 then
    				endif
    				low spi_clk
    				'adc_cnt = spi_rx
    			next
    		next
    		c2 = cnt - c1
    		loop
    ENDTASK
    My scope, the timing measurements I've placed in there and, I think, the PASM code tells me it increases the SPI clock and data rate. I'm just curious what multiplier/divider this parm is in relation to what base. Hope that makes sense...
    Thank you -Mike
    edited 2012-11-25 17:50
    pmrobert wrote: »
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#24
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0029
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,[COLOR="#FF0000"]#20[/COLOR]
                      xor           outa,__temp2
                      xor           outa,__temp2
    This is the basic output loop. It uses (so_speed = 33) 3*20 cycles to transfer a single bit (the other example does the same in 3*106 cycles). I couldn't find any clock setup in the code, what speed are you running at? Also, could you produce those cycle numbers for some other speed values (just to have a few more data points)?
    edited 2012-11-25 18:21
    I'm running at 5x16, just a standard PPDB. With a value of so_speed=4 that waitcnt value is #133, if 8 then #66, if 16 then #33, if 32 then #20. I have since tightened that code up a bit so as not to have that convoluted "if..then" structure, I just want to be clear on what I'm presenting to you. That should not have made any difference, but....
    DAT
      ORG 0
    __INIT
                      mov           dira,__InitDirA
                      mov           outa,__InitOutA
        '' ADC0 Details
        '' MAP			ADC0.0
        '' CLT			ADC0.2 - Radiator In
        '' BARO		ADC0.3
        '' O2			ADC0.4
        '' TPS			ADC0.5
        '' EGT			ADC0.6 - Pre turbo
        '' ADC1 Details
        '' EGT2		ADC1.0 - Post turbo
        '' CLT2		ADC1.1 - Radiator Out
        '' OIL			ADC1.2 - Oil Cooler In
        '' OIL2		ADC1.3 - Oil Cooler Out
        '' KNK			ADC1.4 - Knock Sensor
        '' ACLZ		ADC1.5 - Accelerometer Z
        '' ACLX		ADC1.6 - Accelerometer X
        '' ACLY		ADC1.7 - Accelerometer Y
        '' ADC2 Details
        '' ADC2.0
        '' ADC2.1
        '' ADC2.2
        '' ADC2.3
        '' ADC2.4
        '' ADC2.5
        '' ADC2.6
        '' ADC2.7
    ' 		adc_cmd var long                                         '		adc_cmd var long
    ' 		so_speed con 32 ' cog only, non-LMM max speed, 2881 Hz, 347 usec '		so_speed con 32 ' cog only, non-LMM max speed, 2881 Hz, 347 usec
        '		'so_speed con 5   ' LMM max speed, 560 Hz, 1784 usec
    __DO_5                                                       '		do
    __FOR_adcchip_11
    __FOR_chan_12
                      or            outa,SPI_CS0
                      andn          outa,SPI_CS0
    __ELSE_24
                      or            outa,SPI_CS1
                      andn          outa,SPI_CS1
    __ELSE_25
                      or            outa,SPI_CS2
                      andn          outa,SPI_CS2
    __ELSE_26                                                    '				endif
    __ENDIF_24
                      shl           adchubvar,#3
                      adds          adchubvar,chan
                      mov           adc_cmd,chan                 '				adc_cmd = chan+%11000
                      adds          adc_cmd,#24
                      mov           __temp1,SPI_TX               '				shiftout spi_tx, spi_clk, msbfirst, adc_cmd\5, so_speed
                      or            dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,adc_cmd
                      mov           __temp4,#5
                      shl           __temp3,#27
                      mov           __temp5,#20
                      add           __temp5,cnt
    __L0029
                      shl           __temp3,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
                      xor           outa,__temp2
                      waitcnt       __temp5,#20
        '				'if chan = 0 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %11000\5, so_speed
        '				'elseif chan = 1 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %11001\5, so_speed
        '				'elseif chan = 2 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %11010\5, so_speed
        '				'elseif chan = 3 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %11011\5, so_speed
        '				'elseif chan = 4 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %11100\5, so_speed
        '				'elseif chan = 5 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %11101\5, so_speed
        '				'elseif chan = 6 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %11110\5, so_speed
        '				'elseif chan = 7 then
        '				'	shiftout spi_tx, spi_clk, msbfirst, %11111\5, so_speed
        '				'endif
                      andn          dira,__temp1
                      mov           __temp2,SPI_CLK
                      or            dira,__temp2
                      mov           __temp3,#0
                      mov           __temp4,#13
                      mov           __temp5,cnt
                      add           __temp5,#25
    __L0030
                      xor           outa,__temp2
                      waitcnt       __temp5,#25
                      xor           outa,__temp2
                      waitcnt       __temp5,#25
                      rcl           __temp3,#1
                      mov           adc_cnt,__temp3
                      andn          outa,SPI_CLK
        '				'adc_cnt = spi_rx
                      shl           __temp1,#2
                      adds          chan,#1                      '			next
                      cmps          chan,#7 WZ, WC
    __NEXT_chan_12
    __NEXT_adcchip_11
                      subs          c2,c1
                      jmp           #__DO_5                      '		loop
    __LOOP_5
    SPI_CS0          LONG 1 << 0
    SPI_CS1          LONG 1 << 1
    SPI_CS2          LONG 1 << 2
    SPI_TX           LONG 1 << 3
    SPI_RX           LONG 1 << 4
    SPI_CLK          LONG 1 << 5
    __adc_adr        LONG 4
    __VE_adr         LONG 2314
    __IGN_adr        LONG 2323
    __remainder
    __temp1          RES 1
    __temp2          RES 1
    __temp3          RES 1
    __temp4          RES 1
    __temp5          RES 1
    __param1         RES 1
    __param2         RES 1
    __param3         RES 1
    __param4         RES 1
    __paramcnt       RES 1
    chan             RES 1
    adcchip          RES 1
    adchubvar        RES 1
    adc_cnt          RES 1
    c1               RES 1
    c2               RES 1
    adc_cmd          RES 1
    FIT 492
    CON
      LSBFIRST                         = 0
      MSBFIRST                         = 1
      MSBPRE                           = 0
      LSBPRE                           = 1
      MSBPOST                          = 2
      LSBPOST                          = 3
      HOME                             = 1
      GOTOXY                           = 2
      CRSRLF                           = 3
      CRSRRT                           = 4
      CRSRUP                           = 5
      CRSRN                            = 6
      BEEP                             = 7
      BKSP                             = 8
      TAB                              = 9
      LF                               = 10
      CLREOL                           = 11
      CLRDN                            = 12
      CR                               = 13
      GOTOX                            = 14
      GOTOY                            = 15
      CLS                              = 16
      so_speed                         = 32
    TASK adc_loop
    ' ADC0 Details
    ' MAP			ADC0.0
    ' BARO		ADC0.3
    ' O2			ADC0.4
    ' TPS			ADC0.5
    ' ADC1 Details
    ' ADC2 Details
    ' ADC2.0
    ' ADC2.1
    ' ADC2.2
    ' ADC2.3
    ' ADC2.4
    ' ADC2.5
    ' ADC2.6
    ' ADC2.7
    	  chan var long
    		adcchip var long
    		adchubvar var long
    		adc_cnt var long
    		c1 var long
    		c2 var long
    		adc_cmd var long
    		do
    		c1 = cnt
    			for chan = 0 to 7
    				if adcchip = 0 then
    					high spi_cs0
    					low spi_cs0
    					high spi_cs1
    					low spi_cs1
    					high spi_cs2
    					low spi_cs2
    				endif
    				adchubvar = 0
    				'if chan = 0 then
    				'endif
    				low spi_clk
    				'adc_cnt = spi_rx
    			next
    		next
    		c2 = cnt - c1
    		loop
    ENDTASK
    edited 2012-11-25 18:32
    Here's something strange - with values of so_speed = 32 or 33 the waitcnt value is #20. However, so_speed=32 runs the loop in 344 usec, so_speed=33 runs it in 338 usec even though both have the waitcnt=#20 in the emitted code.
    edited 2012-11-25 19:03
    pmrobert wrote: »
    That's certainly odd. Is the generated code exactly the same?
    Anyway, I came up with a preliminary equation: baudrate = (clkfreq/1600)*speed. Note that this is clipped for n = 1 as we can only fit 511 into a literal parameter (533.3 required @80MHz). Other values are OK. Going towards higher numbers it's clipped as well (most likely in the code generator), 20 cycles seems to be the lower limit here (around speed = 26). HTH
    Note that this equation works for 80MHz, it reacts to changes (40MHz has half the cycle count) so there may be some work required in that department (too lazy to check, 50k*speed seems to fit the bill). But this should work for you.
    edited 2012-11-25 19:20
    I found the difference - the compiler seems to limit the generated value to <= #20 for shiftout. Shiftin on the other hand is generated with a slightly higher set of waitcnts (#23 vs #20) so that accounts for the observed speed difference. Thanks for your time, I hope Bean can weigh in on this. It's pretty much academic but I do like to understand what the code and chip are doing. I need to learn PASM!
    PS: My daughter was looking over my shoulder and said something about a black cat...
    Thanks again,
    -Mike
  • BeanBean Posts: 8,129
    edited 2012-11-26 04:22
    Mike, Yes there is a minimum limit to make sure the code can get through the loop before the next waitcnt instruction. If it doesn't it will hang until "cnt" wraps around (about 56 seconds).
    ShiftIn and ShiftOut have different instructions inside the loop, so the minimum is different for each of them.
    If I remember correctly the default speed is 100KHz and gets scaled from there until the minimum is hit. So speed "2" would be about 200KHz etc.
    Bean
    Bean, thanks for the info. That roughly matches what the scope shows. Kuroneko, thank you for your analysis as well. I'm heading off to teach myself PASM now :-)
    -Mike
