ELEV-8 Flight Simulators
Do any of you have suggestions on what simulator to use in order to learn to fly quadcopters?
I personally use RealFlight G4. It doesn't have any quadcopters but it does have helicopters. I think if one were to learn to fly helicopters, they could also fly quadcopters.
I like that RealFlight G4 allows me to use my regular remote with the simulator. I'd include being able to use your own remote an important feature in a simulator.
Anything else one should look for in a simulator?
I'm not personally looking for a simulator, I've been asked by several people for suggestions and I'd like to be better informed. I also think it would help those purchasing an ELEV-8 to know which simulator would help them learn to fly it.
I agree. I think using the 90 size helicopter is the best to learn on - unless a quad is available. If you can control it then you have learned what you need to.
If you do have a clicking throttle stick (usually TXs intended for airplanes click), it's easy to remove the offending part by opening the transmitter case up. The modification is reversable (in at least the transmitters I've looked inside).
You're right. It's been I while since I've looked inside a heli remote. The throttle will kind of flop around without something there.
