Having trouble getting Seiko RTC working on Propeller DNA board — Parallax Forums
Don MDon M Posts: 1,654
edited 2012-10-24 04:12 in Propeller 1
I have copied some of the code that Beau wrote for the Spinneret but can't seem to make it work. It just shows "Mon Jan 01, 2012 12:00:00 AM". Once it's started the clock counts up but I can't seem to set the time.
Here's my main code:
con
  _clkmode = xtal1 + pll16x
  _clkfreq = 80_000_000
  MS_001   = 80_000_000 / 1_000
obj
  term   : "fullduplexserialplusdecn"                   ' for terminal output
  clock  : "s-35390A_GBSbuild_02_09_2011"               ' Seiko RTC driver
var
  long  MM_DD_YYYY, DW_HH_MM_SS
  byte  dig2[2]
pub main  | d, l ,s
  term.start(31, 30, %0000, 115_200)                    ' start terminal (use PST)
  clock.start
  pause(1000)
  term.tx(0)
  term.str(@version)
  repeat
    d := term.rxcheck
    case d
      "c": SetClock
      "t": term.str(clock.FmtDateTime)
        term.tx(13)
pub SetClock
  Prompt(String("Enter year (2000-2099)"),true)
  MM_DD_YYYY[0] := getSerVal(4)
  Prompt(String("Enter month (01-12)"),true)
  MM_DD_YYYY[3] := getSerVal(2)
  Prompt(String("Enter date (01-31)"), true)
  MM_DD_YYYY[2] := getSerVal(2)
  Prompt(String("Enter day of week where 0=SUN 1=MON 2=TUE 3=WED 4=THU 5=FRI 6=SAT"), true)
  DW_HH_MM_SS[3] := getSerVal(1)
  Prompt(String("Enter hour 0-23 "),true)
  DW_HH_MM_SS[2] := getSerVal(2)
  Prompt(String("Enter minute (01-59)"),true)
  DW_HH_MM_SS[1] := getSerVal(2)
  DW_HH_MM_SS[0] := 0                                   ' Set seconds to 0
  clock.SetDateTime(byte[@MM_DD_YYYY][3],   { <- Month
                  } byte[@MM_DD_YYYY][2],   { <- Day
                  } word[@MM_DD_YYYY][0] - 2000,   { <- Year
                  } byte[@DW_HH_MM_SS][3],  { <- (day of week)
                  } byte[@DW_HH_MM_SS][2],  { <- Hour
                  } byte[@DW_HH_MM_SS][1],  { <- Minutes
                  } byte[@DW_HH_MM_SS][0])  { <- Seconds }
  term.tx(13)
pub getSerVal(lim) : value | bytesread, tmp, x, place
  term.RxFlush
  bytesread := 0
  value := 0
  place := 1
  repeat while bytesread < lim
    tmp := term.Rx
    if ((tmp == 10) OR (tmp ==13) OR (tmp == "*"))
      QUIT
    if (tmp => ("0")) and (tmp =< ("9"))
      dig2[bytesread] := tmp
      bytesread++
  repeat x from (bytesread - 1) to 0
    value := value + ((dig2[x]-"0") * place)
    place := place * 10
pub pause(ms) | t
  t := cnt
  repeat ms
    waitcnt(t += MS_001)
pri Prompt(msg, CR)
  term.str(msg)
  if CR
    term.tx(13)
dat
  version byte  "DNA Board Clock Play", 13, 0
Any help appreciated.
Don
    edited 2012-10-23 16:32
    MM_DD_YYYY is a single long, any index you add to it will be treated as a long index (even though MM_DD_YYYY is not explicitly declared as an array). IOW fred[3] will access the long from address @fred + 12. If you want to access the individual bytes you should use MM_DD_YYYY.byte[3].
    For the year (occupying 2 bytes) use MM_DD_YYYY.word[0] instead.
  • Don MDon M Posts: 1,654
    kuroneko wrote: »
    kuroneko- Thanks so much! As always you are a great help in learning this stuff.
    New code below:
    pub SetClock
      MM_DD_YYYY.word[0] := getSerVal(4)
      MM_DD_YYYY.byte[3] := getSerVal(2)
      MM_DD_YYYY.byte[2] := getSerVal(2)
      DW_HH_MM_SS.byte[3] := getSerVal(1)
      DW_HH_MM_SS.byte[2] := getSerVal(2)
      DW_HH_MM_SS.byte[1] := getSerVal(2)
      DW_HH_MM_SS.byte[0] := 0                                   ' Set seconds to 0
      term.tx(13)
      term.tx(13)
