Having trouble getting Seiko RTC working on Propeller DNA board
I have copied some of the code that Beau wrote for the Spinneret but can't seem to make it work. It just shows "Mon Jan 01, 2012 12:00:00 AM". Once it's started the clock counts up but I can't seem to set the time.
Here's my main code:
Any help appreciated.
Don
con
_clkmode = xtal1 + pll16x
_clkfreq = 80_000_000
MS_001 = 80_000_000 / 1_000
obj
term : "fullduplexserialplusdecn" ' for terminal output
clock : "s-35390A_GBSbuild_02_09_2011" ' Seiko RTC driver
var
long MM_DD_YYYY, DW_HH_MM_SS
byte dig2[2]
pub main | d, l ,s
term.start(31, 30, %0000, 115_200) ' start terminal (use PST)
clock.start
pause(1000)
term.tx(0)
term.str(@version)
repeat
d := term.rxcheck
case d
"c": SetClock
"t": term.str(clock.FmtDateTime)
term.tx(13)
pub SetClock
Prompt(String("Enter year (2000-2099)"),true)
MM_DD_YYYY[0] := getSerVal(4)
Prompt(String("Enter month (01-12)"),true)
MM_DD_YYYY[3] := getSerVal(2)
Prompt(String("Enter date (01-31)"), true)
MM_DD_YYYY[2] := getSerVal(2)
Prompt(String("Enter day of week where 0=SUN 1=MON 2=TUE 3=WED 4=THU 5=FRI 6=SAT"), true)
DW_HH_MM_SS[3] := getSerVal(1)
Prompt(String("Enter hour 0-23 "),true)
DW_HH_MM_SS[2] := getSerVal(2)
Prompt(String("Enter minute (01-59)"),true)
DW_HH_MM_SS[1] := getSerVal(2)
DW_HH_MM_SS[0] := 0 ' Set seconds to 0
clock.SetDateTime(byte[@MM_DD_YYYY][3], { <- Month
} byte[@MM_DD_YYYY][2], { <- Day
} word[@MM_DD_YYYY][0] - 2000, { <- Year
} byte[@DW_HH_MM_SS][3], { <- (day of week)
} byte[@DW_HH_MM_SS][2], { <- Hour
} byte[@DW_HH_MM_SS][1], { <- Minutes
} byte[@DW_HH_MM_SS][0]) { <- Seconds }
term.tx(13)
pub getSerVal(lim) : value | bytesread, tmp, x, place
term.RxFlush
bytesread := 0
value := 0
place := 1
repeat while bytesread < lim
tmp := term.Rx
if ((tmp == 10) OR (tmp ==13) OR (tmp == "*"))
QUIT
if (tmp => ("0")) and (tmp =< ("9"))
dig2[bytesread] := tmp
bytesread++
repeat x from (bytesread - 1) to 0
value := value + ((dig2[x]-"0") * place)
place := place * 10
pub pause(ms) | t
t := cnt
repeat ms
waitcnt(t += MS_001)
pri Prompt(msg, CR)
term.str(msg)
if CR
term.tx(13)
dat
version byte "DNA Board Clock Play", 13, 0
Don
For the year (occupying 2 bytes) use MM_DD_YYYY.word[0] instead.
kuroneko- Thanks so much! As always you are a great help in learning this stuff.
New code below:
pub SetClock Prompt(String("Enter year (2000-2099)"),true) MM_DD_YYYY.word[0] := getSerVal(4) Prompt(String("Enter month (01-12)"),true) MM_DD_YYYY.byte[3] := getSerVal(2) Prompt(String("Enter date (01-31)"), true) MM_DD_YYYY.byte[2] := getSerVal(2) Prompt(String("Enter day of week where 0=SUN 1=MON 2=TUE 3=WED 4=THU 5=FRI 6=SAT"), true) DW_HH_MM_SS.byte[3] := getSerVal(1) Prompt(String("Enter hour 0-23 "),true) DW_HH_MM_SS.byte[2] := getSerVal(2) Prompt(String("Enter minute (01-59)"),true) DW_HH_MM_SS.byte[1] := getSerVal(2) DW_HH_MM_SS.byte[0] := 0 ' Set seconds to 0 clock.SetDateTime(byte[@MM_DD_YYYY][3], { <- Month } byte[@MM_DD_YYYY][2], { <- Day } word[@MM_DD_YYYY][0] - 2000, { <- Year } byte[@DW_HH_MM_SS][3], { <- (day of week) } byte[@DW_HH_MM_SS][2], { <- Hour } byte[@DW_HH_MM_SS][1], { <- Minutes } byte[@DW_HH_MM_SS][0]) { <- Seconds } term.tx(13) term.str(clock.FmtDateTime) term.tx(13)
