Help with repeat loops and if else statements — Parallax Forums
Don MDon M Posts: 1,654
edited 2012-10-04 23:31 in Propeller 1
I am trying to parse some data from a dat data file. I have one method I wrote (included in the archive) that will parse the data using specific case statements. It is a long program and will only respond to specific addresses within the data. What I was trying to do was parse through the data without using specific addresses. I'm thinking this should be possible but am having trouble understanding the "quit" or "next" command trying to get out of a loop and back into the main repeat loop.
Anywhere you see the "quit" directive is where I want to go back to the Main repeat loop.
pub testing2 | chk, d, t, h
  i         := 0
  n         := 0
  chksum    := 0
  term.tx(13)                                           ' Move down 1 line
  repeat  i from 0 to 127                               ' Main loop. Cycle through xxx words from dat section
    if (data[i] & $0F00) == $0100                       ' Check for Command and Slave ACK
      if data[i] == $0100                               ' Slave ACK found
        term.hex(data[i], 3)                            ' Print Slave ACK
        i++                                             ' Increment index
        if data[i] == $0000                             ' Check for Master ACK
          term.tx(58)                                   ' Master ACK found print colon
          term.hex(data[i], 3)                          ' Print Master ACK
          quit                                          ' Need to quit to main repeat loop
        else                                            ' If no Master ACK such as in Slave reset
          i--                                           ' Decrement index
          term.tx(13)                                   ' Print carriage return
      term.hex(data[i], 3)                              ' Print Master command
      term.tx(32)                                       ' Print space
      repeat                                            ' Repeat to look for rest of Master command
        chksum += data[i]                               ' Add word to checksum
        n++                                             ' Increment N counter
        if data[i] ==(chksum & $00FF)                   ' Check for Command checksum
          repeat n                                      ' Print N times
            term.hex(data[i], 3)                        ' Print checksum
          term.tx(58)                                   ' Print colon
          chksum := $0000                               ' Clear checksum
          n := 0                                        ' Reset N counter
        else                                            ' If checksum does not match data
          if data[i] == $000                            ' Check for Master ACK was printed so print
            term.tx(13)                                 ' Master ACK was printed so print carriage return
    repeat                                              ' Collecting additional data from Master
      if (data[i] & $00FF) ==chksum                     ' Looking for checksum match
        i := i - n                                      ' Preset index counter
        if data[i] == $0100                             ' Look for Slave ACK
          term.hex(data[i], 3)                          ' Print data from Slave such as from Reader Just Reset
        repeat n + 1                                    ' Repeat printing of data N + 1 times
          term.hex(data[i], 3)                          ' Print Slave data
If you download the zipped file and run the other method it will print on PST the way I'm trying to get this piece of code to work. I've spent a great number of hours (days) trying to make my way through this...
Any help greatly appreciated.
Edit: Added this dat data section for viewing. It is included in zip file.
dat
version byte  "Parse_Playground5", 13, 0
data    word  $0110, $0010, $0100, $0108, $0008, $0100, $0130, $0030, $0100, $0112, $0012, $0000, $0100, $0000, $0133, $0033
        word  $0006, $0009, $010F, $0000, $0111, $0000, $0003, $0010, $0001, $0001, $0026, $0100, $010B, $000B, $000B, $010B
        word  $0000, $0131, $0031, $0001, $0000, $0001, $0000, $0064, $0002, $0000, $00C8, $0000, $0000, $00FF, $0001, $0002
        word  $0005, $000A, $0014, $00FF, $0000, $0000, $0154, $0000, $0112, $0012, $0001, $0001, $0000, $0001, $0001, $0002
        word  $0030, $000D, $0143, $0000, $0109, $0009, $0003, $0000, $0001, $0005, $0002, $0000, $000F, $0001, $0002, $0005
        word  $0014, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0136, $0000, $0137
        word  $0000, $0037, $004D, $0045, $0049, $0030, $0035, $0030, $0031, $0039, $0030, $0037, $0039, $0035, $0034, $0031
        word  $0037, $0056, $004E, $0032, $0037, $0030, $0030, $0020, $0055, $0053, $0020, $0020, $0020, $0012, $0020, $0112
        word  $0000, $0117, $0000, $0056, $0045, $0045, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030
        word  $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0031, $0032
        word  $00DA, $0100, $010A, $000A, $0000, $0000, $0015, $0018, $001F, $0000, $0000, $0000, $0000, $0000, $0000, $0000
        word  $0000, $0000, $0000, $0000, $0000, $0000, $014C, $0000, $0136, $0036, $0000, $0000, $0100, $0000, $0112, $0012
        word  $0009, $0055, $0053, $0041, $0045, $0045, $0031, $0030, $0030, $0030, $0033, $0037, $0039, $0030, $0036, $002E
        word  $0045, $0070, $006F, $0072, $0074, $0020, $0045, $0064, $0067, $0065, $0020, $0020, $0030, $0030, $01B3, $0000
        word  $010C, $0000, $00FF, $0000, $00FF, $000A, $0100, $0134, $0000, $000F, $0000, $000F, $0052, $0100, $0111, $0001
        word  $0001, $0077, $0000, $0032, $00BC, $0100, $010B, $000B, $0100, $0133, $0033, $0100, $0114, $0001, $0015, $0100
  • SRLMSRLM Posts: 5,045
    edited 2012-10-04 09:05
    So, you basically want the output on multiple lines instead of the one line?
    On lines 77 and 81, I don't think you want to have quit since that will break out of the main loop (and go to the next statement, in this case an implied return from function).
    On lines 95 and 101, I don't think you want to have quit on both. Every time through the loop (the plain "repeat" loop) one or the other of the if or else statements will be run. Putting quit in both means the loop only runs once.
  • Don MDon M Posts: 1,654
    edited 2012-10-04 09:26
    SRLM wrote: »
    That's correct. Each Master string with Slave response and Master ACK on their own line. If you try the other method in the zip archive called "testing" you will see the format of what I'm looking for on PST.
    SRLM wrote: »
    On lines 77 and 81, I don't think you want to have quit since that will break out of the main loop (and go to the next statement, in this case an implied return from function). On lines 95 and 101, I don't think you want to have quit on both. Every time through the loop (the plain "repeat" loop) one or the other of the if or else statements will be run. Putting quit in both means the loop only runs once.
    Tried taking out the quit statements on lines 77, 81 & 95 as you suggest here but still doesn't work....
    edited 2012-10-04 09:34
    SRLM wrote: »
    Here's a screen shot of how it should look:
    SRLM wrote: »
    After making your suggested changes here is what I get:
    1024 x 751 - 62K
    1024 x 369 - 71K
  • JonnyMacJonnyMac Posts: 9,836
    edited 2012-10-04 10:39
    I think the problem you're having, Don, is that you're using a repeat from x to y loop an and then messing with the index inside the loop. You might simply setting the index to a starting address and accounting for a maximum index; then let the mechanics of the loop take care of the indexing. You could change the top of the loop to repeat while idx =< MAX_IDX.
    Here's an example of how you can display a block of data by passing the address of the block and the number of entries in it.
    pub display(addr, entries) | idx, tval
      idx := 0
      repeat while (idx < entries)
        tval := word[addr + (idx++ << 1)]
        if (tval <> $0100)
          term.hex(tval, 3)
          term.tx(" ")
        else
          term.tx(":")
          term.tx(" ")
          term.hex(tval, 3)
          term.tx(CR)
          term.tx(CR)
    edited 2012-10-04 18:37
    Jon- some interesting code example there. It took me a little bit to figure out how it worked itself but to be quite honest I don't know how I would work it into the main loop.
    This somewhat simple looking project has kicked my @@s. I have spent hours going through the loops by hand trying to understand how the data is handled through them and I just can't figure it out. It's confusing to me to understand how the quit (and next) work to exit the loops in an orderly fashion. I can get it to somewhat work but when I start to tweak it it falls apart.
    I'm willing to pay someone to help me out with this at this point. Anyone interested?
    Don
    Don I'm not sure I understand exactly what you are trying to do here but it seems like a case statement without any exits would accomplish what you want.
      i         := 0
      n         := 0
      chksum    := 0
      term.tx(13)
        case (data[i] and $0F00)
          $0100:                                             ' Slave ACK found        if data[i] == $0100                               ' Slave ACK found
    '        i++                                            ' NO. DONT MESS WITH THE INDEX
          $0000:                                             ' If it is Master ACK
          other                                              ' If no Master ACK such as in Slave reset
    '          i--                                          ' NO. DONT MESS WITH THE INDEX
            ` Term.tx(13)                                   ' Print carriage return
    '       repeat                                            ' NO NEED FOR REPEAT
    '        i++                                             ' NO. DONT MESS WITH INDEX
        case (data[i] ==(chksum & $00FF)                   ' Check for Command checksum
    In other words the case statements would exit to your repeat loop without quit statements since each case is only executed if it is true.
