Help with repeat loops and if else statements
I am trying to parse some data from a dat data file. I have one method I wrote (included in the archive) that will parse the data using specific case statements. It is a long program and will only respond to specific addresses within the data. What I was trying to do was parse through the data without using specific addresses. I'm thinking this should be possible but am having trouble understanding the "quit" or "next" command trying to get out of a loop and back into the main repeat loop.
Anywhere you see the "quit" directive is where I want to go back to the Main repeat loop.
If you download the zipped file and run the other method it will print on PST the way I'm trying to get this piece of code to work. I've spent a great number of hours (days) trying to make my way through this...
Any help greatly appreciated.
Edit: Added this dat data section for viewing. It is included in zip file.
pub testing2 | chk, d, t, h
i := 0
n := 0
chksum := 0
term.tx(13) ' Move down 1 line
repeat i from 0 to 127 ' Main loop. Cycle through xxx words from dat section
if (data[i] & $0F00) == $0100 ' Check for Command and Slave ACK
if data[i] == $0100 ' Slave ACK found
term.hex(data[i], 3) ' Print Slave ACK
i++ ' Increment index
if data[i] == $0000 ' Check for Master ACK
term.tx(58) ' Master ACK found print colon
term.hex(data[i], 3) ' Print Master ACK
quit ' Need to quit to main repeat loop
else ' If no Master ACK such as in Slave reset
i-- ' Decrement index
term.tx(13) ' Print carriage return
term.hex(data[i], 3) ' Print Master command
term.tx(32) ' Print space
repeat ' Repeat to look for rest of Master command
chksum += data[i] ' Add word to checksum
n++ ' Increment N counter
if data[i] ==(chksum & $00FF) ' Check for Command checksum
repeat n ' Print N times
term.hex(data[i], 3) ' Print checksum
term.tx(58) ' Print colon
chksum := $0000 ' Clear checksum
n := 0 ' Reset N counter
else ' If checksum does not match data
if data[i] == $000 ' Check for Master ACK was printed so print
term.tx(13) ' Master ACK was printed so print carriage return
repeat ' Collecting additional data from Master
if (data[i] & $00FF) ==chksum ' Looking for checksum match
i := i - n ' Preset index counter
if data[i] == $0100 ' Look for Slave ACK
term.hex(data[i], 3) ' Print data from Slave such as from Reader Just Reset
repeat n + 1 ' Repeat printing of data N + 1 times
term.hex(data[i], 3) ' Print Slave data
dat
version byte "Parse_Playground5", 13, 0
data word $0110, $0010, $0100, $0108, $0008, $0100, $0130, $0030, $0100, $0112, $0012, $0000, $0100, $0000, $0133, $0033
word $0006, $0009, $010F, $0000, $0111, $0000, $0003, $0010, $0001, $0001, $0026, $0100, $010B, $000B, $000B, $010B
word $0000, $0131, $0031, $0001, $0000, $0001, $0000, $0064, $0002, $0000, $00C8, $0000, $0000, $00FF, $0001, $0002
word $0005, $000A, $0014, $00FF, $0000, $0000, $0154, $0000, $0112, $0012, $0001, $0001, $0000, $0001, $0001, $0002
word $0030, $000D, $0143, $0000, $0109, $0009, $0003, $0000, $0001, $0005, $0002, $0000, $000F, $0001, $0002, $0005
word $0014, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0000, $0136, $0000, $0137
word $0000, $0037, $004D, $0045, $0049, $0030, $0035, $0030, $0031, $0039, $0030, $0037, $0039, $0035, $0034, $0031
word $0037, $0056, $004E, $0032, $0037, $0030, $0030, $0020, $0055, $0053, $0020, $0020, $0020, $0012, $0020, $0112
word $0000, $0117, $0000, $0056, $0045, $0045, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030
word $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0030, $0031, $0032
word $00DA, $0100, $010A, $000A, $0000, $0000, $0015, $0018, $001F, $0000, $0000, $0000, $0000, $0000, $0000, $0000
word $0000, $0000, $0000, $0000, $0000, $0000, $014C, $0000, $0136, $0036, $0000, $0000, $0100, $0000, $0112, $0012
word $0009, $0055, $0053, $0041, $0045, $0045, $0031, $0030, $0030, $0030, $0033, $0037, $0039, $0030, $0036, $002E
word $0045, $0070, $006F, $0072, $0074, $0020, $0045, $0064, $0067, $0065, $0020, $0020, $0030, $0030, $01B3, $0000
word $010C, $0000, $00FF, $0000, $00FF, $000A, $0100, $0134, $0000, $000F, $0000, $000F, $0052, $0100, $0111, $0001
word $0001, $0077, $0000, $0032, $00BC, $0100, $010B, $000B, $0100, $0133, $0033, $0100, $0114, $0001, $0015, $0100
On lines 77 and 81, I don't think you want to have quit since that will break out of the main loop (and go to the next statement, in this case an implied return from function).
On lines 95 and 101, I don't think you want to have quit on both. Every time through the loop (the plain "repeat" loop) one or the other of the if or else statements will be run. Putting quit in both means the loop only runs once.
That's correct. Each Master string with Slave response and Master ACK on their own line. If you try the other method in the zip archive called "testing" you will see the format of what I'm looking for on PST.
Tried taking out the quit statements on lines 77, 81 & 95 as you suggest here but still doesn't work....
Here's a screen shot of how it should look:
After making your suggested changes here is what I get:
Here's an example of how you can display a block of data by passing the address of the block and the number of entries in it.
pub display(addr, entries) | idx, tval idx := 0 repeat while (idx < entries) tval := word[addr + (idx++ << 1)] if (tval <> $0100) term.hex(tval, 3) term.tx(" ") else term.tx(":") term.tx(" ") term.hex(tval, 3) term.tx(CR) term.tx(CR)This somewhat simple looking project has kicked my @@s. I have spent hours going through the loops by hand trying to understand how the data is handled through them and I just can't figure it out. It's confusing to me to understand how the quit (and next) work to exit the loops in an orderly fashion. I can get it to somewhat work but when I start to tweak it it falls apart.
I'm willing to pay someone to help me out with this at this point. Anyone interested?
Don
pub testing2 | chk, d, t, h i := 0 n := 0 chksum := 0 term.tx(13) repeat i from 0 to 127 ' Main loop. Cycle through xxx words from dat section case (data[i] and $0F00) $0100: ' Slave ACK found if data[i] == $0100 ' Slave ACK found term.hex(data[i], 3) ' Print Slave ACK ' i++ ' NO. DONT MESS WITH THE INDEX $0000: ' If it is Master ACK term.tx(58) ' Master ACK found print colon term.hex(data[i], 3) ' Print Master ACK quit ' Need to quit to main repeat loop other ' If no Master ACK such as in Slave reset ' i-- ' NO. DONT MESS WITH THE INDEX ` Term.tx(13) ' Print carriage return term.hex(data[i], 3) ' Print Master command term.tx(32) ' Print space ' repeat ' NO NEED FOR REPEAT chksum += data[i] ' Add word to checksum ' i++ ' NO. DONT MESS WITH INDEX n++ ' Increment N counter case (data[i] ==(chksum & $00FF) ' Check for Command checksum repeat n ' Print N times term.hex(data[i], 3) ' Print checksum term.tx(32) ' Print space term.tx(58) ' Print colon chksum := $0000 ' Clear checksum n := 0 ' Reset N counterIn other words the case statements would exit to your repeat loop without quit statements since each case is only executed if it is true.
