Sounds good. I won't get a chance to look at code for a few days - real work getting in the way
Re testing, yes I have found every time I do a big change, I have to go and recompile all the apps and make sure they are all still working.
Re "EXCEPT for initial development where program will most likely be run from unknown state."
For that, what I am doing is putting the desktop program in eeprom and debug a new app in ram with F10 downloads. Then the initial state is known because the eeprom program will have written the type of display out to external ram. Actually, if it is done that way, it does not really matter that all the initialisation code is in inefficient spin because there is plenty of space in the desktop program, and the apps don't need to reinitialise the displays. So it is just the draw routine we need to move into spin. That simplifies things a bit.
Nice about 227 longs left. Maybe there is indeed room left for a cache driver too?
I'm still finishing homework for the week so time is limited still. I did take another stab at the cache driver and I'm STILL doing something wrong. It passes the cache test, but won't run in XMMC model yet. I've been going through the previous thread in the GCC forum and might have something. More on that later.
I'm fairly sure touch.spin v0.8.6 is stable. I've also been working on a bug in the buttons program. I've decided that my 3am "fix" of swapping true and false is the wrong way and will be changing the bmp. I'll upload project later today. There's also some bugs in keyboard.. I'll work on those later.
204 longs left in the cache driver *although it doesn't seem to work?* so there should be room for current PASM to port to C. Need to get the cache driver working FIRST!
I have desktop loaded into EEPROM but for some reason... When using the programming method you described, the programs don't seem to return to desktop properly. Runs fine compiled to SD though.
Draw in PASM could be optimized further, and I will work on it some more. My idea is to use hub2display loop, since the same code is currently repeated 3 times. Just wanted to get it working first, and it does. The other optimization might not seem big, but I feel removing the if "s", if "I" from the spin code will help speeds more. I think the previous example of what I'd like to be doing in spin will work. Just need to "nail down" the PASM.
Expansion boards arrived today! I'll solder one up next week, need to get some new resistors for the Vdacs!
I think I figured the reset bug out... Still trying to understand a whole strip *25* 33k's measuring around 90k? They're old *maybe 5 yrs.* from the shack. Been in the 'spare passives' box for a while, but nothing to indicate fault. Guess I should be double checking all resistors from now on. Have not tried a different resistor yet since I pulled the SubD connector already. When parts arrive, *futurlec is taking their time as always* I'll continue soldering boards up.
I *still* can't quite articulate the problem with the cache but I have this gut feeling that it won't work. I think what you need is to bundle a sd file open, data transfer and file close into one cache block, so that then you can be definite that there will be no cache refreshes during the transfer of a file. It involves getting deeper inside the C code and really understanding all the drivers. I can't see a way of doing that apart from taking Kye's code, reordering the functions and running it through the Spin2C program. But I don't fully understand how the C code is working inside - is there any spin anywhere or is it C code under the hood as well? I don't think I have enough information to say whether C can run on this board as well as Spin does.
re your resistors - that is very odd for a 33k to measure 90k. I have never seen a resistor read wrong. However, I have seen my multimeter read wrong when the battery is going flat. I now have two multimeters and if I get an odd reading I check on the other one.
On the other hand, if indeed it is 90k, then that would upset the RC timing and could well account for your reset bug.
I've spent some time moving the draw routine into pasm. It ended up being two routines, one for each display. It certainly is faster with the lorem program, and it is a lot faster with the pacman program as this is drawing lots of little tiles. Included is the new touch.spin and also pacman.spin and the bitmaps this uses. Draws the screen and moves a ghost around at the moment.
It can go faster again - at the moment it is restarting a few things each draw routine and I am sure that they can go but lorem keeps breaking between characters if there is a call to spinhubtoram.
In a general sense, putting draw into pasm speeds up text and it speeds up games because both of those have small tile sizes.
I tested it with both displays. I probably need to go through what changes you would like to make.
' ********** command D and G draw subroutines in pasm **************
pasm_RS_Low and latchvalue,#%01111111' RS lowcall #set373
pasm_RS_Low_ret ret
pasm_RS_High or latchvalue,#%10000000' RS highcall #set373
pasm_RS_High_ret ret
pasm_send andnouta,maskP19 ' CS lowandouta,maskP16P31 ' %11111111_11111111_00000000_00000000 ' set P0-P15 to zero ready to OR orouta,data_16 ' send out the dataandnouta,maskP18 ' ILI write loworouta,maskP18 ' ILI write highorouta,maskP19 ' CS high
pasm_send_ret ret
pasm_Lcd_Write_Com ' pass data_16call #pasm_RS_Low ' RS lowcall #pasm_send
pasm_Lcd_Write_Com_ret ret' return
pasm_Lcd_Write_Data ' pass data_16call #pasm_RS_High ' RS highcall #pasm_send
pasm_Lcd_Write_Data_ret ret' return
pasm_draw_cmd call #pasm_Lcd_Write_Com ' send outrdword data_16,hubaddr ' get the word from hubadd hubaddr,#2' get x1 etccall #pasm_Lcd_Write_Data
pasm_draw_cmd_ret ret
pasm_draw_start ordira,maskP0P15 ' %00000000_00000000_11111111_11111111or latchvalue,#%00001111and latchvalue,#%11111101' group 2 call #set373
pasm_draw_start_ret ret
pasm_Draw_ILI9325 ' replicates the spin version, but assumes already in drawing mode as this is quicker' pass a list of words in hubaddr x1,y1,x2,y2' this is the ILI9325 version, the SSD1289 version is slightly different see below ' no orientation change, so suggest the first draw in a sequence is the pasm version as this sets orientation as well' block is $50,x1,$52,y1,$51,x2,$53,y2,$20,x1,$21,y1, then cmd $22call #pasm_draw_start ' startup common commands with the SSD displaymov data_16,#$50' command 0x50call #pasm_draw_cmd ' send outmov data_16,#$52' command 0x52call #pasm_draw_cmd ' send outmov data_16,#$51' command 0x51call #pasm_draw_cmd ' send outmov data_16,#$53' command 0x53call #pasm_draw_cmd ' send outsub hubaddr,#8' back to beginning = x1mov data_16,#$20' command 0x20call #pasm_draw_cmd ' send outmov data_16,#$21' command 0x21call #pasm_draw_cmd ' send outmov data_16,#$22' command 0x22call #pasm_Lcd_Write_Com ' send outcall #pasm_RS_High ' finish with RS highjmp #init ' finished
pasm_Draw_SSD1289 call #pasm_draw_start
mov data_16,#$44' command 0x44call #pasm_Lcd_Write_Com ' send outrdword pasm_n,hubaddr ' get the word from hubadd hubaddr,#4' merge x2 and x1rdword data_16,hubaddr
shl data_16,#8or data_16,pasm_n
sub hubaddr,#2' point to y1mov data_16,#$45' command 0x45call #pasm_draw_cmd ' send outadd hubaddr,#2' point to y2mov data_16,#$46' command 0x46call #pasm_draw_cmd ' send out y2sub hubaddr,#8' back to beginning = x1mov data_16,#$4E' command 0x4Ecall #pasm_draw_cmd ' send outmov data_16,#$4F' command 0x4Fcall #pasm_draw_cmd ' send outmov data_16,#$22' command 0x22call #pasm_Lcd_Write_Com ' send outcall #pasm_RS_High ' finish with RS highjmp #init ' finished
Very nice work! I think I was over-complicating things with self-modifying code, etc.. I would still like to get burst transfers working, and they appear to be... I still can not explain a couple of the instructions so need to think on this. I'm also curious about your thoughts on changing SetLatch back to a single command and using my save/restore method.
On another note, I believe I have the basics of the C cache driver. It now passes tests with flying colors, could use optimization. What I'm REALLY trying to get my head around is "extended commands." From my understanding, this is how we can pass cog commands. I think the mailbox structure will need to be modified, or perhaps not. I THINK we can use cache_interface.spin to pass commands, but I'm not sure about how we access this in C. Cache_interface.spin has some code like:
I think we can substitute our transfers to do block writes, but as I said "vm_mbox" will probably need to be extended to 4 longs. What I'm REALLY pondering is what could actually be moved here, and where it lives in program memory. If things work like I HOPE they do, cache AND cache_interface live in-chip. Cache should always be loaded in cog *just like ramdriver* so if the interface lives in hub, we should be able to access SRAM at all times. This is even better if display writes can live in cache too, IMO. What I DO NOT understand is where SD code "lives." Of course I could be wrong and interface is just "part of code" and lives in external memory. If not there's still issues to be worked out, say Group3-4 is where things "break" IMO. If code's running along happily, then a cache hit, anything running needs to be "gracefully" shut down before cache read.
I do understand your gut feeling about this not working. The more I work on it, the more it seems NEARLY impossible... Which is to say that I still think it's possible, but it's going to require serious work. Plus quite a bit of learning about the implementation. It will be interesting as things progress, although I'm not pushing this as top-priority right now. It would be nice to have C+,C++ running but with all the improvements in touch.spin I don't see the need for it yet.
Top priority right now is getting expansion board running! I'm not looking forward to another RadioShack trip, but it will be worth it!
With the new pasm draw routine I thought I would push the text as fast as it can go. So - take a font, move all the size data into a hub array, and leave the pixel data in external ram. We can print the letters with one pasm comand. And do characters one after the other quickly. So it is over 300 characters per second and can fill a screen with text in under a second. Maybe archive this one as it might be useful for a terminal program or text editor.
Addit: I just thought of something. Ok, at the moment, the touch.spin object is sort of a garbage can full of routines and maybe you don't need them all. I think you are wanting to fork this code as well.
Fundamental problem with spin as I can see it. You have object A, B and C. Object A is the main and B and C are sub objects. B can't talk to C. So say you split the touch.spin and move all the string routines over to another object. The string routines need to talk to the ram routines (this is also the reason the SD object resides within the touch.spin object and not in the main object).
But... I see a solution. As we move more things into pasm, then objects are able to talk to each other. I think there are a bare minimum of pointers you might need to pass to any object at startup - the location of the three buffers we commonly use, the location of the cog parameters, and maybe some global values. I'm not sure this will work with the SD routines, but it ought to work with the routines that talk to external memory.
What that means is we could split touch.spin up into a number of objects and you include the ones you want. And that might be a way of handling forks in the code in a neater way.
It might also even be possible to do this for the SD object - you could set up some common hub locations with a flag to say "here is an SD command" and a little buffer for a file name, and then any object can open a file, read a block etc.
The reason for all this is that looking at the text code on this post, the touch.spin contains some text drivers but what if you want to change them a little bit? They are not flexible enough.
Also, maybe we can think about shrinking the sd driver code. At a fundamental level, open, close, write 512 bytes, read 512 bytes. So there must be some redundant code that can go to save space.
CON_clkmode = xtal1 + pll16x' use crystal x 16_xinfreq = 5_000_000' demo using the fastdraw command - pasm draw, font size is in hub in an array.' over 300 characters per second. OBJ
tch: "Touch"' touchscreen driverVARlong Font[658] ' 0=size, 1=width,2=height, 3=xoffset, 4=yoffset, 5=amount to move next char, 6=ram location (126-32 characters)PUBMain | touchtest' debug value
tch.BeginProgram
TextFast
repeat
tch.SetWarmBoot ' clears screen, sets a warm boot and rebootsPUBTextFast | fontheight,f,fontaddress,ascii,jump,rambufferaddress,j,size,width,height,xoffset,yoffset,advance,pixeladdress,x,y
tch.Clearscreen($FFFF) ' white background
tch.ClearRam
f := tch.Loadfont(string("Times20.ifn")) 'load font , file 2
fontaddress := tch.getramlocation(f)
fontheight := (tch.readramlong(fontaddress,$F8)>>24) ' get the heightrepeat ascii from32to126' read the font size data into hub (but leave the pixels in external ram)
jump := tch.ReadRamLong(fontaddress,(ascii << 2) + 256)
tch.RamToHub(fontaddress+jump>>1,20) ' move data to rambuffer
rambufferaddress := tch.fetchrambuffer ' find out where rambuffer isrepeat j from0to5
font[((ascii-32)*7)+j] := long[rambufferaddress][j] ' could maybe do with a longmove but it isn't working
font[((ascii-32)*7)+6] := fontaddress+((jump+32)>>1)
tch.drawfastsetup ' set up for fast draw repeat300
ascii := 65' letter to print
f := ((ascii-32)*7) ' address
size := font[f+0]
width := font[f+1]
height := font[f+2]
xoffset := font[f+3]
yoffset := font[f+4]
advance := font[f+5]
pixeladdress := font[f+6]
tch.Drawfast(x+xoffset,y+yoffset,x+width-1+xoffset,y+height-1+yoffset) ' draw on screen
tch.RamToDisplay(pixeladdress,size) ' move bytes from ram out to the display
x += advance ' new line if neededif x >220
x := 0
y += fontheight
All very good thoughts! I've taken a small break from code to work on hardware. Built the basics of the expansion + midi + 4 audio outs. Then stopped to work on something I've had on the table for a while: Soft-Power...
Here's the thought, take the /on|OFF terminals from the regulators and connect together. 20k pull-up to Vin connected to /on|OFF and collector of NPN transistor, emitter to ground. Capacitor on /on|off line for R/C constant discussed below.
Now since all pins are used, I'd been thinking of ways to sense power-off condition and request power on. IF the transistor above is connected to I2C CLOCK will always be high, save during I2C transfers where it goes low for 1/2 period of clock. This is where the R/C comes in. Make C large enough to compensate for low period of clock. Need to run the figures for exact value.
So now the propeller is able to "soft-power-off" by driving I2C CLOCK low for some time. I'm thinking a second or 2. This turns transistor off long enough to charge capacitor to above 1.6v per datasheet specs. Then regulator turns off, and so does everything else.
Now the problem of turning things BACK ON! Well this is where things started to get complicated. Since I didn't want to add another mechanical button, I decided to reuse the reset button already on board. Connect /reset pin, through diode, to /on|OFF and when reset is pressed will ground /on|OFF pin. This powers up the regulators, and 10k pull-up on I2C clock pin will turn transistor back on. With transistor on, /on|OFF pin will be below 1.6v.
That's the theory of operation. I have disconnected the /on|OFF pins for regulators and connected together. This works as expected, connected to gnd REGS are on. Connected to Vin, regs off. Tried 20k pull-up to Vin and mechanical switch to gnd and functions properly. Now time to build the rest! Should work like a charm!
I've been deep inside the pacman coding. One nice thing is that with the new pasm draw routine, it is amazingly fast. I've got screen updates of all the ghosts and other things every 30ms but I think it can go faster than 10ms.
In a general sense, I think in the past one of the limiting things with tile driver games has been getting the data out to the screen. For small games sprites can be stored in hub ram, but as the game reaches a certain level of complexity the sprites have to live in external memory (SD,eeprom, ram) and that limits the refresh speed. So game development sort of comes to a halt.
With this design, the core of the design is fast ram to display transfer, with the propeller added later, and it makes for faster code. The original pacman is in Z80 assembly but for our purposes, Spin (with assembly calls) seems more than fast enough.
In general terms, this board can do a lot more fun things that are yet to be coded.
I have to confess I haven't soldered up an expansion board yet so any bugs you find are my fault!
I have the ghosts and pacman bouncing around randomly at the moment. Useful for testing if walls work.
There are more things to code - collisions between pacman and ghosts, and the tunnel, and I need to redraw the food after the ghosts have moved over a food pellet.
There is some ghost AI to add as well, and then icing sugar like adding fruit when you get a certain score.
I'm hoping to play .wav files as is, or alternatively, use one of the synth programs. Lots of cogs still free.
On a real pacman there are more things flashing, eg the score, and the power pills.
CON_clkmode = xtal1 + pll16x' use crystal x 16_xinfreq = 5_000_000OBJ
tch: "Touch"' touchscreen driverVARbyte AltClock ' 0 = pacman mouth open, ghosts shimmer left, 1= pacman mouth closed, ghosts shimmer rightlong pac[20] ' 4 direction values (0123=RDLU), 5 X values (x8), 5 Y values, for (in order) pacman, red, orange, pink, blue, 5 speed valueslong Random ' every time use this add one (not really random but good enough for debugging)long milliseconds
long GateCounter
tch.BeginProgram
Pacman
repeat
tch.SetWarmBoot ' clears screen, sets a warm boot and rebootsPUBPacman | address,timer,tick,r
tch.Clearscreen(%00000000_00000000) ' so something happens immediately
tch.ClearRam
tch.SDBMPtoRam(string("pactiles.bmp")) ' file 2. File is a .bmp image but each 6x6 tile is continous for fast output
tch.SDBMPtoRam(string("pacbut.bmp")) ' file 3 - control buttons
tch.DrawBMPRam(3,70,215) ' draw the picture
PacText(string("PACMAN"),0,300)
Gatecounter := 0' gate closed
DrawFruit
DrawMaze
'GhostsStart'PacmanDie(60,29*6-3)
Setup ' start locations, speeds and directions
tick := 50' ms between framesrepeat
Move ' move to new locationcase Milliseconds
2000: ReleaseGhost(2)
4000: ReleaseGhost(3)
6000: ReleaseGhost(4)
if Milliseconds >10000
Milliseconds := 10000' don't increment any more
timer += tick ' increment timer
tch.pause1ms(tick)
milliseconds += tick
if timer > 200
altclock ^= 1' alternate 0,1,0,1 for pacman opening mouth, ghosts feet moving
timer := 0' reset timerif gatecounter > 0
gatecounter += tick
if gatecounter > 200
gatecounter := 0
gateclose
PUBSetup' pacman
pac[0] := 0' looking left RDLU
pac[5] := ((20*6)-3)<<8' x position (col*6)-3
pac[10]:= ((17*6)-3)<<8' y position (row*6)-3
pac[15]:= 600' speed, 256 is one pixel per clock tick' red ghost
pac[1] := 1' red ghost eye direction
pac[6] := ((20*6)-3)<<8' start x
pac[11]:= ((11*6)-3)<<8' start y
pac[16]:= 500' speed' orange ghost
pac[2] := 3' orange ghost eye direction
pac[7] := 100<<8' start x
pac[12]:= 83<<8' start y
pac[17]:= 500' speed' pink ghost
pac[3] := 1' pink ghost eye direction
pac[8] := 116<<8' start x
pac[13]:= 83<<8' start y
pac[18]:= 500' speed' blue ghost
pac[4] := 3' blue ghost eye direction
pac[9] := 132<<8' start x
pac[14]:= 83<<8' start y
pac[19]:= 500' speedPUBMove | direction,i,x,y,s' work through characters in order' use the current x,y and the direction of each character' test ahead n pixels and see what is there eg a corridor, food pellet, or wall' if hits a barrier, work out the available directions, apply rules (eg keypress, searching for pacman)' and then change the direction' redraw the background, redraw the character in the new position' add speed to the current direction' erase first If moving down or right then leaves one line of pixels. Erase these (or more if moving fast)' (can't do a full black erase prior to redrawing as flickers a lot)' the cage is not working as the lines are different. K instead of M along the top' add or subtract speedrepeat i from0to4
x:= pac[i+5]>>8' values used for clearrectangle below
y:= pac[i+10]>>8
s:= pac[i+15]>>8' speed, use this to calculate how many pixels to erasecase pac[i] ' direction0:ifnot walldetectR(i)
pac[i+5] += pac[i+15] ' increment x by speed
tch.clearrectangle(x,y,x+s,y+11,0)
1:ifnot walldetectD(i)
pac[i+10] += pac[i+15] ' increment y by speed
tch.clearrectangle(x,y,x+11,y+s,0)
2:ifnot walldetectL(i)
pac[i+5] -= pac[i+15] ' decrement x by speed
tch.clearrectangle(x+11-s,y,x+11,y+11,0)
3:ifnot walldetectU(i)
pac[i+10] -= pac[i+15] ' decrement y by speed
tch.clearrectangle(x,y+11-s,x+11,y+11,0)
DrawPacman(pac[0],pac[5]>>8,pac[10]>>8) ' bit shift 8 for higher x and y resolution
DrawRed(pac[1],pac[6]>>8,pac[11]>>8)
DrawOrange(pac[2],pac[7]>>8,pac[12]>>8)
DrawPink(pac[3],pac[8]>>8,pac[13]>>8)
DrawBlue(pac[4],pac[9]>>8,pac[14]>>8)
PUBReleaseGhost(i)
GateOpen
GateCounter := 1' gate is open, close it later
DrawBlank4(i) ' delete the ghost in the cage
pac[i] := 0' ghost eye direction
pac[i+5] := ((20*6)-3)<<8
pac[i+10]:= ((11*6)-3)<<8' y position (row*6)-3PUBGateOpen
DrawTile(32*6+12,19*6,12*6) ' open gate
DrawTile(32*6+13,20*6,12*6)
PUBGateClose
DrawTile(32*6+14,19*6,12*6) ' close gate
DrawTile(32*6+15,20*6,12*6)
PUBWallDetectL(i)result := falseif collision(pac[i],pac[i+5] - pac[i+15] ,pac[i+10] ) == 2
pac[i] := NewDirection(i,2) ' hit wall to left so choose new direction
DrawBlank4(i)
FixX(i) 'result := truePUBWallDetectR(i)result := falseif collision(pac[i],pac[i+5] + pac[i+15],pac[i+10]) == 0
pac[i] := NewDirection(i,0) ' hit wall to the right so choose new direction
DrawBlank4(i) ' erase the old one prior to the fix move
FixX(i)
result := truePUBWallDetectD(i)result := falseif collision(pac[i],pac[i+5],pac[i+10]+pac[i+15]) == 1
pac[i] := NewDirection(i,1)' hit wall down so choose new direction
DrawBlank4(i)
FixY(i)
result := truePUBWallDetectU(i)result := falseif collision(pac[i],pac[i+5],pac[i+10]-pac[i+15]) == 3
pac[i] := NewDirection(i,3) ' hit a wall going up so choose new direction
DrawBlank4(i)
FixY(i)
result := truePUBDrawBlank4(i)
Draw4(256,pac[i+5]>>8,pac[i+10]>>8)
PUBCollision(dir,x,y)' pass x and y, returns 0,1,2,3 for RDLU collision, 255 for no collision' works on the centre tile where 0,0 is the top left, 6,6 is the centre with a 6x6 square around this' so can encroach 3 on a wall tile and not hit it
x := x>>8' convert to pixels
y := y>>8' convert to pixels
x +=6' centre in pixels
y +=6' centre in pixelsresult := 255if dir == 0and CheckWall(XYtoTile(x+3,y)) == trueresult := 0' right side hits a wallif dir == 2and CheckWall(XYtoTile(x-3,y)) == trueresult := 2' left side hits a wallif dir == 3and CheckWall(XYtoTile(x,y-3)) == trueresult := 3' top side hits a wallif dir == 1and CheckWall(XYtoTile(x,y+3)) == trueresult := 1' bottom side hits a wall' special exemptions for the ghosts in the cage as need to use diff double lines so tracks above and below workif x>84and x<156and y>80and y<94if y<84result :=3if y>89result :=1PUBFixX(i) | x' x values must be 3,9,15 etc so 0-5 is 3, 6-11 is 9
x := pac[i+5]>>8' x value in pixels
x := x/6' divide by 6
x := x*6' multiply by 6 so multiple of 6
x +=3' offset of 3
pac[i+5] := x << 8' put new value back inPUBFixY(i) | y' same as fixx
y := pac[i+10] >> 8
y := y/6
y := y*6
y +=3
pac[i+10] := y << 8PUBXYtoTile(pixelx,pixely)result := (pixelx/6)+(40*(pixely/6)) 'could do this faster with bitshifts instead of mul/dividePUBNewDirection(i,wall) | x,y,dir0,dir1,dir2,dir3' pass i = character, wall is RDLU 0123 the wall that has been hit
x := pac[i+5]
y := pac[i+10]
dir0:=0
dir1:=1
dir2:=2
dir3:=3case wall
0,2:' hit a wall to the right or left so eliminate right and left as options as can't go back the same way
dir0:= true' true is a wall or going back the same way
dir2:= true1,3: ' hit a wall going down or up so eliminate up and down
dir1:= true
dir3:= trueif CheckWall(XYtoTile(x+3,y)) == true' hits a wall to the right so eliminate this
dir0 := trueif CheckWall(XYtoTile(x-3,y)) == true' if hits a wall to the left eliminate this
dir2 := trueif CheckWall(XYtoTile(x,y-3)) == true' if hits a wall up eliminate this
dir3 := trueif CheckWall(XYtoTile(x,y+3)) == true' if hits a wall down eliminate this
dir1 := trueif dir0 <> true' can go rightif dir2<> true' if also can go leftif ?random & 1 == 1result := 0' go rightelseresult := 2' go leftelseresult := 0' go rightif dir1 <> true' can go downif dir3<> true'if can also go upif ?random & 1 == 1result := 1' go downelseresult := 3' go upelseresult := 1' go downif dir2 <> true' can go leftif dir0 <> true'if also can go rightif ?random & 1 == 1result := 0' rightelseresult := 2' leftelse' only one choice left result := 2if dir3 <> true' check upif dir1 <> true' if can go down as wellif ?random & 1 == 1result := 1' go downelseresult := 3' go upelseresult := 3' special exemptions for the ghosts in the cage as need to use diff double lines so tracks above and below workif x>84and x<156and y>80and y<94' direction has already been changed by now so restore itresult := pac[i]
PUBCheckWall(n)' returns true if a wall at location m in maze, false if notresult := falsecasebyte[@maze][n]
"D","C","Z","V","X","\","P","W","Y","[","M","E","F","B","A","K","G","H","I","J","`","_","b","?","a","]","^": result := truePUBDrawTile(n,x,y)' draw tile n in location x,y
tch.drawFast(x,y,x+5,y+5)
tch.ramtodisplay(tch.getramlocation(2)+$36+((n<<5)+(n<<2)),36) ' $36 is the bitmap header offset, 36 (x32+x4) is number of pixels to drawPUBPacText(stringptr,x,y)' the tiles also include text but only capitals. Happens to be stored at position 65 up (though numbers are not in the ascii position)
tch.drawfastsetup
repeatstrsize(stringptr)
DrawTile(byte[stringptr++],x,y)
x += 6PUBDrawMaze | x,y,address,c,n
tch.drawfastsetup
repeat y from0to180step6
n := (40*y)/6repeat x from0to234step6'c := byte[@maze][40*y+x]
c := byte[@maze][n] ' faster as add is faster than multiply
n++
case c
32..120:address := 143 + c ' walls of the maze 126: address := 16' ~ is small food125: address := 20' } is large food
drawtile(address,x,y)
PUBDraw4(n,x,y)' draw 4 tiles - many pictures are 4 tiles rather than 1. N is top left tile number
drawtile(n,x,y)
drawtile(n+1,x+6,y)
drawtile(n+32,x,y+6)
drawtile(n+33,x+6,y+6)
PUBPacmanDie(x,y) | irepeat i from0to11
draw4(520+(i<<1),x,y)
tch.pause1ms(120)
PUBDrawFruit | i' draw row of fruitrepeat i from0to7
draw4(320+(i<<1),10+i*12,190)
PUBDrawPacman(d,x,y) | a' d = direction 0,1,2,3,4= R,D,L,U,stationarycase d ' direction0: a:= 4721: a:= 4742: a:= 7043: a:= 706
draw4(a+(altclock<<2),x,y) ' draw pacmanPUBDrawPink(d,x,y)
draw4(576+(d<<2)+(altclock<<1),x,y) ' draw pink ghost with eyes correct direction and feet movingPUBDrawRed(d,x,y)
draw4(448+(d<<2)+(altclock<<1),x,y) ' draw red ghostPUBDrawOrange(d,x,y)
draw4(640+(d<<2)+(altclock<<1),x,y) ' draw orange ghostPUBDrawBlue(d,x,y)
draw4(592+(d<<2)+(altclock<<1),x,y) ' draw blue ghostDAT
Maze byte"BKKKKKKKKKKKKKKKKKKlkKKKKKKKKKKKKKKKKKKA"byte"D~~~~~~~~~~~~~~~~~~ZY~~~~~~~~~~~~~~~~~~C"byte"D~XPPPPPW~XPPPPPPW~ZY~XPPPPPPW~XPPPPPW~C"byte"D}ZwwwwwY~ZwwwwwwY~ZY~ZwwwwwwY~ZwwwwwY}C"byte"D~\VVVVV[~\VVVVVV[~\[~\VVVVVV[~\VVVVV[~C"byte"D~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~C"byte"D~XPPPPPW~XW~XPPPPPPPPPPPPW~XW~XPPPPPW~C"byte"D~\VVVVV[~ZY~\VVVVVWXVVVVV[~ZY~\VVVVV[~C"byte"D~~~~~~~~~ZY~~~~~~~ZY~~~~~~~ZY~~~~~~~~~C"byte"HPPPPPPPW~ZePPPPPW~ZY~XPPPPPfY~XPPPPPPPG"byte"nwwwwwwwY~ZcVVVVV[~\[~\VVVVVdY~Zwwwwwwwm"byte"nwwwwwwwY~ZY~~~~~~~~~~~~~~~~ZY~Zwwwwwwwm"byte"VVVVVVVV[~\[~^MMMMb??aMMMM]~\[~\VVVVVVVV"byte"~~~~~~~~~~~~~CwwwwwwwwwwwwD~~~~~~~~~~~~~"byte"PPPPPPPPW~XW~CwwwwwwwwwwwwD~XW~XPPPPPPPP"byte"DwwwwwwwY~ZY~CwwwwwwwwwwwwD~ZY~ZwwwwwwwC"byte"DwwwwwwwY~ZY~`KKKKKKKKKKKK_~ZY~ZwwwwwwwC"byte"DwwwwwwwY~ZY~~~~~~~~~~~~~~~~ZY~ZwwwwwwwC"byte"DwwwwwwwY~ZY~XPPPPPPPPPPPPW~ZY~ZwwwwwwwC"byte"JVVVVVVV[~\[~\VVVVVWXVVVVV[~\[~\VVVVVVVI"byte"D~~~~~~~~~~~~~~~~~~ZY~~~~~~~~~~~~~~~~~~C"byte"D~XPPPW~XPPPPPPPPW~ZY~XPPPPPPPPW~XPPPW~C"byte"D~\VVWY~\VVVVVVVV[~\[~\VVVVVVVV[~ZXVV[~C"byte"D}~~~ZY~~~~~~~~~~~~~~~~~~~~~~~~~~ZY~~~}C"byte"HPPW~ZY~XW~XPPPPPPPPPPPPPPPPW~XW~ZY~XPPG"byte"JVV[~\[~ZY~\VVVVVVVWXVVVVVVV[~ZY~\[~\VVI"byte"D~~~~~~~ZY~~~~~~~~~ZY~~~~~~~~~ZY~~~~~~~C"byte"D~XPPPPPfePPPPPPPW~ZY~XPPPPPPPfePPPPPW~C"byte"D~\VVVVVVVVVVVVVV[~\[~\VVVVVVVVVVVVVV[~C"byte"D~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~C"byte"FMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMME"
Also I think it is easier to work with tiles if they don't require any external preprocessing. So, create a bitmap with all the tiles on it, then run it through a little spin routine at startup to strip off the bitmap header and then convert to a linear stream of pixels per tile. Just pass the tilesize and the number of columns and rows. I have tried this with an 8x8 tile for the background, a 8x8 font and 16x16 tiles for the actors.
Loading in tiles uses these three lines of code
tch.SDBMPtoRam(string("pacfont.bmp")) ' file 4 font bitmap (8x8 font)
tch.arraydim((16*16*64)/2) ' file 5 is the font tiles
CreateTiles(5,4,8,16,16) ' create 8x8 font tiles
So it is possible to use the bitmap files attached here. I think this will have a number of applications. Fonts are one, because you can "see" the font and edit it in paintshop or whatever, rather than running it through a preprocessor.
CON' http://home.comcast.net/~jpittman2/pacman/pacmandossier.html#CH3_What_Tile_Am_I_In_clkmode = xtal1 + pll16x' use crystal x 16_xinfreq = 5_000_000OBJ
tch: "Touch"' touchscreen driverVARlong Blinky[6] ' red ghost direction UDLR, speed,x, y, offset (in current direction) mode (hunting, frightened, eyes, in cage) long Pinky[6]
long Inky[6]
long Clyde[6]
long Pacman[6]
tch.BeginProgram
MainPacman
repeat
tch.SetWarmBoot ' clears screen, sets a warm boot and rebootsPUBMainPacman | address,timer,tick,r
tch.ClearRam
tch.drawfastsetup ' setup fast drawing
tch.SDBMPtoRam(string("pac8back.bmp")) ' file 2. File is a .bmp image
tch.arraydim((8*7*64)/2) ' file 3 8x8 tiles, 8 wide, 7 high, this is in words so divide by 2 - file 3
CreateTiles(3,2,8,8,7) ' pixels all one after the other in an array
tch.SDBMPtoRam(string("pac16.bmp")) ' file 6 all the ghosts and pacman (16x16 tiles)
tch.arraydim((8*8*256)/2) ' file 7 pixels all in a row
CreateTiles(7,6,16,8,8) ' pixels all one after the other in an array
tch.drawfastsetup ' must do again if do any data transfers
DrawMaze(3) ' draw maze using file 3
Pactext(string("PACMAN"),5,0*8,0*8) ' draw text using file 5
Pactext(string("HI SCORE"),5,10*8,0*8)
Pactext(string("00"),5,7*8,1*8)
DrawTile16(7,9,2*8,34*8) ' draw number of lives left
DrawTile16(7,9,4*8,34*8) ' draw number of lives left
DrawTile16(7,48,24*8,34*8) ' draw fruit
Setup ' setup the ghosts
DrawBlinky
DrawPinky
DrawInky
DrawClyde
DrawPacman
PUBCreateTiles(destination,source,tilesize,ntileswide,ntileshigh) | s,d,soffset,doffset,tilex,tiley,npixels,tilesizetimesntileswide' pixels linear so faster drawing' take a bitmap made up of tiles and reorder so all the tile data is contiguous. Quicker to find tiles and to display them
s := tch.getramlocation(source)+ $36' location in external ram and add $36 for bitmap header
d := tch.getramlocation(destination) ' destination
npixels := tilesize*tilesize
tilesizetimesntileswide := tilesize*ntileswide ' faster if precalculate this repeat tiley from0to ntileshigh-1repeat tilex from0to ntileswide-1
soffset := (tilex*tilesize) + (tiley*ntileswide) * npixels
doffset := ((tiley*ntileswide)+tilex) * npixels
repeat tilesize
tch.ramwordscopy(d+doffset,s+soffset,tilesize)
soffset += tilesizetimesntileswide
doffset += tilesize
PUBDrawTile8(f,tilenumber,x,y)' file, tilenumber, x, y. Optimised for 8x8 tiles - can do bitshifts instead of divides/multiplies
tch.drawFast(x,y,x+7,y+7)
tilenumber := tilenumber << 6' multiply by 64 to get the start address
tch.ramtodisplay(tch.getramlocation(f)+tilenumber,64) ' displayPUBDrawTile16(f,tilenumber,x,y)' file, tilenumber, x,y. Optimised for 16x16 tiles (bitshifts faster than multiply)
tch.drawfast(x,y,x+15,y+15)
tilenumber := tilenumber << 8' multiply by 256 to get the startaddress
tch.ramtodisplay(tch.getramlocation(f)+tilenumber,256) ' display PUBDrawMaze(f) | x,y,c,n' 28 wide, 36 high
tch.drawfastsetup
repeat y from0to (288-8) step8
n := (28*y)>>3' width times y and divide by 8repeat x from0to (224-8) step8
n++
drawtile8(f,c,x+8,y)
PUBPacText(stringptr,f,x,y)'string, ram file (array) to print from, x,y
tch.drawfastsetup
DrawTile8(f,byte[stringptr++],x,y)
x += 8PUBSetup
Blinky[0] := 2' travelling left
Blinky[1] := 0' speed
Blinky[2] := 14*8+4' tilex 14,13 is startup for Blinky
Blinky[3] := 13*8+4' tiley
Blinky[4] := 0' offset (add speed to this each clock tick and use to recalculate the tile. Increment tile if in the next one)
Blinky[5] := 0' mode = hunting
Pinky[0] := 1
Pinky[1] := 0
Pinky[2] := 11*8+8
Pinky[3] := 16*8+4
Pinky[4] := 0
Pinky[5] := 1' in cage
Inky[0] := 0
Inky[1] := 0
Inky[2] := 13*8+8
Inky[3] := 16*8+4
Inky[4] := 0
Inky[5] := 1
Clyde[0] := 1
Clyde[1] := 0
Clyde[2] := 15*8+8
Clyde[3] := 16*8+4
Clyde[4] := 0
Clyde[5] := 1
Pacman[0] := 1
Pacman[1] := 0
Pacman[2] := 14*8
Pacman[3] := 25*8+4
Pacman[4] := 0
Pacman[5] := 2' startupPUBDrawBlinky' need to add in offset
DrawTile16(7,16+Blinky[0]<<1,Blinky[2],Blinky[3])
PUBDrawPinky
DrawTile16(7,24+Pinky[0]<<1,Pinky[2],Pinky[3])
PUBDrawInky
DrawTile16(7,32+Inky[0]<<1,Inky[2],Inky[3])
PUBDrawClyde
DrawTile16(7,40+Clyde[0]<<1,Clyde[2],Clyde[3])
PUBDrawPacman
DrawTile16(7,2,Pacman[2],Pacman[3])
' http://home.comcast.net/~jpittman2/pacman/pacmandossier.html#CH3_What_Tile_Am_I_InDAT maze ' tile number' 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 byte16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16' 0 byte16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16' 1byte16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16' 2 byte25,21,21,21,21,21,21,21,21,21,21,21,21,30,29,21,21,21,21,21,21,21,21,21,21,21,21,26' 3 byte23,18,18,18,18,18,18,18,18,18,18,18,18,48,47,18,18,18,18,18,18,18,18,18,18,18,18,24' 4 byte23,18,41,46,46,42,18,41,46,46,46,42,18,48,47,18,41,46,46,46,42,18,41,46,46,42,18,24' 5byte23,19,48,16,16,47,18,48,16,16,16,47,18,48,47,18,48,16,16,16,47,18,48,16,16,47,19,24' 6byte23,18,43,45,45,44,18,43,45,45,45,44,18,43,44,18,43,45,45,45,44,18,43,45,45,44,18,24' 7byte23,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,24' 8 byte23,18,41,46,46,42,18,41,42,18,41,46,46,46,46,46,46,42,18,41,42,18,41,46,46,42,18,24' 9byte23,18,43,45,45,44,18,48,47,18,43,45,45,38,37,45,45,44,18,48,47,18,43,45,45,44,18,24' 10 byte23,18,18,18,18,18,18,48,47,18,18,18,18,48,47,18,18,18,18,48,47,18,18,18,18,18,18,24' 11 byte27,22,22,22,22,42,18,48,39,46,46,42,16,48,47,16,41,46,46,40,47,18,41,22,22,22,22,28' 12 byte16,16,16,16,16,23,18,48,37,45,45,44,16,43,44,16,43,45,45,38,47,18,24,16,16,16,16,16' 13 byte16,16,16,16,16,23,18,48,47,16,16,16,16,16,16,16,16,16,16,48,47,18,24,16,16,16,16,16' 14 byte16,16,16,16,16,23,18,48,47,16,50,22,54,20,20,55,22,51,16,48,47,18,24,16,16,16,16,16' 15 byte21,21,21,21,21,44,18,43,44,16,24,16,16,16,16,16,16,23,16,43,44,18,43,21,21,21,21,21' 16 byte16,16,16,16,16,16,18,16,16,16,24,16,16,16,16,16,16,23,16,16,16,18,16,16,16,16,16,16' 17 byte22,22,22,22,22,42,18,41,42,16,24,16,16,16,16,16,16,23,16,41,42,18,41,22,22,22,22,22' 18 byte16,16,16,16,16,23,18,48,47,16,52,21,21,21,21,21,21,53,16,48,47,18,24,16,16,16,16,16' 19 byte16,16,16,16,16,23,18,48,47,16,16,16,16,16,16,16,16,16,16,48,47,18,24,16,16,16,16,16' 20 byte16,16,16,16,16,23,18,48,47,16,41,46,46,46,46,46,46,42,16,48,47,18,24,16,16,16,16,16' 21 byte25,21,21,21,21,44,18,43,44,16,43,45,45,38,37,45,45,44,16,43,44,18,43,21,21,21,21,26' 22byte23,18,18,18,18,18,18,18,18,18,18,18,18,48,47,18,18,18,18,18,18,18,18,18,18,18,18,24' 23 byte23,18,41,46,46,42,18,41,46,46,46,42,18,48,47,18,41,46,46,46,42,18,41,46,46,42,18,24' 24byte23,18,43,45,38,47,18,43,45,45,45,44,18,43,44,18,43,45,45,45,44,18,48,37,45,44,18,24' 25 byte23,19,18,18,48,47,18,18,18,18,18,18,18,16,16,18,18,18,18,18,18,18,48,47,18,18,19,24' 26byte34,46,42,18,48,47,18,41,42,18,41,46,46,46,46,46,46,42,18,41,42,18,48,47,18,41,46,36' 27 byte33,45,44,18,43,44,18,48,47,18,43,45,45,38,37,45,45,44,18,48,47,18,43,44,18,43,45,35' 28byte23,18,18,18,18,18,18,48,47,18,18,18,18,48,47,18,18,18,18,48,47,18,18,18,18,18,18,24' 29 byte23,18,41,46,46,46,46,40,39,46,46,42,18,48,47,18,41,46,46,40,39,46,46,46,46,42,18,24' 30byte23,18,43,45,45,45,45,45,45,45,45,44,18,43,44,18,43,45,45,45,45,45,45,45,45,44,18,24' 31 byte23,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,24' 32 byte27,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,28' 33byte16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16' 34byte16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16' 35
Nice work indeed! Very impressed. Since this is such a long thread I was wondering what the hardware setup you are currently using? I happen to have just acquired a couple of 320x240 LCD modules from eBay and have a few miniature joystick switches needing a good home!
Hi Mark, the hardware is a 100x160mm board that average joe and I have designed. It has gone through a number of revisions but it is essentially a propeller chip, two ram chips and some counter chips, plus the display. average joe has some boards available for sale.
Miniature joysticks sound interesting. I wonder if we could convert the analog signal into something an I2C A to D chip could read? That would make a great controller for this game.
I do have boards for sale, but they will not be compatible with the displays you mentioned in a previous post. Might be able to figure something out, then again maybe not...
PM me if you're interested!
I soldered up another board, and took a video. I have some editing done on the build video but decided to scrap old footage because I was doing it wrong!!! This time I did sockets, REGULATORS *directly to board, DUH...* and continued.
Need to get expansion board going, still have not had time
I will be picking up a couple of analog sticks next time I order from parallax. Hopefully they'll have the FULL PING kit then.
Hi James, I've been quite busy but found some free time on my hands. Now I've really been meaning to get the expansion board up and running. Had some ideas about how to accomplish this but still have not implemented anything. At this point I have been thinking about getting SidSynth running on the expansion and using the touchburger to change parameters. I would also like to use the expansion's programming port to communicate with the pc using the midi in and outs. But there are some significant hurtles that need to be overcome...
First, sidsynth has about 300 longs left after removing debugging code. With the debug code, there's 80 longs left which I imagine is filled with stack *there is a bug mentioned with debug code running, my guess would be not enough stack* If I decided to use SPDIF I could free a cog and about 8k... Still thinking about this.
Second, and most important, I can't figure out how to implement the protocol. My first thought was down and dirty. Use 2 pins for bidirectional asynchronous serial. Have the expansion watch for group change. But on second thought I see some real issues with this. For example, serial transfer is taking place when screen update is called *this could be prevented in code but adds significant complexity*
My next thought was to use a parallel transfer, using the memory cog. My thought is transfers would need to be at least 2 bytes. First byte from host to slave giving read/write command, second byte containing data. *minimum* Seems like a good start but still has some downfalls, IE lack of addressing.
So what I'm asking is this...Do you have any insight as to the most flexible way to implement this? Any thoughts would be greatly appreciated!
You might be able to do serial transfer while doing a screen refresh if you use the programming pins for the serial, and use a serial object that fits entirely in a cog. Buffer things into hub and if the buffer is big enough, worry about what is in the buffer after a screen update?
You know, I thought about using the programming pins... Seems like cheating though
The 8-bit parallel bus keeps making me drool since it should be able to transfer quite quickly and be very lightweight. My thought was to modify 4port full duplex serial and change port4 to transfer using the parallel bus. Maybe this is not the way to go after all.
The problem is that there are SO MANY ways to do it, it's hard to pick just one. Might be best to stick with using a serial port at this point since SidSynth has 4port running 2 ports already.
The goal at this point is to get a GUI control for the parameters of the synth, maybe even use that cool keyboard you made to play notes I would also like to use sidsynth with the midi ports on the expander. Then I start thinking about how cool it would be to have "midi - routing" functions running on the expander. IE have midi-in port "echo" to programing port for serial midi to computer. Then serial-midi out "play" sidsynth. This could be turned on or off at will.
With the GUI running, I'd like to control parameters and possibly save patches to SD card for later use. The touchburger code should be a snap, provided I can figure out the SidSynth code. It's a masterpiece and I don't want to mess it up!
Maybe use the serial ports for the moment - should be easy to drop in existing objects.
Re an 8 bit bus, I'm working on a group of boards that use an "8080" style of bus - 20 pins = 8 data, 8 address (256 ports), read, write and power. I've got 4 boards so far. I'm starting with the generic idea that each board is programmed once and then acts as a functional unit, and only the master is reprogrammed. Take the SD card for instance - as soon as you add an SD card to a propeller chip, you lose 1/3 of the hub memory for code. Add in a TV or VGA display and you lose half, and there is never enough code space for a decent program. So if a separate board has an SD card and a VGA socket and a keyboard etc, then all that code can be offloaded. But you need the speed for transferring data and I think devoting something like 11 propeller pins to driving the bus gives a good compromise between speed and pin count.
The data bus is bidirectional and the address bus might be too so I am thinking of a system like on the I2C bus with one 10k pullup and then devices can pull the line down. ie rather than High and Low signals, the signals are HiZ and L, with a weak pullup. So then any device can talk to any other device. Specs here are a work in progress!
I'm going off on a tangent here though.
For your problem, the serial port sounds like an answer.
Okay, I THINK I've got this. The plan us to use 4-port serial running in SidCog, with 4-port serial on touchburger. Need to figure out coding for CTS/RTS using groups.. I think I might need to OR RTS with group4? Might be a way to do this in code though.
Sounds like you've got great ideas, love the 8080 style bus idea. Using 20 pins should be VERY fast! Can't wait to see what materializes!
*edit
Well I wired up a `244 isolation circuit. I think this should work, just need to shutdown and start serial cog IN MASTER for display updates. I'll start coding tonight and let you know how it goes!
*aedit
I tried coding up a simple loop to start the serial driver, wait some time to fill it up.
obj
exp : "fullDuplexSerial4portJM"' 4 port serial driver with
.. (init code)
exp.init ' init serial driver
exp.AddPort(0,13,16,14,15,0,(expMode),expBaud) ' set master
...(finish init code)
PUBGetExpSTRING | ptr , t'' returns a number of characters
exp.start ' start serial driver
ptr := 0' zero pointer
pause1ms(100) ' ?wait? for buffer to fill? repeatwhile ((t:=exp.rxcheck(0)) <> -1) ' empty serial bufferbyte[@buffer2][ptr] := t ' into buffer2
exp.Stop ' stop RS232 driver, need to do this gracefully??result := ptr ' set result to pointer
Not the best way to do this.. I'm not even sure this would work? There's a chance of losing data this way. What I'd LIKE to do is modify FullDuplex to use Open drain... then I could pull RTS low in spin, clear the buffer, then stop the cog. I think I've narrowed the code, but it's a tricky one...
Well I've had some ideas on shutting the serial cog down on the master in a graceful way. The problem is: with the expansion connected, the touchburger fails to boot! Need to figure out why.
This was after I realized the I2C bus was missing pullups... So the expander programs now. Must be close!
*edit*
Spent the night trying to figure out why my `244 circuit didn't work. Turns out the 2 power headers are labeled wrong. 5v is actually gnd and GND is 5v. Now to rebuild my 244 again...
*aedit
Okay, I'm at a loss... It seems like any load on GP3 pin causes the issue. Having trouble capturing it with the `scope.
Right now I'm getting Random_Reboots during load desktop. Unplug the `244 from the group pin and it boots fine. Hook the scope up to the pin and RR..
Here's a capture. The dip is where it reboots.
And it just starts working, kind of... Not stable. I'm willing to bet it was the 100k resistor networks on Pins 0-16. I'll build another board and re-check. Otherwise it's the cable. I thought a 6" section of floppy cable would work but maybe not!
I have not officially tested this yet, but I think I have the expansion figured out. It's actually fairly simple. Replace the resistor array with a socket, and 74hc244. "Modify" the 244 to get it's power from the headers *(which are labeled incorrectly * and wire the group to enable. Works out kinda nice! I'll edit later for clarity.
I have it working!!! There's still a bug somewhere...
Needed to add a couple no-ops in the assembly driver since there was a problem with the 1'st byte of RamToHub becoming corrupted. That one took me a while to figure out.
pasmramtohub
call #set161and373 ' set up the 161 counter and change to group 2anddira,maskP16P31 '%11111111_11111111_00000000_00000000 inputsandnouta,maskP16 ' memory /rd lownopnop
ramtohub_loop mov data_16,ina' get the datawrword data_16,hubaddr ' move data to hubandnouta,maskP20 ' clock 161 loworouta,maskP20 ' clock 161 highadd hubaddr,#2' increment the hub address djnz len,#ramtohub_loop
orouta,maskP16 ' memory /rd high jmp #init ' ' tristate pins and listen for commands
Then, I needed to modify the group selection as follows
PUBSelectMemGroup' select group 1 for memory transfer
spi.stop ' and stop any other cogs here too if neededDIRA |= %00000000_00011111_11111111_11111111' enable these pins for outputOUTA |= %00000000_00011111_00000000_00000000' set /rd /wr /disp wr and 161 clock high
LatchGroup2
PUBSelectSPIGroupDIRA &= %00000000_00000000_00000000_00000000' so no clashes with the cogs using P0-P2 set these as inputs and P3-P5, and expansion pins
LatchGroup3 ' select group 2 for spi transfers
TouchStart ' start the touchscreen cog ' may need to set some pins here as inputs or outputs with a dira
Now I've still had some issues using the first "port" OR expander pins 0-3
expander pins
0 - 1 - 2 - 3 - 4 - 5 - 6 - 7
I - O - I - O - I - O - I - O
O - I - O - I - O - I - O - I
19 - 12 - 13 - 14 - 15 - 16 - 17 - 18
touchburger pins
con
ExpRX = 16
ExpTX = 19
ExpCTS = 18
ExpRTS = 17
ExpMODE = exp#OCTX
EXP_BRATE = 115200OBJ
exp : "fullDuplexSerial4portJM"' 4 port serial driver with PUBexp_test | ptr, font, p
beginProgram ' warmBoot
font := Loadfont(string("Par16.ifn")) ' black on white 16 point, load and set font to file
Clearscreen(BackFontColor) ' clear screen to BackFontColor = font file loaded above
curx := 0' return Cursor to X 0
cury := 0' return Cursor to Y 0repeat' loop
exp.AddPort(0,ExpRX,ExpTX,ExpCTS,ExpRTS,EXP#DefaultThreshold,ExpMODE,EXP_BRATE) ' create expansion port
SelectSPIGroup ' Change to group3 for transfers
pause1ms(50) ' ?wait? for buffer to fill?
exp.Stop ' stop expander portrepeatwhile ((p:=exp.rxcheck(0)) <> -1) ' empty serial bufferif32 < p < 126' check for printable characterbyte[@sdbuffer][ptr++] := p ' and copy into sdbufferIF ptr > 0' if captured characterbyte[@sdbuffer][ptr] := 0' zero terminate string
TextT(font,@sdbuffer) ' and print message on display
I have several things in mind for the expansion. I figured I'd start with MIDI and Audio wired up. I'm planning on building a skin for SidSynth, similar to pc program included with a previous build. Right now it's simple debugging, ensuring reliable serial port.
There's still a glitch somewhere, but it's one of those pesky ones that pops up and goes away at random. Well not entirely random. IF rebooting expansion board, sometimes display draws garbage.
Still much work to do. I'll record a demo of the debugger in a few.
*edit...
Here's some photos of the debugger, uploading video in a few. This only works for the initialize debugging, once I start playing notes the screen bugs out.
There's a hardware error on the expansion - RN2-Pin2 goes to Q19/OK-1-pin6. OOPS!
Need to do a bunch more testing as things are still not "stable"
Erm, well. Efforts directly connecting the wiznet812MJ to the touchburger soured so plugged the expansion board back in. Seems that pesky bug is gone? Not sure what I did, but I've been working through a clean-up of Touch.Spin and I can no-longer replicate my bug!!! A bug I found : Updating the cursor Y position was wrong for text, would cut off portion of last write.
PUB lf ' line feed, move up one
cury += FontHeight ' next lineif cury + FontHeight > screenheight ' if off the bottom of the screen then clear screen, start at the top' if cury > screenheight ' if off the bottom of the screen then clear screen, start at the top missed the last write -OLD
ClearRectangle(0,0,screenwidth,screenheight,BackFontColor) ' clear the screen
cury := 0
Also: release ALL pins in SPI GROUP.
PUB SelectSPIGroup
DIRA &= %00000000_00000000_00000000_00000000 ' so no clashes with the cogs using P0-P2 set these as inputs and P3-P5, and expansion pins
Also: for stability with 2 displays and the expansion, seems we need a no-op before entering the main loop of Ram2Hub and Ram2Display
pasmramtohub
pasmramtodisplay andnouta,maskP19 ' CS lowanddira,maskP16P31 ' %11111111_11111111_00000000_00000000 so prop pins 0-15 HiZandnouta,maskP16 ' ram /rd lownop
ramtodisplay_loop andnouta,maskP18 ' ILI write loworouta,maskP18 ' ILI write highandnouta,maskP20 ' clock 161 loworouta,maskP20 ' clock 161 highdjnz len,#ramtodisplay_loop
orouta,maskP16 ' mem /rd highorouta,maskP19 ' CS high jmp #init
I'm also attaching the schematic I drew up describing the communication channel I hacked to the expansion. Looks like it works, need to test reliability of communication. Oh yea here's the simple debugging program I've been working on.
CON' //////////////////////////////////////////////////////////////////////' touchburger debugger program, simple serial to text on screen /' //////////////////////////////////////////////////////////////////////' / /' //////////////////////////////////////////////////////////////////////' ///// Clock settings /////_clkmode = xtal1 + pll16x' use crystal x 16 /_xinfreq = 5_000_000' use 5MHZ crystal /' //////////////////////////////////////////////////////////////////////' / /' expansion pin config, slave currently 1 way.' / /' //////////////////////////////////////////////////////////////////////
ExpRX = 16
ExpTX = 19
ExpCTS = 14
ExpRTS = 15
ExpMODE = exp#OCTX
EXP_BRATE = 115200' //////////////////////////////////////////////////////////////////////' VARbyte buffer[512]
'dat default_font byte "Par16.ifn",0 ' default fontdat default_font byte"4x6.ifn",0' default fontOBJ tch : "Touch3"
exp : "fullDuplexSerial4portJM"' 4 port serial driver with PUBIni | ptr, font, p
tch.beginDesktop("S") ' warmBoot
font := tch.Loadfont(@default_font) ' black on white 16 point, load and set font to file
tch.Clearscreen(tch.GetBackFontColor) ' clear screen to BackFontColor = font file loaded above
tch.SetCursor(0,0) ' repeat' loop
tch.SelectSPIGroup ' Change to group3 for transfers
tch.pause1ms(50) ' ?wait? for buffer to fill?
exp.Stop ' stop expander portrepeatwhile ((p:=exp.rxcheck(0)) <> -1) ' empty serial bufferif31 < p < 126' check for printable characterbyte[@buffer][ptr++] := p ' and copy into sdbufferIF ptr > 0' if captured characterbyte[@buffer][ptr] := 0' zero terminate string
tch.TextT(font,@buffer) ' and print message on display
This runs on the touchburger and gives the expansion 1-TX channel. I have not implemented RX yet. There's room for 2 ports on the bus if we really want to push it. I was having problems with one-way recieve on the touchburger, but now it seems better. Still need to test everything thoroughly.
I have 1 unpopulated expansion board left and will record the "fix" for the comms channel. The resistors would probably work, I was just worried about an Off-The-Rails program running on the expansion board causing problems with the touchburger. Also prevents the need from stopping and starting the cog on SLAVE, still need to stop and start cog on MASTER *just like SPI*
A few more posts to this thread, then I'll start a new one *I know, I've been saying that for some time now*
Picked up a 7", 800x480 display on ebay. Getting it to work has been a bit tricky though. Because it is significantly larger, it does not fit in Display 1 slot. Took me a while to figure out that's why I couldn't initialize it. So, connected SD pins to Display 2 slot as well. Just to realize there's an error in the schematic! Display 2 slot has P5 to 24-T_busy, not 26-T_out. Can't believe I missed that. Code's still a mess. One huge problem I've found but not had time to track down. When screenWidth and screenHeight are modified to proper resolution, icons won't draw properly in desktop.
There's a few decisions to make at this point. Largely, how to handle the multiple displays. For the 2.4" and 3.2", using the ASCII character worked pretty well. But now with the 3 different display types, one with a different resolution, I propose using separate touch.spin files. This means compiling programs for each display. Maybe we can have the 2.4" and 3.2" share programs, need to think on this still. One tool I've thought about using is BST's conditional compiles. It would make it possible to keep things in one file, and just change a couple tags when compiling. Still not sure though.
I propose changing DisplayMode to DisplayType and using "2" for 2.4, "3" for 3.2" and "7" for 7". Files on the SD card have max 7 character name, followed by display type. As I said, it would be possible to have the 2.4" and 3.2" share programs but they will display just a bit faster if they don't. Plus code size is smaller...
I'm also thinking about another variation of the spin file. One file "touchP.spin" and "touchD.spin". TouchP is for programs that don't need to initialize the display *most* and TouchD is for those that do *Desktop*.
I've also done a significant amount of tuning of touch.spin *for the SSD* mostly ASM work, some small modifications to Spin as well. Got the drawFast a little faster. Unrolled the loop and made sure there were no hub windows missed. Tried unrolling the BMP to 16bpp but failed. I'll look back into this after getting this new display working properly. It also dawned on me how to speed up loading of BMPs. Instead of reversing the order when transferring from SD to RAM, just change the entry mode for RAM to display RAM. I was also pondering just keeping width and height from the header instead of the whole 54 bytes. Still much work to do. Any thoughts greatly appreciated!
Now if only Raymond would offer the Graphics shield with access to all 16 pins. Then I would need to buy one. I'm still thinking about it, but it seems like a waste of perfectly good ram...
Ok , so i though its about time I also jump into action.
Fist of all @ average joe and Dr_Acula Masssively immpressive work . thanks for sharing it
I always dreamed about building my own stuff, with this propeller more and more I see almost everything is possible with this propeller.
I have been reading back and forth on this tread and think its time I also jump into some coding with an lcd some time soon
a touchscreen GUI with my projects is almost like finally going to space for an astronaut . for me than
have been working on with all different kinds of sensors en modules(temp + humidity + light + CO2 + Ph + EC ) last was the wiznet W5200 . with Mike G who also is the genious on this thing. puting together a webserver, with my controller . the touchscreen is what im missing
anyway
, it isn't really clear to me how the lcd is connected to the propeller , which of all the schematics is the good one
is it this one or are there modifications made to the board later on that are not changed in the schematic ?.
if I understand correctly , I can also connect the lcd directly pin for pin to the propeller , but i wil be having slower speeds. I dont want that
I would realy like to make it the best possible way, so adding the external couters, and memory like you were mentioning .
the idear of having 2 propellers togeter working as one system has also daunted me , because with the wiznet i am almost running out of code space, adding a lcd would deffinintly make it even worse. A second prop , also for the pins , so more sensors can be connected or controled. would be verry nice , but cant realy find a good nice clear example to connect them. maybe putting the lcd, wiznet,sdcard. on one prop . the other one driving relays , indication leds, buttons ( o I dont need those anymore then) and all sensors I want to add ,.
see some talk about the Prop B version. that would make allot of difference those extra pins , even better the prop 2 . but with the prop 2 i am affraid i have to go invent all my sensor routines again , just want to use the prop1 .
are there any boards for sale left ? if so how much would it cost me ( shiping to the netherlands).
I prefeur a good scematic because i can easly make a proto pcb at scool ,I do have to drill the vias manualy . but hey , beats 3 weeks waiting any day. to get somthing to work that is
I also stil have to order a lcd
had 4.3 inch in mind before . dont hear you mentioning it anywhere . maybe ill just go for the 3.2 inch . or both
any suggestions ??
so its going to be some time before ill be talking about that , but i realy look forward to it .
@averagejoe, I've been following the posts on facebook - from the lines to the icons and I think you have it nailed. Great stuff!
Sorry about the bug on the board - my bad. *facepalm*
I like the code changes. Re the board, given the size of the display, one could think about redoing the board layout so the board sits under the display. How much did the display cost? If it was less than the cost of two of the smaller displays, then maybe we move all the code over to the bigger display? That gets around your problem of having different code.
If we ever do a surface mount smaller board, then that would fit underneath one of the smaller displays.
I have a whole system of new boards that I am building and testing at the moment that plug together with 10 pin headers. Everything is via these headers so you can easily change from a VGA or TV or touchscreen setup. The I2C bus also comes out to a 10 way header and there are lots of peripheral I2C bus boards so that could go on the touchscreen board. Not quite ready to release photos yet as there are still some bugs (like the PCB fab house using a mirror image of one of the gerber files).
Re Igor_Rast, yes that schematic is the correct one. Files are Eagle 5.0 - I am not sure if they will open in the new version of Eagle 6. Probably will. Re connecting directly to the prop - yes you can but it is too slow to be practical. Things like dumping fonts out to the display for fast scrolling through text really do work a lot better if the font is stored in external ram.
averagejoe - do you have a link to the supplier of the display?
@ Dr A.
I can't wait to see the new boards you're working on! They sound quite interesting.
There is still a ton of things to get working *and perfected*. I finally got icons working, then broke BMPtoILI... Have not even tested fonts yet..
The display I purchased is here : http://www.ebay.com/itm/181052646803?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 :
$61 is still more expensive than the other displays. There's also other issues... With the increase in pixels, a full screen takes over half the RAM. This means the desktop needs to be wiped if we intend on loading a different full-screen image. I have a couple thoughts about this, but need to explore further before publishing the details. Then there's the fact it takes about 7 seconds to load the desktop background.
The display required a small modification. Removed the resistor for backlight-enable and filled a solder bridge. The power pins are labeled 3v3 only, but runs off 5v just fine. Not sure about other displays, although if they have regulators should work. Several other 7" boards have a 40-pin header, but there seems to be a few different pin layouts.
Re testing, yes I have found every time I do a big change, I have to go and recompile all the apps and make sure they are all still working.
Re "EXCEPT for initial development where program will most likely be run from unknown state."
For that, what I am doing is putting the desktop program in eeprom and debug a new app in ram with F10 downloads. Then the initial state is known because the eeprom program will have written the type of display out to external ram. Actually, if it is done that way, it does not really matter that all the initialisation code is in inefficient spin because there is plenty of space in the desktop program, and the apps don't need to reinitialise the displays. So it is just the draw routine we need to move into spin. That simplifies things a bit.
Nice about 227 longs left. Maybe there is indeed room left for a cache driver too?
I'm fairly sure touch.spin v0.8.6 is stable. I've also been working on a bug in the buttons program. I've decided that my 3am "fix" of swapping true and false is the wrong way and will be changing the bmp. I'll upload project later today. There's also some bugs in keyboard.. I'll work on those later.
204 longs left in the cache driver *although it doesn't seem to work?* so there should be room for current PASM to port to C. Need to get the cache driver working FIRST!
I have desktop loaded into EEPROM but for some reason... When using the programming method you described, the programs don't seem to return to desktop properly. Runs fine compiled to SD though.
Draw in PASM could be optimized further, and I will work on it some more. My idea is to use hub2display loop, since the same code is currently repeated 3 times. Just wanted to get it working first, and it does. The other optimization might not seem big, but I feel removing the if "s", if "I" from the spin code will help speeds more. I think the previous example of what I'd like to be doing in spin will work. Just need to "nail down" the PASM.
Expansion boards arrived today! I'll solder one up next week, need to get some new resistors for the Vdacs!
I think I figured the reset bug out... Still trying to understand a whole strip *25* 33k's measuring around 90k? They're old *maybe 5 yrs.* from the shack. Been in the 'spare passives' box for a while, but nothing to indicate fault. Guess I should be double checking all resistors from now on. Have not tried a different resistor yet since I pulled the SubD connector already. When parts arrive, *futurlec is taking their time as always* I'll continue soldering boards up.
re your resistors - that is very odd for a 33k to measure 90k. I have never seen a resistor read wrong. However, I have seen my multimeter read wrong when the battery is going flat. I now have two multimeters and if I get an odd reading I check on the other one.
On the other hand, if indeed it is 90k, then that would upset the RC timing and could well account for your reset bug.
It can go faster again - at the moment it is restarting a few things each draw routine and I am sure that they can go but lorem keeps breaking between characters if there is a call to spinhubtoram.
In a general sense, putting draw into pasm speeds up text and it speeds up games because both of those have small tile sizes.
I tested it with both displays. I probably need to go through what changes you would like to make.
' ********** command D and G draw subroutines in pasm ************** pasm_RS_Low and latchvalue,#%01111111 ' RS low call #set373 pasm_RS_Low_ret ret pasm_RS_High or latchvalue,#%10000000 ' RS high call #set373 pasm_RS_High_ret ret pasm_send andn outa,maskP19 ' CS low and outa,maskP16P31 ' %11111111_11111111_00000000_00000000 ' set P0-P15 to zero ready to OR or outa,data_16 ' send out the data andn outa,maskP18 ' ILI write low or outa,maskP18 ' ILI write high or outa,maskP19 ' CS high pasm_send_ret ret pasm_Lcd_Write_Com ' pass data_16 call #pasm_RS_Low ' RS low call #pasm_send pasm_Lcd_Write_Com_ret ret ' return pasm_Lcd_Write_Data ' pass data_16 call #pasm_RS_High ' RS high call #pasm_send pasm_Lcd_Write_Data_ret ret ' return pasm_draw_cmd call #pasm_Lcd_Write_Com ' send out rdword data_16,hubaddr ' get the word from hub add hubaddr,#2 ' get x1 etc call #pasm_Lcd_Write_Data pasm_draw_cmd_ret ret pasm_draw_start or dira,maskP0P15 ' %00000000_00000000_11111111_11111111 or latchvalue,#%00001111 and latchvalue,#%11111101 ' group 2 call #set373 pasm_draw_start_ret ret pasm_Draw_ILI9325 ' replicates the spin version, but assumes already in drawing mode as this is quicker ' pass a list of words in hubaddr x1,y1,x2,y2 ' this is the ILI9325 version, the SSD1289 version is slightly different see below ' no orientation change, so suggest the first draw in a sequence is the pasm version as this sets orientation as well ' block is $50,x1,$52,y1,$51,x2,$53,y2,$20,x1,$21,y1, then cmd $22 call #pasm_draw_start ' startup common commands with the SSD display mov data_16,#$50 ' command 0x50 call #pasm_draw_cmd ' send out mov data_16,#$52 ' command 0x52 call #pasm_draw_cmd ' send out mov data_16,#$51 ' command 0x51 call #pasm_draw_cmd ' send out mov data_16,#$53 ' command 0x53 call #pasm_draw_cmd ' send out sub hubaddr,#8 ' back to beginning = x1 mov data_16,#$20 ' command 0x20 call #pasm_draw_cmd ' send out mov data_16,#$21 ' command 0x21 call #pasm_draw_cmd ' send out mov data_16,#$22 ' command 0x22 call #pasm_Lcd_Write_Com ' send out call #pasm_RS_High ' finish with RS high jmp #init ' finished pasm_Draw_SSD1289 call #pasm_draw_start mov data_16,#$44 ' command 0x44 call #pasm_Lcd_Write_Com ' send out rdword pasm_n,hubaddr ' get the word from hub add hubaddr,#4 ' merge x2 and x1 rdword data_16,hubaddr shl data_16,#8 or data_16,pasm_n call #pasm_Lcd_Write_Data sub hubaddr,#2 ' point to y1 mov data_16,#$45 ' command 0x45 call #pasm_draw_cmd ' send out add hubaddr,#2 ' point to y2 mov data_16,#$46 ' command 0x46 call #pasm_draw_cmd ' send out y2 sub hubaddr,#8 ' back to beginning = x1 mov data_16,#$4E ' command 0x4E call #pasm_draw_cmd ' send out mov data_16,#$4F ' command 0x4F call #pasm_draw_cmd ' send out mov data_16,#$22 ' command 0x22 call #pasm_Lcd_Write_Com ' send out call #pasm_RS_High ' finish with RS high jmp #init ' finished
PUB start(code, mbox, cache, config1, config2) | params[_INIT_SIZE] vm_mbox := mbox params[INIT_MBOX] := mbox params[INIT_CACHE] := cache params[INIT_CONFIG_1] := config1 params[INIT_CONFIG_2] := config2 long[vm_mbox] := $ffffffff 'd.debug(code,@params) cognew(code, @params) repeat while long[vm_mbox] vm_linemask := params[0] return vm_linemask pub readLong(madr) long[vm_mbox][0] := (madr&!CMD_MASK) | READ_CMD repeat while long[vm_mbox][0] madr &= vm_linemask return long[long[vm_mbox][1]+madr] pub writeLong(madr, val) long[vm_mbox][0] := (madr&!CMD_MASK) | WRITE_CMD repeat while long[vm_mbox][0] madr &= vm_linemask long[long[vm_mbox][1]+madr] := val
I think we can substitute our transfers to do block writes, but as I said "vm_mbox" will probably need to be extended to 4 longs. What I'm REALLY pondering is what could actually be moved here, and where it lives in program memory. If things work like I HOPE they do, cache AND cache_interface live in-chip. Cache should always be loaded in cog *just like ramdriver* so if the interface lives in hub, we should be able to access SRAM at all times. This is even better if display writes can live in cache too, IMO. What I DO NOT understand is where SD code "lives." Of course I could be wrong and interface is just "part of code" and lives in external memory. If not there's still issues to be worked out, say Group3-4 is where things "break" IMO. If code's running along happily, then a cache hit, anything running needs to be "gracefully" shut down before cache read.I do understand your gut feeling about this not working. The more I work on it, the more it seems NEARLY impossible... Which is to say that I still think it's possible, but it's going to require serious work. Plus quite a bit of learning about the implementation. It will be interesting as things progress, although I'm not pushing this as top-priority right now. It would be nice to have C+,C++ running but with all the improvements in touch.spin I don't see the need for it yet.
Top priority right now is getting expansion board running! I'm not looking forward to another RadioShack trip, but it will be worth it!
With the new pasm draw routine I thought I would push the text as fast as it can go. So - take a font, move all the size data into a hub array, and leave the pixel data in external ram. We can print the letters with one pasm comand. And do characters one after the other quickly. So it is over 300 characters per second and can fill a screen with text in under a second. Maybe archive this one as it might be useful for a terminal program or text editor.
Addit: I just thought of something. Ok, at the moment, the touch.spin object is sort of a garbage can full of routines and maybe you don't need them all. I think you are wanting to fork this code as well.
Fundamental problem with spin as I can see it. You have object A, B and C. Object A is the main and B and C are sub objects. B can't talk to C. So say you split the touch.spin and move all the string routines over to another object. The string routines need to talk to the ram routines (this is also the reason the SD object resides within the touch.spin object and not in the main object).
But... I see a solution. As we move more things into pasm, then objects are able to talk to each other. I think there are a bare minimum of pointers you might need to pass to any object at startup - the location of the three buffers we commonly use, the location of the cog parameters, and maybe some global values. I'm not sure this will work with the SD routines, but it ought to work with the routines that talk to external memory.
What that means is we could split touch.spin up into a number of objects and you include the ones you want. And that might be a way of handling forks in the code in a neater way.
It might also even be possible to do this for the SD object - you could set up some common hub locations with a flag to say "here is an SD command" and a little buffer for a file name, and then any object can open a file, read a block etc.
The reason for all this is that looking at the text code on this post, the touch.spin contains some text drivers but what if you want to change them a little bit? They are not flexible enough.
Also, maybe we can think about shrinking the sd driver code. At a fundamental level, open, close, write 512 bytes, read 512 bytes. So there must be some redundant code that can go to save space.
CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 ' demo using the fastdraw command - pasm draw, font size is in hub in an array. ' over 300 characters per second. OBJ tch: "Touch" ' touchscreen driver VAR long Font[658] ' 0=size, 1=width,2=height, 3=xoffset, 4=yoffset, 5=amount to move next char, 6=ram location (126-32 characters) PUB Main | touchtest ' debug value tch.BeginProgram TextFast repeat tch.SetWarmBoot ' clears screen, sets a warm boot and reboots PUB TextFast | fontheight,f,fontaddress,ascii,jump,rambufferaddress,j,size,width,height,xoffset,yoffset,advance,pixeladdress,x,y tch.Clearscreen($FFFF) ' white background tch.ClearRam f := tch.Loadfont(string("Times20.ifn")) 'load font , file 2 fontaddress := tch.getramlocation(f) fontheight := (tch.readramlong(fontaddress,$F8)>>24) ' get the height repeat ascii from 32 to 126 ' read the font size data into hub (but leave the pixels in external ram) jump := tch.ReadRamLong(fontaddress,(ascii << 2) + 256) tch.RamToHub(fontaddress+jump>>1,20) ' move data to rambuffer rambufferaddress := tch.fetchrambuffer ' find out where rambuffer is repeat j from 0 to 5 font[((ascii-32)*7)+j] := long[rambufferaddress][j] ' could maybe do with a longmove but it isn't working font[((ascii-32)*7)+6] := fontaddress+((jump+32)>>1) tch.drawfastsetup ' set up for fast draw repeat 300 ascii := 65 ' letter to print f := ((ascii-32)*7) ' address size := font[f+0] width := font[f+1] height := font[f+2] xoffset := font[f+3] yoffset := font[f+4] advance := font[f+5] pixeladdress := font[f+6] tch.Drawfast(x+xoffset,y+yoffset,x+width-1+xoffset,y+height-1+yoffset) ' draw on screen tch.RamToDisplay(pixeladdress,size) ' move bytes from ram out to the display x += advance ' new line if needed if x >220 x := 0 y += fontheight
CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 OBJ tch: "Touch" ' touchscreen driver VAR byte AltClock ' 0 = pacman mouth open, ghosts shimmer left, 1= pacman mouth closed, ghosts shimmer right long pac[20] ' 4 direction values (0123=RDLU), 5 X values (x8), 5 Y values, for (in order) pacman, red, orange, pink, blue, 5 speed values long Random ' every time use this add one (not really random but good enough for debugging) long milliseconds long GateCounter PUB Main | touchtest ' debug value tch.BeginProgram Pacman repeat tch.SetWarmBoot ' clears screen, sets a warm boot and reboots PUB Pacman | address,timer,tick,r tch.Clearscreen(%00000000_00000000) ' so something happens immediately tch.ClearRam tch.SDBMPtoRam(string("pactiles.bmp")) ' file 2. File is a .bmp image but each 6x6 tile is continous for fast output tch.SDBMPtoRam(string("pacbut.bmp")) ' file 3 - control buttons tch.DrawBMPRam(3,70,215) ' draw the picture PacText(string("PACMAN"),0,300) Gatecounter := 0 ' gate closed DrawFruit DrawMaze 'GhostsStart 'PacmanDie(60,29*6-3) Setup ' start locations, speeds and directions tick := 50 ' ms between frames repeat Move ' move to new location case Milliseconds 2000: ReleaseGhost(2) 4000: ReleaseGhost(3) 6000: ReleaseGhost(4) if Milliseconds >10000 Milliseconds := 10000 ' don't increment any more timer += tick ' increment timer tch.pause1ms(tick) milliseconds += tick if timer > 200 altclock ^= 1 ' alternate 0,1,0,1 for pacman opening mouth, ghosts feet moving timer := 0 ' reset timer if gatecounter > 0 gatecounter += tick if gatecounter > 200 gatecounter := 0 gateclose PUB Setup ' pacman pac[0] := 0 ' looking left RDLU pac[5] := ((20*6)-3)<<8 ' x position (col*6)-3 pac[10]:= ((17*6)-3)<<8 ' y position (row*6)-3 pac[15]:= 600 ' speed, 256 is one pixel per clock tick ' red ghost pac[1] := 1 ' red ghost eye direction pac[6] := ((20*6)-3)<<8 ' start x pac[11]:= ((11*6)-3)<<8 ' start y pac[16]:= 500 ' speed ' orange ghost pac[2] := 3 ' orange ghost eye direction pac[7] := 100<<8 ' start x pac[12]:= 83<<8 ' start y pac[17]:= 500 ' speed ' pink ghost pac[3] := 1 ' pink ghost eye direction pac[8] := 116<<8 ' start x pac[13]:= 83<<8 ' start y pac[18]:= 500 ' speed ' blue ghost pac[4] := 3 ' blue ghost eye direction pac[9] := 132<<8 ' start x pac[14]:= 83<<8 ' start y pac[19]:= 500 ' speed PUB Move | direction,i,x,y,s ' work through characters in order ' use the current x,y and the direction of each character ' test ahead n pixels and see what is there eg a corridor, food pellet, or wall ' if hits a barrier, work out the available directions, apply rules (eg keypress, searching for pacman) ' and then change the direction ' redraw the background, redraw the character in the new position ' add speed to the current direction ' erase first If moving down or right then leaves one line of pixels. Erase these (or more if moving fast) ' (can't do a full black erase prior to redrawing as flickers a lot) ' the cage is not working as the lines are different. K instead of M along the top ' add or subtract speed repeat i from 0 to 4 x:= pac[i+5]>>8 ' values used for clearrectangle below y:= pac[i+10]>>8 s:= pac[i+15]>>8 ' speed, use this to calculate how many pixels to erase case pac[i] ' direction 0:ifnot walldetectR(i) pac[i+5] += pac[i+15] ' increment x by speed tch.clearrectangle(x,y,x+s,y+11,0) 1:ifnot walldetectD(i) pac[i+10] += pac[i+15] ' increment y by speed tch.clearrectangle(x,y,x+11,y+s,0) 2:ifnot walldetectL(i) pac[i+5] -= pac[i+15] ' decrement x by speed tch.clearrectangle(x+11-s,y,x+11,y+11,0) 3:ifnot walldetectU(i) pac[i+10] -= pac[i+15] ' decrement y by speed tch.clearrectangle(x,y+11-s,x+11,y+11,0) DrawPacman(pac[0],pac[5]>>8,pac[10]>>8) ' bit shift 8 for higher x and y resolution DrawRed(pac[1],pac[6]>>8,pac[11]>>8) DrawOrange(pac[2],pac[7]>>8,pac[12]>>8) DrawPink(pac[3],pac[8]>>8,pac[13]>>8) DrawBlue(pac[4],pac[9]>>8,pac[14]>>8) PUB ReleaseGhost(i) GateOpen GateCounter := 1 ' gate is open, close it later DrawBlank4(i) ' delete the ghost in the cage pac[i] := 0 ' ghost eye direction pac[i+5] := ((20*6)-3)<<8 pac[i+10]:= ((11*6)-3)<<8 ' y position (row*6)-3 PUB GateOpen DrawTile(32*6+12,19*6,12*6) ' open gate DrawTile(32*6+13,20*6,12*6) PUB GateClose DrawTile(32*6+14,19*6,12*6) ' close gate DrawTile(32*6+15,20*6,12*6) PUB WallDetectL(i) result := false if collision(pac[i],pac[i+5] - pac[i+15] ,pac[i+10] ) == 2 pac[i] := NewDirection(i,2) ' hit wall to left so choose new direction DrawBlank4(i) FixX(i) ' result := true PUB WallDetectR(i) result := false if collision(pac[i],pac[i+5] + pac[i+15],pac[i+10]) == 0 pac[i] := NewDirection(i,0) ' hit wall to the right so choose new direction DrawBlank4(i) ' erase the old one prior to the fix move FixX(i) result := true PUB WallDetectD(i) result := false if collision(pac[i],pac[i+5],pac[i+10]+pac[i+15]) == 1 pac[i] := NewDirection(i,1)' hit wall down so choose new direction DrawBlank4(i) FixY(i) result := true PUB WallDetectU(i) result := false if collision(pac[i],pac[i+5],pac[i+10]-pac[i+15]) == 3 pac[i] := NewDirection(i,3) ' hit a wall going up so choose new direction DrawBlank4(i) FixY(i) result := true PUB DrawBlank4(i) Draw4(256,pac[i+5]>>8,pac[i+10]>>8) PUB Collision(dir,x,y) ' pass x and y, returns 0,1,2,3 for RDLU collision, 255 for no collision ' works on the centre tile where 0,0 is the top left, 6,6 is the centre with a 6x6 square around this ' so can encroach 3 on a wall tile and not hit it x := x>>8 ' convert to pixels y := y>>8 ' convert to pixels x +=6 ' centre in pixels y +=6 ' centre in pixels result := 255 if dir == 0 and CheckWall(XYtoTile(x+3,y)) == true result := 0 ' right side hits a wall if dir == 2 and CheckWall(XYtoTile(x-3,y)) == true result := 2' left side hits a wall if dir == 3 and CheckWall(XYtoTile(x,y-3)) == true result := 3 ' top side hits a wall if dir == 1 and CheckWall(XYtoTile(x,y+3)) == true result := 1 ' bottom side hits a wall ' special exemptions for the ghosts in the cage as need to use diff double lines so tracks above and below work if x>84 and x<156 and y>80 and y<94 if y<84 result :=3 if y>89 result :=1 PUB FixX(i) | x ' x values must be 3,9,15 etc so 0-5 is 3, 6-11 is 9 x := pac[i+5]>>8 ' x value in pixels x := x/6 ' divide by 6 x := x*6 ' multiply by 6 so multiple of 6 x +=3 ' offset of 3 pac[i+5] := x << 8 ' put new value back in PUB FixY(i) | y ' same as fixx y := pac[i+10] >> 8 y := y/6 y := y*6 y +=3 pac[i+10] := y << 8 PUB XYtoTile(pixelx,pixely) result := (pixelx/6)+(40*(pixely/6)) 'could do this faster with bitshifts instead of mul/divide PUB NewDirection(i,wall) | x,y,dir0,dir1,dir2,dir3' pass i = character, wall is RDLU 0123 the wall that has been hit x := pac[i+5] y := pac[i+10] x := x>>8 ' convert to pixels y := y>>8 ' convert to pixels x +=6 ' centre in pixels y +=6 ' centre in pixels dir0:=0 dir1:=1 dir2:=2 dir3:=3 case wall 0,2:' hit a wall to the right or left so eliminate right and left as options as can't go back the same way dir0:= true ' true is a wall or going back the same way dir2:= true 1,3: ' hit a wall going down or up so eliminate up and down dir1:= true dir3:= true if CheckWall(XYtoTile(x+3,y)) == true ' hits a wall to the right so eliminate this dir0 := true if CheckWall(XYtoTile(x-3,y)) == true ' if hits a wall to the left eliminate this dir2 := true if CheckWall(XYtoTile(x,y-3)) == true ' if hits a wall up eliminate this dir3 := true if CheckWall(XYtoTile(x,y+3)) == true ' if hits a wall down eliminate this dir1 := true if dir0 <> true ' can go right if dir2<> true ' if also can go left if ?random & 1 == 1 result := 0 ' go right else result := 2 ' go left else result := 0 ' go right if dir1 <> true ' can go down if dir3<> true 'if can also go up if ?random & 1 == 1 result := 1 ' go down else result := 3 ' go up else result := 1 ' go down if dir2 <> true ' can go left if dir0 <> true 'if also can go right if ?random & 1 == 1 result := 0 ' right else result := 2 ' left else ' only one choice left result := 2 if dir3 <> true ' check up if dir1 <> true ' if can go down as well if ?random & 1 == 1 result := 1 ' go down else result := 3 ' go up else result := 3 ' special exemptions for the ghosts in the cage as need to use diff double lines so tracks above and below work if x>84 and x<156 and y>80 and y<94 ' direction has already been changed by now so restore it result := pac[i] PUB CheckWall(n) ' returns true if a wall at location m in maze, false if not result := false case byte[@maze][n] "D","C","Z","V","X","\","P","W","Y","[","M","E","F","B","A","K","G","H","I","J","`","_","b","?","a","]","^": result := true PUB DrawTile(n,x,y) ' draw tile n in location x,y tch.drawFast(x,y,x+5,y+5) tch.ramtodisplay(tch.getramlocation(2)+$36+((n<<5)+(n<<2)),36) ' $36 is the bitmap header offset, 36 (x32+x4) is number of pixels to draw PUB PacText(stringptr,x,y) ' the tiles also include text but only capitals. Happens to be stored at position 65 up (though numbers are not in the ascii position) tch.drawfastsetup repeat strsize(stringptr) DrawTile(byte[stringptr++],x,y) x += 6 PUB DrawMaze | x,y,address,c,n tch.drawfastsetup repeat y from 0 to 180 step 6 n := (40*y)/6 repeat x from 0 to 234 step 6 'c := byte[@maze][40*y+x] c := byte[@maze][n] ' faster as add is faster than multiply n++ case c 32..120:address := 143 + c ' walls of the maze 126: address := 16 ' ~ is small food 125: address := 20 ' } is large food drawtile(address,x,y) PUB Draw4(n,x,y) ' draw 4 tiles - many pictures are 4 tiles rather than 1. N is top left tile number drawtile(n,x,y) drawtile(n+1,x+6,y) drawtile(n+32,x,y+6) drawtile(n+33,x+6,y+6) PUB PacmanDie(x,y) | i repeat i from 0 to 11 draw4(520+(i<<1),x,y) tch.pause1ms(120) PUB DrawFruit | i ' draw row of fruit repeat i from 0 to 7 draw4(320+(i<<1),10+i*12,190) PUB DrawPacman(d,x,y) | a ' d = direction 0,1,2,3,4= R,D,L,U,stationary case d ' direction 0: a:= 472 1: a:= 474 2: a:= 704 3: a:= 706 draw4(a+(altclock<<2),x,y) ' draw pacman PUB DrawPink(d,x,y) draw4(576+(d<<2)+(altclock<<1),x,y) ' draw pink ghost with eyes correct direction and feet moving PUB DrawRed(d,x,y) draw4(448+(d<<2)+(altclock<<1),x,y) ' draw red ghost PUB DrawOrange(d,x,y) draw4(640+(d<<2)+(altclock<<1),x,y) ' draw orange ghost PUB DrawBlue(d,x,y) draw4(592+(d<<2)+(altclock<<1),x,y) ' draw blue ghost DAT Maze byte "BKKKKKKKKKKKKKKKKKKlkKKKKKKKKKKKKKKKKKKA" byte "D~~~~~~~~~~~~~~~~~~ZY~~~~~~~~~~~~~~~~~~C" byte "D~XPPPPPW~XPPPPPPW~ZY~XPPPPPPW~XPPPPPW~C" byte "D}ZwwwwwY~ZwwwwwwY~ZY~ZwwwwwwY~ZwwwwwY}C" byte "D~\VVVVV[~\VVVVVV[~\[~\VVVVVV[~\VVVVV[~C" byte "D~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~C" byte "D~XPPPPPW~XW~XPPPPPPPPPPPPW~XW~XPPPPPW~C" byte "D~\VVVVV[~ZY~\VVVVVWXVVVVV[~ZY~\VVVVV[~C" byte "D~~~~~~~~~ZY~~~~~~~ZY~~~~~~~ZY~~~~~~~~~C" byte "HPPPPPPPW~ZePPPPPW~ZY~XPPPPPfY~XPPPPPPPG" byte "nwwwwwwwY~ZcVVVVV[~\[~\VVVVVdY~Zwwwwwwwm" byte "nwwwwwwwY~ZY~~~~~~~~~~~~~~~~ZY~Zwwwwwwwm" byte "VVVVVVVV[~\[~^MMMMb??aMMMM]~\[~\VVVVVVVV" byte "~~~~~~~~~~~~~CwwwwwwwwwwwwD~~~~~~~~~~~~~" byte "PPPPPPPPW~XW~CwwwwwwwwwwwwD~XW~XPPPPPPPP" byte "DwwwwwwwY~ZY~CwwwwwwwwwwwwD~ZY~ZwwwwwwwC" byte "DwwwwwwwY~ZY~`KKKKKKKKKKKK_~ZY~ZwwwwwwwC" byte "DwwwwwwwY~ZY~~~~~~~~~~~~~~~~ZY~ZwwwwwwwC" byte "DwwwwwwwY~ZY~XPPPPPPPPPPPPW~ZY~ZwwwwwwwC" byte "JVVVVVVV[~\[~\VVVVVWXVVVVV[~\[~\VVVVVVVI" byte "D~~~~~~~~~~~~~~~~~~ZY~~~~~~~~~~~~~~~~~~C" byte "D~XPPPW~XPPPPPPPPW~ZY~XPPPPPPPPW~XPPPW~C" byte "D~\VVWY~\VVVVVVVV[~\[~\VVVVVVVV[~ZXVV[~C" byte "D}~~~ZY~~~~~~~~~~~~~~~~~~~~~~~~~~ZY~~~}C" byte "HPPW~ZY~XW~XPPPPPPPPPPPPPPPPW~XW~ZY~XPPG" byte "JVV[~\[~ZY~\VVVVVVVWXVVVVVVV[~ZY~\[~\VVI" byte "D~~~~~~~ZY~~~~~~~~~ZY~~~~~~~~~ZY~~~~~~~C" byte "D~XPPPPPfePPPPPPPW~ZY~XPPPPPPPfePPPPPW~C" byte "D~\VVVVVVVVVVVVVV[~\[~\VVVVVVVVVVVVVV[~C" byte "D~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~C" byte "FMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMME"
tch.SDBMPtoRam(string("pacfont.bmp")) ' file 4 font bitmap (8x8 font) tch.arraydim((16*16*64)/2) ' file 5 is the font tiles CreateTiles(5,4,8,16,16) ' create 8x8 font tiles
I'm studying the ghost personalities here http://home.comcast.net/~jpittman2/pacman/pacmandossier.html#CH3_What_Tile_Am_I_In
Grateful acknowledgement for the bitmaps here http://www.javaonthebrain.com/java/msmidpman/technical.html
CON ' http://home.comcast.net/~jpittman2/pacman/pacmandossier.html#CH3_What_Tile_Am_I_In _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 OBJ tch: "Touch" ' touchscreen driver VAR long Blinky[6] ' red ghost direction UDLR, speed,x, y, offset (in current direction) mode (hunting, frightened, eyes, in cage) long Pinky[6] long Inky[6] long Clyde[6] long Pacman[6] PUB Main | touchtest ' debug value tch.BeginProgram MainPacman repeat tch.SetWarmBoot ' clears screen, sets a warm boot and reboots PUB MainPacman | address,timer,tick,r tch.Clearscreen(%00000000_00000000) ' so something happens immediately tch.ClearRam tch.drawfastsetup ' setup fast drawing tch.SDBMPtoRam(string("pac8back.bmp")) ' file 2. File is a .bmp image tch.arraydim((8*7*64)/2) ' file 3 8x8 tiles, 8 wide, 7 high, this is in words so divide by 2 - file 3 CreateTiles(3,2,8,8,7) ' pixels all one after the other in an array tch.SDBMPtoRam(string("pacfont.bmp")) ' file 4 font bitmap (8x8 font) tch.arraydim((16*16*64)/2) ' file 5 is the font tiles CreateTiles(5,4,8,16,16) ' create 8x8 font tiles tch.SDBMPtoRam(string("pac16.bmp")) ' file 6 all the ghosts and pacman (16x16 tiles) tch.arraydim((8*8*256)/2) ' file 7 pixels all in a row CreateTiles(7,6,16,8,8) ' pixels all one after the other in an array tch.drawfastsetup ' must do again if do any data transfers DrawMaze(3) ' draw maze using file 3 Pactext(string("PACMAN"),5,0*8,0*8) ' draw text using file 5 Pactext(string("HI SCORE"),5,10*8,0*8) Pactext(string("00"),5,7*8,1*8) DrawTile16(7,9,2*8,34*8) ' draw number of lives left DrawTile16(7,9,4*8,34*8) ' draw number of lives left DrawTile16(7,48,24*8,34*8) ' draw fruit Setup ' setup the ghosts DrawBlinky DrawPinky DrawInky DrawClyde DrawPacman PUB CreateTiles(destination,source,tilesize,ntileswide,ntileshigh) | s,d,soffset,doffset,tilex,tiley,npixels,tilesizetimesntileswide ' pixels linear so faster drawing ' take a bitmap made up of tiles and reorder so all the tile data is contiguous. Quicker to find tiles and to display them s := tch.getramlocation(source)+ $36 ' location in external ram and add $36 for bitmap header d := tch.getramlocation(destination) ' destination npixels := tilesize*tilesize tilesizetimesntileswide := tilesize*ntileswide ' faster if precalculate this repeat tiley from 0 to ntileshigh-1 repeat tilex from 0 to ntileswide-1 soffset := (tilex*tilesize) + (tiley*ntileswide) * npixels doffset := ((tiley*ntileswide)+tilex) * npixels repeat tilesize tch.ramwordscopy(d+doffset,s+soffset,tilesize) soffset += tilesizetimesntileswide doffset += tilesize PUB DrawTile8(f,tilenumber,x,y) ' file, tilenumber, x, y. Optimised for 8x8 tiles - can do bitshifts instead of divides/multiplies tch.drawFast(x,y,x+7,y+7) tilenumber := tilenumber << 6 ' multiply by 64 to get the start address tch.ramtodisplay(tch.getramlocation(f)+tilenumber,64) ' display PUB DrawTile16(f,tilenumber,x,y) ' file, tilenumber, x,y. Optimised for 16x16 tiles (bitshifts faster than multiply) tch.drawfast(x,y,x+15,y+15) tilenumber := tilenumber << 8 ' multiply by 256 to get the startaddress tch.ramtodisplay(tch.getramlocation(f)+tilenumber,256) ' display PUB DrawMaze(f) | x,y,c,n ' 28 wide, 36 high tch.drawfastsetup repeat y from 0 to (288-8) step 8 n := (28*y)>>3 ' width times y and divide by 8 repeat x from 0 to (224-8) step 8 c := byte[@maze][n] ' faster as add is faster than multiply n++ drawtile8(f,c,x+8,y) PUB PacText(stringptr,f,x,y) 'string, ram file (array) to print from, x,y tch.drawfastsetup repeat strsize(stringptr) DrawTile8(f,byte[stringptr++],x,y) x += 8 PUB Setup Blinky[0] := 2 ' travelling left Blinky[1] := 0 ' speed Blinky[2] := 14*8+4 ' tilex 14,13 is startup for Blinky Blinky[3] := 13*8+4 ' tiley Blinky[4] := 0 ' offset (add speed to this each clock tick and use to recalculate the tile. Increment tile if in the next one) Blinky[5] := 0 ' mode = hunting Pinky[0] := 1 Pinky[1] := 0 Pinky[2] := 11*8+8 Pinky[3] := 16*8+4 Pinky[4] := 0 Pinky[5] := 1 ' in cage Inky[0] := 0 Inky[1] := 0 Inky[2] := 13*8+8 Inky[3] := 16*8+4 Inky[4] := 0 Inky[5] := 1 Clyde[0] := 1 Clyde[1] := 0 Clyde[2] := 15*8+8 Clyde[3] := 16*8+4 Clyde[4] := 0 Clyde[5] := 1 Pacman[0] := 1 Pacman[1] := 0 Pacman[2] := 14*8 Pacman[3] := 25*8+4 Pacman[4] := 0 Pacman[5] := 2 ' startup PUB DrawBlinky ' need to add in offset DrawTile16(7,16+Blinky[0]<<1,Blinky[2],Blinky[3]) PUB DrawPinky DrawTile16(7,24+Pinky[0]<<1,Pinky[2],Pinky[3]) PUB DrawInky DrawTile16(7,32+Inky[0]<<1,Inky[2],Inky[3]) PUB DrawClyde DrawTile16(7,40+Clyde[0]<<1,Clyde[2],Clyde[3]) PUB DrawPacman DrawTile16(7,2,Pacman[2],Pacman[3]) ' http://home.comcast.net/~jpittman2/pacman/pacmandossier.html#CH3_What_Tile_Am_I_In DAT maze ' tile number ' 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 byte 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16 ' 0 byte 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16 ' 1 byte 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16 ' 2 byte 25,21,21,21,21,21,21,21,21,21,21,21,21,30,29,21,21,21,21,21,21,21,21,21,21,21,21,26 ' 3 byte 23,18,18,18,18,18,18,18,18,18,18,18,18,48,47,18,18,18,18,18,18,18,18,18,18,18,18,24 ' 4 byte 23,18,41,46,46,42,18,41,46,46,46,42,18,48,47,18,41,46,46,46,42,18,41,46,46,42,18,24 ' 5 byte 23,19,48,16,16,47,18,48,16,16,16,47,18,48,47,18,48,16,16,16,47,18,48,16,16,47,19,24 ' 6 byte 23,18,43,45,45,44,18,43,45,45,45,44,18,43,44,18,43,45,45,45,44,18,43,45,45,44,18,24 ' 7 byte 23,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,24 ' 8 byte 23,18,41,46,46,42,18,41,42,18,41,46,46,46,46,46,46,42,18,41,42,18,41,46,46,42,18,24 ' 9 byte 23,18,43,45,45,44,18,48,47,18,43,45,45,38,37,45,45,44,18,48,47,18,43,45,45,44,18,24 ' 10 byte 23,18,18,18,18,18,18,48,47,18,18,18,18,48,47,18,18,18,18,48,47,18,18,18,18,18,18,24 ' 11 byte 27,22,22,22,22,42,18,48,39,46,46,42,16,48,47,16,41,46,46,40,47,18,41,22,22,22,22,28 ' 12 byte 16,16,16,16,16,23,18,48,37,45,45,44,16,43,44,16,43,45,45,38,47,18,24,16,16,16,16,16 ' 13 byte 16,16,16,16,16,23,18,48,47,16,16,16,16,16,16,16,16,16,16,48,47,18,24,16,16,16,16,16 ' 14 byte 16,16,16,16,16,23,18,48,47,16,50,22,54,20,20,55,22,51,16,48,47,18,24,16,16,16,16,16 ' 15 byte 21,21,21,21,21,44,18,43,44,16,24,16,16,16,16,16,16,23,16,43,44,18,43,21,21,21,21,21 ' 16 byte 16,16,16,16,16,16,18,16,16,16,24,16,16,16,16,16,16,23,16,16,16,18,16,16,16,16,16,16 ' 17 byte 22,22,22,22,22,42,18,41,42,16,24,16,16,16,16,16,16,23,16,41,42,18,41,22,22,22,22,22 ' 18 byte 16,16,16,16,16,23,18,48,47,16,52,21,21,21,21,21,21,53,16,48,47,18,24,16,16,16,16,16 ' 19 byte 16,16,16,16,16,23,18,48,47,16,16,16,16,16,16,16,16,16,16,48,47,18,24,16,16,16,16,16 ' 20 byte 16,16,16,16,16,23,18,48,47,16,41,46,46,46,46,46,46,42,16,48,47,18,24,16,16,16,16,16 ' 21 byte 25,21,21,21,21,44,18,43,44,16,43,45,45,38,37,45,45,44,16,43,44,18,43,21,21,21,21,26 ' 22 byte 23,18,18,18,18,18,18,18,18,18,18,18,18,48,47,18,18,18,18,18,18,18,18,18,18,18,18,24 ' 23 byte 23,18,41,46,46,42,18,41,46,46,46,42,18,48,47,18,41,46,46,46,42,18,41,46,46,42,18,24 ' 24 byte 23,18,43,45,38,47,18,43,45,45,45,44,18,43,44,18,43,45,45,45,44,18,48,37,45,44,18,24 ' 25 byte 23,19,18,18,48,47,18,18,18,18,18,18,18,16,16,18,18,18,18,18,18,18,48,47,18,18,19,24 ' 26 byte 34,46,42,18,48,47,18,41,42,18,41,46,46,46,46,46,46,42,18,41,42,18,48,47,18,41,46,36 ' 27 byte 33,45,44,18,43,44,18,48,47,18,43,45,45,38,37,45,45,44,18,48,47,18,43,44,18,43,45,35 ' 28 byte 23,18,18,18,18,18,18,48,47,18,18,18,18,48,47,18,18,18,18,48,47,18,18,18,18,18,18,24 ' 29 byte 23,18,41,46,46,46,46,40,39,46,46,42,18,48,47,18,41,46,46,40,39,46,46,46,46,42,18,24 ' 30 byte 23,18,43,45,45,45,45,45,45,45,45,44,18,43,44,18,43,45,45,45,45,45,45,45,45,44,18,24 ' 31 byte 23,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,24 ' 32 byte 27,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,28 ' 33 byte 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16 ' 34 byte 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16 ' 35
BTW: current schematic and parts list here:
http://forums.parallax.com/showthread.php?137266-Propeller-GUI-touchscreen-and-full-color-display&p=1117341&viewfull=1#post1117341
James, I almost ordered 2 of these a couple days ago when I ordered another propPlug:
https://www.parallax.com/Store/Accessories/HumanInterfaceDevices/tabid/822/CategoryID/90/List/0/SortField/0/Level/a/ProductID/581/Default.aspx
I think they would be PERFECT for the `2302.
Almost grabbed one of these too:
https://www.parallax.com/Store/Accessories/HumanInterfaceDevices/tabid/822/CategoryID/90/List/0/SortField/0/Level/a/ProductID/615/Default.aspx
Have other stuff to (re)-order right now...
Been super-busy... And gotta run!
Also the MCP2302 will work really well with this. For something like pacman, you could use the screen or the joystick as the controller.
Just going off on a tangent, I have been doing some research on the I2C bus as this can keep running in the background with a cog without having to be stopped for screen refreshes. The PCF8591 is a nice chip - one analog output, 4 analog inputs, three pins to select one of 8 so lots of I/O possible. Schematic is simple http://astro.temple.edu/~cvecchio/PCF8591%20I2C%20example.htm and available on ebay for $1.20 http://www.ebay.com.au/itm/5-x-PCF8591P-PCF8591-8591-IC-8-BIT-AD-AND-DA-CONVERTER-FREE-SHIPPING-/251117655919?pt=LH_DefaultDomain_0&hash=item3a77c7576f PDIP for easy soldering.
*edit
*aedit
obj exp : "fullDuplexSerial4portJM" ' 4 port serial driver with .. (init code) exp.init ' init serial driver exp.AddPort(0,13,16,14,15,0,(expMode),expBaud) ' set master ...(finish init code)
PUB GetExpSTRING | ptr , t '' returns a number of characters exp.start ' start serial driver ptr := 0 ' zero pointer pause1ms(100) ' ?wait? for buffer to fill? repeat while ((t:=exp.rxcheck(0)) <> -1) ' empty serial buffer byte[@buffer2][ptr] := t ' into buffer2 exp.Stop ' stop RS232 driver, need to do this gracefully?? result := ptr ' set result to pointer
Not the best way to do this.. I'm not even sure this would work? There's a chance of losing data this way. What I'd LIKE to do is modify FullDuplex to use Open drain... then I could pull RTS low in spin, clear the buffer, then stop the cog. I think I've narrowed the code, but it's a tricky one...This was after I realized the I2C bus was missing pullups... So the expander programs now. Must be close!
*edit*
*aedit
pasmramtohub call #set161and373 ' set up the 161 counter and change to group 2 and dira,maskP16P31 '%11111111_11111111_00000000_00000000 inputs andn outa,maskP16 ' memory /rd low nop nop ramtohub_loop mov data_16,ina ' get the data wrword data_16,hubaddr ' move data to hub andn outa,maskP20 ' clock 161 low or outa,maskP20 ' clock 161 high add hubaddr,#2 ' increment the hub address djnz len,#ramtohub_loop or outa,maskP16 ' memory /rd high jmp #init ' ' tristate pins and listen for commands
PUB SelectMemGroup ' select group 1 for memory transfer spi.stop ' and stop any other cogs here too if needed DIRA |= %00000000_00011111_11111111_11111111 ' enable these pins for output OUTA |= %00000000_00011111_00000000_00000000 ' set /rd /wr /disp wr and 161 clock high LatchGroup2 PUB SelectSPIGroup DIRA &= %00000000_00000000_00000000_00000000 ' so no clashes with the cogs using P0-P2 set these as inputs and P3-P5, and expansion pins LatchGroup3 ' select group 2 for spi transfers TouchStart ' start the touchscreen cog ' may need to set some pins here as inputs or outputs with a dira
expander pins 0 - 1 - 2 - 3 - 4 - 5 - 6 - 7 I - O - I - O - I - O - I - O O - I - O - I - O - I - O - I 19 - 12 - 13 - 14 - 15 - 16 - 17 - 18 touchburger pins
con ExpRX = 16 ExpTX = 19 ExpCTS = 18 ExpRTS = 17 ExpMODE = exp#OCTX EXP_BRATE = 115200 OBJ exp : "fullDuplexSerial4portJM" ' 4 port serial driver with PUB exp_test | ptr, font, p beginProgram ' warmBoot font := Loadfont(string("Par16.ifn")) ' black on white 16 point, load and set font to file Clearscreen(BackFontColor) ' clear screen to BackFontColor = font file loaded above curx := 0 ' return Cursor to X 0 cury := 0 ' return Cursor to Y 0 repeat ' loop exp.init ' init serial driver exp.AddPort(0,ExpRX,ExpTX,ExpCTS,ExpRTS,EXP#DefaultThreshold,ExpMODE,EXP_BRATE) ' create expansion port SelectSPIGroup ' Change to group3 for transfers exp.start ' start serial driver ptr := 0 ' zero pointer pause1ms(50) ' ?wait? for buffer to fill? exp.Stop ' stop expander port repeat while ((p:=exp.rxcheck(0)) <> -1) ' empty serial buffer if 32 < p < 126 ' check for printable character byte[@sdbuffer][ptr++] := p ' and copy into sdbuffer IF ptr > 0 ' if captured character byte[@sdbuffer][ptr] := 0 ' zero terminate string TextT(font,@sdbuffer) ' and print message on display
What are you going to be using the expansion board for?
*edit...
http://youtu.be/QYSygAMXjQs?hd=1
PUB lf ' line feed, move up one cury += FontHeight ' next line if cury + FontHeight > screenheight ' if off the bottom of the screen then clear screen, start at the top ' if cury > screenheight ' if off the bottom of the screen then clear screen, start at the top missed the last write -OLD ClearRectangle(0,0,screenwidth,screenheight,BackFontColor) ' clear the screen cury := 0
Also: release ALL pins in SPI GROUP.PUB SelectSPIGroup DIRA &= %00000000_00000000_00000000_00000000 ' so no clashes with the cogs using P0-P2 set these as inputs and P3-P5, and expansion pins LatchGroup3 ' select group 2 for spi transfers TouchStart ' start the touchscreen cog
Also: for stability with 2 displays and the expansion, seems we need a no-op before entering the main loop of Ram2Hub and Ram2Displaypasmramtohub call #set161and373 ' set up the 161 counter and change to group 2 and dira,maskP16P31 '%11111111_11111111_00000000_00000000 inputs andn outa,maskP16 ' memory /rd low nop ramtohub_loop mov data_16,ina ' get the data wrword data_16,hubaddr ' move data to hub andn outa,maskP20 ' clock 161 low or outa,maskP20 ' clock 161 high add hubaddr,#2 ' increment the hub address djnz len,#ramtohub_loop or outa,maskP16 ' memory /rd high jmp #init ' ' tristate pins and listen for commands pasmramtodisplay andn outa,maskP19 ' CS low and dira,maskP16P31 ' %11111111_11111111_00000000_00000000 so prop pins 0-15 HiZ andn outa,maskP16 ' ram /rd low nop ramtodisplay_loop andn outa,maskP18 ' ILI write low or outa,maskP18 ' ILI write high andn outa,maskP20 ' clock 161 low or outa,maskP20 ' clock 161 high djnz len,#ramtodisplay_loop or outa,maskP16 ' mem /rd high or outa,maskP19 ' CS high jmp #init
CON ' ////////////////////////////////////////////////////////////////////// ' touchburger debugger program, simple serial to text on screen / ' ////////////////////////////////////////////////////////////////////// ' / / ' ////////////////////////////////////////////////////////////////////// ' ///// Clock settings ///// _clkmode = xtal1 + pll16x ' use crystal x 16 / _xinfreq = 5_000_000 ' use 5MHZ crystal / ' ////////////////////////////////////////////////////////////////////// ' / / ' expansion pin config, slave currently 1 way. ' / / ' ////////////////////////////////////////////////////////////////////// ExpRX = 16 ExpTX = 19 ExpCTS = 14 ExpRTS = 15 ExpMODE = exp#OCTX EXP_BRATE = 115200 ' ////////////////////////////////////////////////////////////////////// ' VAR byte buffer[512] 'dat default_font byte "Par16.ifn",0 ' default font dat default_font byte "4x6.ifn",0 ' default font OBJ tch : "Touch3" exp : "fullDuplexSerial4portJM" ' 4 port serial driver with PUB Ini | ptr, font, p tch.beginDesktop("S") ' warmBoot font := tch.Loadfont(@default_font) ' black on white 16 point, load and set font to file tch.Clearscreen(tch.GetBackFontColor) ' clear screen to BackFontColor = font file loaded above tch.SetCursor(0,0) ' repeat ' loop exp.init ' init serial driver exp.AddPort(0,ExpRX,ExpTX,ExpCTS,ExpRTS,EXP#DefaultThreshold,ExpMODE,EXP_BRATE) ' create expansion port tch.SelectSPIGroup ' Change to group3 for transfers exp.start ' start serial driver ptr := 0 ' zero pointer tch.pause1ms(50) ' ?wait? for buffer to fill? exp.Stop ' stop expander port repeat while ((p:=exp.rxcheck(0)) <> -1) ' empty serial buffer if 31 < p < 126 ' check for printable character byte[@buffer][ptr++] := p ' and copy into sdbuffer IF ptr > 0 ' if captured character byte[@buffer][ptr] := 0 ' zero terminate string tch.TextT(font,@buffer) ' and print message on display
oh yea, BTW... icons for PacMan and the Debugger
anyway
any suggestions ??
Addit: E'go China on ebay have both 5" and 7" displays at 800x480 and both use the same 40 pin system and both have the SSD1963 so we could maybe think about a board that supports both? The 7" one however does not have the header in the center of the board $80 http://www.ebay.com/itm/7-TFT-LCD-Module-Touch-Panel-Screen-SSD1963-PCB-/190565861822?pt=LH_DefaultDomain_0&hash=item2c5e9c49be which would change the way a propeller board was designed. How much was yours?
$50 including shipping for this one http://www.ebay.com/itm/7-TFT-LCD-Module-800-480-with-Touch-Panel-SSD1963-ARM-STM32-code-Cortex-M3-/120963914141?pt=Art_Prints&hash=item1c2a02d99d but it is a 34 pin header instead of 40 pins.
$58 for this one with 40 pins http://www.ebay.com/itm/7-inch-TFT-800-480-LCD-Display-Module-16M-colors-Touch-Panel-Screen-SSD1963-51-/181073065840?pt=US_Laptop_Screens_LCD_Panels&hash=item2a28cbb770 but you would need to buy a 40 pin header
$61 http://www.ebay.com/itm/7inch-7-0-800-480-TFT-LCD-Module-Display-Touch-Panel-SSD1963-For-51-AVR-STM32-/181052646803?pt=LH_DefaultDomain_0&hash=item2a27942593 with a header soldered on
I note these boards are all running from 3.3V so they are not going to be compatible with the 3.2" ones that run on 5V. So need a new design anyway...
Gotta run! Much more soon
