"AND"
I want to test a circuit to make sure pins 5, and 6 are not high at the same time before i use a transistor h bridge. Does this test expression look ok? I didn't expect it to, but pin 7 goes high right away. Is there a good way to prevent the pins from crossing paths other than a mechanical relay, i have a hip 4081 but want to keep it as simple as possible?-thanks-mike
dira[5..7]~~
repeat
if outa[6]~~ and outa[5]~~
outa[7]~~
if outa[6]==1 and outa[5]==1 outa[7]~~I'd suggest having an else, at least while troubleshooting, for sanity
like Dr_Acula I do not understand why outa[6]==1 can work at all. Should that not be ina[7]==1? why outa for reading ?
Enjoy!
Or do you devote two more pins to sampling the actual outputs? But no point in that - by the time the code finds this has happened, and shuts down every cog, the damage may be done.
Or - do you have a hardware solution. That was how I have always built bridge circuits - use a few transistors or logic gates to make sure the error condition never comes up.
Or - do you just code very carefully, in which case no need to check for errors?
BTW it will be important for the bridge to default to off (? pull down resistors) as the propeller pins start off at HiZ (which in practice probably means they are going up and down due to stray RF voltages, mains wiring, flouro lights etc).
ahh. Thank you.
Still ina[1] would make more sense wouldn't it? Just for understanding?
Enjoy!
as allways a step ahed. yes. I understand. Thank you again.
Enjoy!
CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 VAR long cyclev long endcyclev long startpulsev long endpulsev long pulsewidthv long stack[100] long stack1[100] OBJ pst: "parallax serial terminal" PUB eye cognew(plow,@stack) 'cognew(display,@stack1) ' cog for pst for troubleshooting dira[2]~ ctra[30..26]:=100 ctra[5..0]:=2 'radio plugged into pin 2 'read r/c receiver section frqa:=1 repeat waitpeq(0, |< 2, 0) ' wait for Pin 2 to go low waitpeq(0, |< 2, 0) 'Wait for Pin 2 to go high startpulsev:=cnt waitpeq(0, |< 2, 0) ' wait for Pin 2 to go low endpulsev:=cnt waitpeq(0, |< 2, 0) 'Wait for Pin 2 to go high ' endcyclev:=cnt pulsewidthv:=endpulsev-startpulsev ' cyclev:=endcyclev-startpulsev {pub display pst.start(115200) waitcnt(clkfreq/4+cnt) repeat 'serial terminal section pst.str(string("cyclev=")) 'display cyclewidth, and pulsewidth from receiver pst.dec (cyclev) pst.str(string(13,"pulsewidthv=")) pst.dec(pulsewidthv) waitcnt(clkfreq/1000+cnt) 'pst.clear } pub plow dira[5..7]~~ 'notes stickup=154300 'deadstick=122000 'stickdown=89600 repeat if pulsewidthv>132_400 and pulsewidthv <160_000 'if stick is pushed up then turn on transistor to switch relay 1 of h bridge outa[5]~~ else outa[5]~ if pulsewidthv<110_400 and pulsewidthv >83_000 'if stick is pushed up then turn on transistor to switch relay 2 of h bridge outa[6]~~ else outa[6]~ 'if outa[6]==1 and outa[5]==1 'test to see if pin 5 and 6 are ever on together if radio signal is lost ' outa[7]~~One solution might be to explicitly output every pin on every change. eg change
if pulsewidthv>132_400 and pulsewidthv <160_000 'if stick is pushed up then turn on transistor to switch relay 1 outa[5]~~ else outa[5]~to
if pulsewidthv>132_400 and pulsewidthv <160_000 'if stick is pushed up then turn on transistor to switch relay 1 outa[6]~ ' maybe add a pause here - see post #16 outa[5]~~ else outa[5]~ ' maybe add a pause here - see post #16 outa[6]~~And make sure that an off always happens before an on, so the pin order changes above and below the "else"
and maybe add the code for the condition where both relays are off, whatever that pulsewidth is?
I'm not quite sure if a fuse is preventative protection
Look into proper MOSFET drivers - many of those have analog sense feedback, that delays one FETs ON until the other really is OFF, and some have hardware enable lines to connect to a Power-Good reset type signal, for extra brown out area protection.
With large power fets, and large GATE C's there can be appreciable delays from the uC asking for a change, and the device actually turning off.
You can do this in software too, with a 3rd state that is 'all off' that you apply for a few hundred ns between the active states.
If software always explicitly complements, or both-off's, then in a working system crow-bar effects should be avoided, but on a run-away/corrupted system assuming correct software is optimistic.
That's why some also use hardware.
