"AND" — Parallax Forums
"AND"
mikeamikea Posts: 283
edited 2012-07-30 22:13 in Propeller 1
I want to test a circuit to make sure pins 5, and 6 are not high at the same time before i use a transistor h bridge. Does this test expression look ok? I didn't expect it to, but pin 7 goes high right away. Is there a good way to prevent the pins from crossing paths other than a mechanical relay, i have a hip 4081 but want to keep it as simple as possible?-thanks-mike
dira[5..7]~~
repeat
  if outa[6]~~ and  outa[5]~~
    outa[7]~~
    edited 2012-07-30 16:35
    Are you testing pins 5 and 6 and then outputting the answer to 7? If so then should the outa[] on 5 and 6 be an input instead?
  • mikeamikea Posts: 283
    edited 2012-07-30 16:46
    5 and 6 are outputs that drive a relay h bridge. i would like to test what i have or add something to make sure they arn't on simultaneously before i replace the relays with transistors. 7 is just a test led that is supposed to stay on if they end up on at the same time.
    edited 2012-07-30 16:55
    Right now you're basically saying if TRUE and TRUE, i.e. you set both bits (~~) and then combine them with a logical AND. So either use if outa[5] and outa[6] or simply outa[7] := outa[5] & outa[6].
    edited 2012-07-30 17:19
    makes sense now. Changed it == to compare rather than set the state. Thank you for the quick replies. -mike
    if outa[6]==1 and outa[5]==1
        outa[7]~~
  • turbosupraturbosupra Posts: 1,088
    edited 2012-07-30 17:26
    ^ That's how I do it.
    I'd suggest having an else, at least while troubleshooting, for sanity
    edited 2012-07-30 17:27
    I have to correct my statement. The first time through the loop the original states of bits 5 and 6 are used (it's post-set after all). But for the second round they are both set. IOW, you get the correct/intended evaluation once, then always TRUE.
    edited 2012-07-30 19:12
    I am getting cofused,
    like Dr_Acula I do not understand why outa[6]==1 can work at all. Should that not be ina[7]==1? why outa for reading ?
    Enjoy!
    edited 2012-07-30 19:16
    msrobots wrote: »
    If the same cog is driving those pins (and no other cog interferes) then it doesn't matter. You'd read what you sent out. As we don't have all the code it's pure speculation though. To avoid confusion/trouble later reading ina[?] would probably be better.
    edited 2012-07-30 19:17
    Yes I am a bit confused too. There are several failure modes. Best solution is to never make a mistake with the coding in the first place. Don't put "outa := $FFFF" accidentally just before driving the bridge. But if the code is imperfect, there are other failure modes, eg a cog running some completely unrelated code that accidentally puts those two pins high at the same time (due to the wire-or nature of cogs and outa). Unlikely I agree, but then if code is always perfect, no need for this error checking code either.
    Or do you devote two more pins to sampling the actual outputs? But no point in that - by the time the code finds this has happened, and shuts down every cog, the damage may be done.
    Or - do you have a hardware solution. That was how I have always built bridge circuits - use a few transistors or logic gates to make sure the error condition never comes up.
    Or - do you just code very carefully, in which case no need to check for errors?
    BTW it will be important for the bridge to default to off (? pull down resistors) as the propeller pins start off at HiZ (which in practice probably means they are going up and down due to stray RF voltages, mains wiring, flouro lights etc).
    edited 2012-07-30 19:20
    kurenko,
    ahh. Thank you.
    Still ina[1] would make more sense wouldn't it? Just for understanding?
    Enjoy!
    edited 2012-07-30 19:23
    msrobots wrote: »
    Sure, it's the difference between knowing what's really out there (ina[x]) and assuming what should be there (outa[x]).
    edited 2012-07-30 19:28
    oh kurenko,
    as allways a step ahed. yes. I understand. Thank you again.
    Enjoy!
    edited 2012-07-30 21:05
    I am reading a r/c receiver. If the radio signal is lost or somehow not consistent i wanted to see if there would be a condition where out5 and 6 would ever be on together. 5 and 6 each drive relays. right now its no problem because i'm using relays and there can be no shootthrough, but next i would like to replace these with a mosfet h bridge. I think i'm going to put fuses to protect shootthrough, i've shut the radio off for a time and they both ended up coming on together. Thanks for all the info.-mike
    CON
            _clkmode = xtal1 + pll16x                                               'Standard clock mode * crystal frequency = 80 MHz
            _xinfreq = 5_000_000
    VAR
      long cyclev
      long endcyclev
      long startpulsev
      long endpulsev
      long pulsewidthv
      long stack[100]
      long stack1[100]
    OBJ
           pst: "parallax serial terminal"
    PUB   eye
    cognew(plow,@stack)
    'cognew(display,@stack1)   '  cog for pst for troubleshooting
    dira[2]~
    ctra[30..26]:=100
    ctra[5..0]:=2        'radio plugged into pin 2                'read r/c receiver section
    frqa:=1
       repeat
         waitpeq(0, |< 2, 0) ' wait for Pin 2 to go low
         waitpeq(0, |< 2, 0) 'Wait for Pin 2 to go high
         startpulsev:=cnt
         endpulsev:=cnt
        ' endcyclev:=cnt
         pulsewidthv:=endpulsev-startpulsev
        ' cyclev:=endcyclev-startpulsev
    {pub display
    pst.start(115200)
    waitcnt(clkfreq/4+cnt)
      repeat                                    'serial terminal section
       pst.str(string("cyclev="))               'display cyclewidth, and pulsewidth from receiver
       pst.dec (cyclev)
       pst.str(string(13,"pulsewidthv="))
       pst.dec(pulsewidthv)
       waitcnt(clkfreq/1000+cnt)
       'pst.clear             }
    pub plow
    dira[5..7]~~                                                 'notes stickup=154300
        'deadstick=122000
        'stickdown=89600
    repeat
      if pulsewidthv>132_400 and pulsewidthv <160_000            'if stick is pushed up then turn on transistor to switch relay 1 of h bridge
        outa[5]~~
      else
        outa[5]~
       if pulsewidthv<110_400 and pulsewidthv >83_000          'if stick is pushed up then turn on transistor to switch relay 2 of h bridge
           outa[6]~~
       else
        outa[6]~
     'if outa[6]==1 and outa[5]==1                   'test to see if pin 5 and 6 are ever on together if radio signal is lost
      '  outa[7]~~
    edited 2012-07-30 22:10
    Ah, that makes sense.
    One solution might be to explicitly output every pin on every change. eg change
        outa[5]~~
      else
        outa[5]~
    to
        outa[6]~
       ' maybe add a pause here - see post #16
        outa[5]~~
      else
        outa[5]~
        outa[6]~~
    And make sure that an off always happens before an on, so the pin order changes above and below the "else"
    and maybe add the code for the condition where both relays are off, whatever that pulsewidth is?
  • jmgjmg Posts: 15,199
    mikea wrote: »
    .... but next i would like to replace these with a mosfet h bridge. I think i'm going to put fuses to protect shootthrough,
    I'm not quite sure if a fuse is preventative protection ;)
    Look into proper MOSFET drivers - many of those have analog sense feedback, that delays one FETs ON until the other really is OFF, and some have hardware enable lines to connect to a Power-Good reset type signal, for extra brown out area protection.
    With large power fets, and large GATE C's there can be appreciable delays from the uC asking for a change, and the device actually turning off.
    You can do this in software too, with a 3rd state that is 'all off' that you apply for a few hundred ns between the active states.
    If software always explicitly complements, or both-off's, then in a working system crow-bar effects should be avoided, but on a run-away/corrupted system assuming correct software is optimistic.
    That's why some also use hardware.
