Choosing a PCB package?
So Im at the point where not knowing a PCB cad program is holding me back from getting my goals acomplished. I need to use the package to make DIY double sided boards for prototyping and also to make boards from 2 to 4 layers to send in and have professional batches done. I would like the program to be compatible with windows and linux(via wine is ok). There is just so much to choose from. Everyone uses Eagle but everywhere I turn everyone says eagle is junk they just use it becuase its popular. Ive been looking at KiCad, Altium, OrCad and Eagle. Alot of people seem to like dip trace alot too, and someone mentiond allegro. I tried KiCad schematic editor and wasnt very impressed the one in express pcb is much better in my opinion. I know express will run in linux under wine, is its board creator usable for professional manufactured boards? Theres just so many choices and I have so much to get done I dont want to waste a ton of time learning the CAD software, I just wanna learn one CAD package that does what I need is easy and has good foot print libraries.
I'm very glad I've switch from Eagle to Diptrace.
Here are a few of my first attempts at designing a PCB.
You can't do four layer boards with the free version of DipTrace though. I'm not sure if Eagle's free version will do four layers either.
I'm pretty sure PCB Express does not export gerber files.
What I can tell you is that I've gone from zero to producing boards within a few months. Diptrace is easy to understand and fast.
The only downside I've encountered with Diptrace is that there have been times when the "part" I need simply isn't in the library and has to be created.
OBC
http://www.pulsonix.co.uk
It's the easiest to use of the mid-range packages.
http://www.designspark.com/pcb
It's not open-source but its free and has none of the limitations that the free versions of EagleCAD and DipTrace have. Is done by the same people who do ExpressPCB.
I found the thread where the switch to DipTrace was discussed. There's a lot of information about PCB software on that thread.
Thanks for the link. I am downloading it now to try it out.
I acually do have a copy of altium at my disposal and I havent even looked at it, does anyone know how it stacks up espescially against diptrace. Right now Im thinking im gonna have to settle with KiCad since its the only thing I have access to without limitations that seems reasonably easy to get up to speed with and has a good community. I forgot all about altium designer but like I said i just wanna learn one program and get off and running, sooo for those of you with some experince with altium diptrace and kicad maybe how do they stack up?
You mentioned having access to Altium. FYI, Parallax uses Altium, I think it's their education department that uses DipTrace. One reason Parallax likes DipTrace is because the import and export DipTrace files with Altium.
the issue that concerns me at this point in time is the signal layers. its kind of confusing i want to spin some audio boards. the site says u get unlimited power and ground planes. if i need planes for two audio channels a voltage + a voltage - ground and maybe a genral plain thats 6 layers, are 3 of them free and the other 3 considered signal planes? this means i would need the four signal layer liscence? id probably need the 2000 pin 6 layer version for future projects in reality, just for the pin count especially if u wanna throw an arm cpu in there.
I don't know of a PCB that uses more than four layers. The Parallax Laser Range Finder is a four layer board and I believe the PropBOE is a four layer board but most other boards made by/for Parallax are two layer boards.
I also have very limited PCB making experience but I haven't even seen a fab house that offers more than four layers (though I haven't looked very hard for one).
I think Rick makes a lot of good points.
The only thing I don't agree with is the cost issue of more than two layers. While the prices I've seen for four layer boards are between 5 to 7 times the cost of a two layer board, if you're making a really small board, the cost of a four layer board isn't so bad. Several of the hobby PCB fab houses make four layer boards. I have a few four layer boards I plan to submit to a fab house soon myself.
I suppose it wont take long for the extra cost of the four layer boards to exceed the price I paid to upgrade DipTrace so Rick is probably right about the upgrade price not being an issue compared with the cost of making four layer boards. Still the extra $200 upgrade price was/is a bit painful.
You certainly have other choices than DipTrace but I don't think you should be basing your decision on whether of not to use DipTrace on the price of the full version when it's very unlikely you'd really need it.
BTW, you can always upgrade from one DipTrace version to another by paying the difference in price between the two versions. It doesn't cost more to if you start with the less expensive versions and then upgrade to higher versions than it does to start out with the more expensive version.
Dude - try 24 layers. That was one of our digital instruments for automated test. In ATE, >8 layers is very very common.
But maybe you were referencing the hobby/home market.
I was referencing what I had seen here on the forum (and remembered seeing).
Does ATE stand for Automated Test Equipment? I'm guessing the extra (bad word choice but I couldn't think of a better word) layers are ground/power planes to limit noise issues?
Do you know if more than 4 layers is common in other fields? I just don't remember seeing anything but two layer boards posted to the forum. Though I suppose most of the PCBs I've seen on the forum are hobby boards.
Thanks for the information.
Anyone with the two lowest-end versions, and if so, any comments on their usability?
-- Gordon
I used the Starter version for a while. The first time I had an issue with it was when I wanted to panalize a small PCB to use a 5cm x 5cm board. By copying the layout multiple times, I quickly ran out of pins.
I believe the less expensive versions are the same as the more expensive versions except for the number of pins that can be used and the number of signal layers.
I know I've already mentioned it, but I really like DipTrace much more than Eagle. I think Parallax made a good choice in switching to DipTrace.
Yup!
