Quickplayer updated — Parallax Forums
Quickplayer updated
edited 2012-05-22 17:34 in Propeller 1
We've restocked the Quickplayer this afternoon, adding some new features...
Added an SRAM socket.
Added a second Wii Controller Port.
Added a second audio channel.
Specifications:
Video Output. P12,P13,14
Stereo Audio Output. P10,P11
2X Wii Controller Input. #1-P22-P23,#2-P24-P25
Optional SD module connection. P0,P1,P2,P3
Optional SRAM socket. P16(CLK),P17(SI),P18(SO),P19(CS)
http://www.gadgetgangster.com/find-a-project/56?projectnum=207
OBC
    edited 2012-05-22 13:24
    Good job!!! Dang you guys!!
    edited 2012-05-22 14:44
    Specifications:
    OBC
    Is it possible to use a SPI flash in place of the SRAM? That would allow big C programs to run.
    edited 2012-05-22 14:54
    David Betz wrote: »
    From my quick glance at the datasheet for the Winbond W25X40BV, it looks like a match, but as yet untested..
    OBC
    edited 2012-05-22 15:06
    OBC
    Maybe I'll have to order one of your boards and test it! :-)
    edited 2012-05-22 15:15
    David Betz wrote: »
    Just ordered one. I'll let you know how it works with PropGCC as soon as I get it and assemble it. PropGCC can work with either a SPI flash chip or a SPI SRAM chip. I'll try both.
    edited 2012-05-22 15:35
    Thanks David!
    I'll ship it out tomorrow! I simply don't have a SPI flash chip handy to test with as I was preoccupied with SPI SRAM. :)
    OBC
  • AntoineDoinelAntoineDoinel Posts: 312
    edited 2012-05-22 15:40
    Specifications:
    OBC
    Naaah... I just got the "old" one two days ago :-(
    (joking, will get this new one next time... btw, thanks OBC and Nick)
    OTOH the old version leave the pads exposed, which is exactly what I needed for a project.
  • Nick McClickNick McClick Posts: 1,003
    edited 2012-05-22 16:39
    Here's a big photo of the board;
    Thanks David!
    OBC
    I have both so I'll verify that both cache drivers will work. I won't be able to check the SD card though since I didn't order one of those.
