Looking for Prop stamp board, no pins — Parallax Forums
GordonMcCombGordonMcComb Posts: 3,366
edited 2012-05-23 05:18 in Propeller 1
For a project that I can't be too specific about at the moment, I am looking for a Propeller board like the SpinStamp, but with through-holes instead of the soldered-in pins. Non-Parallax products are fine, but they have to be:
a) In *commercial* production, now and for the near future (minimum 6-9 months)
b) In inventory of at least a hundred units, with reasonable lead times (<30 days) for new inventory as needed
c) Fully featured, with its own regulation, EEPROM, crystal, etc., just like the SpinStamp
d) Orderable by consumers in quantities starting at 1, from the Web with online payment tools (PayPal, credit cards, Google Checkout, etc)
e) Available in quantity starting in early September
f) Shipping from North America; sorry no Chinese eBay - most people just won't go that route
The board should have a similar price point to the SpinStamp if USB is off board, and no more than $35-40 if USB is on board. If using off-board USB for programming it has to be compatible with the PropPlug.
Small size and profile is a must. Except for USB connector, if any, it needs to be the same form factor (size, height) as the SpinStamp -- minus the pins, of course.
Let me know of any contenders you think fit the bill. If I can use a Prop then I won't have to go with an Arduino Pro Mini. (I'm not against the Arduino, but I'd like to get a little more editorial play going to the Propeller.) The closer the price is to the Pro Mini, plus maybe $5 or so premium for it being a Propeller, the better.
-- Gordon
  • tonyp12tonyp12 Posts: 1,951
    edited 2012-05-20 10:57
    I could stretch out the Lilly to be the same size, is it always connected to a enumerated USB port ? (saving the cost of a crystal)
    If you place an initial order of a 100's I could see doing a small production run to your specifications.
    Is using a 3rd party free virtual com port OK? as implementing HID to Prop tool is probably not in the near future.
    About the Prop Lilly:
    http://forums.parallax.com/showthread.php?138457-PropLilly-worlds-smallest-Demoboard&p=1080134
    edited 2012-05-20 12:13
    See the original post. The product must have the same functionality as the SpinStamp, which means crystal. And similarly like the SpinStamp, the board needs to run on its own. (Or put another way, I'd happily use the SpinStamp as the reference design if it didn't have pins.)
    It actually doesn't need to be the same size as the SpinStamp. Smaller is okay, but not larger. Sorry that's wasn't clear.
    Sales are through customers going to your site, so you would be selling one at a time -- possibly hundreds, possibly none. But let's hope it isn't "none"!
    -- Gordon
    edited 2012-05-20 23:05
    Gordon: I am not sure if this fits your requirements as they are slightly different from the SPin Stamp.
    My CpuBlade is on a 1"sq pcb and has 36 I/O pins or holes around the edge of the pcb.
    The 4 RHS/down pins are in PropPlug format (gnd/res/si/so)
    On the LHS/down are 2 power pins (5V/gnd).
    All other I/O pins are the prop pins P0..P29 (P30&31 are at the end for the propplug).
    Eeprom is 64KB normally, xtal is pluggable and can be 10MHz if you prefer (I usually ship with 5 or 6 or 6.5MHz)
    The 3V3 regulator can only take 6V MAX regulated input (5V preferred)
    Also optional onboard is the transistor reset circuit which permits using a cheaper non-propplug USB-TTL.
    I am in Australia, so I post unregistered but it takes about 10-14 days to the USA.
    They are in production, but I haven't produced these in 100's (easily doable as that was my professional job)
    I do them for the love of it here on the forum, so I assemble/price them to suit.
    To do it commercially like this I would need to increase the price (currently US$17.50 +$4.00post)
    Here is a link http://clusos.com/home/1994.html
    and http://forums.parallax.com/showthread.php?134134-Cluso-s-new-Propeller-stackable-and-pluggable-boards-(MultiProps-too)&highlight=stackable+blades
    Attachment not found.
    edited 2012-05-21 00:21
    Gordon,
    1. My M44D40+ Module and a PowerTwig as a pair will give you want you want and can go together for $25 (no headers on M44D40+)
    2. I could easily re-spin my M44D40+ Module to add power regulation and hit the $35 price tag.
    3. I also sent you a PM with specifics on a project that, although not ready for public disclosure, will meet each of your requirements you list by your September deadline.
    4. Check out Jazzed's SpinSocket DIP32 Board.
    5. Check out this thread for other ideas.
    edited 2012-05-21 06:08
    Gordon, I use Andrew's M44D40+ Module and a PowerTwig pretty frequently for prototyping and was about to suggest them. Here's a video of it paired with a Wixel if you are curious.
    http://www.youtube.com/watch?v=UJv5J-tOfNU
    Andrew sells with machine pins or sockets, so it's pretty flexible.
    edited 2012-05-21 09:25
    Thanks for the responses. All these are great, though the 40-pin DIP footprint may be a deal killer. They really need to fit into the same approximate space as the Arduino Pro Mini. That's the board being replaced, so the form factor really needs to match that (or, smaller is okay). It's a matter of enclosure size.
    Jazzed's board is a bit closer in size, but from the trailing posts in the thread the cost seems to be nearly 2X the target price.
    -- Gordon
    edited 2012-05-21 12:01
    -- Gordon
    Hi Gordon,
    Unfortunately I don't think anyone here has a board that meets all of your specs, especially in your desired 0.70"x1.30" form factor.
    Perhaps you could get Parallax to make a run of 100-200 SpinStamps without the pins being installed?
    Do they need analog inputs? The Atmega168 provides them, otherwise using sigma/delta ADC would use up to 12 propeller pins for six analog inputs.
    (Sapieha wanted me to tell you about an upcoming board, but unfortunately it does not fit your size/budget constraints.)
    Best Regards,
    Bill
    p.s.
    Many here on the forums could make such a board, but all would face the following issues:
    1) development costs (prototyping etc)
    2) cost of parts / inventory costs
    a) Atmega168 qty.100 price is approx. $1.50 * 100
    b) Prop + eeprom qty.100 price is approx. $7.19 + $0.81 = $8.00 * 100
    3) assembly costs
    4) not knowing how long it will take the initial run of 100 units to sell
    I know that you are aware of all of the above (which I am sure is why you asked if anyone had a board already done that was close to what you need) - but the buyers of the device may not be, and are likely to complain about SpinStamp level pricing.
    edited 2012-05-21 12:19
    Bill, I might ask Ken if it's possible to do a run without the pins, but as there's no guarantee regarding sales I would understand completely if he decided not to.
    Yes, I realize any Prop board would be more expensive, but I was hoping it could be held to about the same $30 pricepoint of the Spin Stamp. I also know that's a price based on Parallax's costs, who after all make the Prop. It may not be a doable price for a third party.
    The Arduino Pro Mini uses the '328, and do remember it has to be pre-flashed with a bootloader, so that adds a bit of cost to it. Still, it's all-around cheaper. No escaping that.
    I'm hoping I can do this project with a Prop. It's a natural for it, but I have to demonstrate it'll work in the same container, and will be reasonably priced. We'll see.
    -- Gordon
  • Mike4421Mike4421 Posts: 131
    edited 2012-05-21 13:15
    @ GordonMcComb..... you can always try to get SpinStamps from Parallax with NO pin's, and make a mechanical rig that lets you bend the extended headers (like the one's you commonly see in Arduino sheilds) into a square shape (if not square; appropriate shape) to match the thickness of the SpinSamp +/- tolerance.... then just solder and you'll have the female header's you need or maybe a combination or just the pins.... etc... same applies with other types of materials/ headers....
    scince this will prob. be a trial and error setup on the headers, until you make the right rig for mass-production.... dont wait till last minute....
    cheers...
    edited 2012-05-21 14:26
    Thanks, Mike, but my project is editorial only on my end. If there's a product out there that fits the bill, I'll write about it, and the company that provides the board will sell it directly to consumers. If there isn't a product available, I have to use the Arduino Pro Mini or an Arduino Nano without pins (like the kind offered by Gravitech).
    I'm kinda surprised there isn't more in Propland, with all the emphasis on doing Propeller-versions of the Uno. The small-format Arduino boards have a big following, too. So are versions of the boards without headers. Just about all the form factors are available that way.
    -- Gordon
  • pedwardpedward Posts: 1,642
    edited 2012-05-21 15:45
    Why no pins? The stamp boards don't have through holes because the pins are pressed on, so stamp -pins isn't viable.
    I would have offered up the PropKey, but I'm not producing it yet. My prototype run came back late so I didn't have time to put in an order for a medium run.
    I'm considering taking the design to a production house now, but I don't have the bucks to pony up for 100 finished pieces. I was planning on producing them at home, but I am hesitant to do so because I don't want to commit to something I can't keep up with.
    FWIW, the PropKey is a 32 pin DIP formfactor with a USB plug on one end of the board and an SD socket on the bottom. It's about the size of a 40 pin DIP with a USB connector sticking out the end.
    All in all, I think it would be better to offer a simple design based around a plugin module like the SpinStamp, rather than bodge together a board, you can unplug the stamp and use it in some other project very easily.
    edited 2012-05-21 16:24
    pedward wrote: »
    Why no pins?
    Pins assume you're plugging into a circuit board, solderless breadboard or a soldered board. But what if there is no circuit board, either because of artistic design, limited space, or both? What if the pins connect directly into to other boards with very short wires or double-length pins? What if space is REALLY tight and you want to connect parts like LEDs and resistors directly to the Prop? What if ...
    Well, I could go on. But the idea here is that one person's simple design is another person's not applicable design -- that's what happens with pre-conceived notions. What I need to do will NOT work with a Spin Stamp or any board that has pins. It has to be as absolutely flat as possible, and squishing down the pins will just look amateurish. I don't want people asking, "Why didn't you just use an Arduino Pro Mini? It's cheaper and doesn't have the pins!" I'm trying to buck the trend of every article being about the Arduino, don't you see.
    -- Gordon
    edited 2012-05-21 16:48
    For a new design...
    Pcb size of 0.7x1.3" or smaller
    Is reset switch required ?
    Is input power of 5V regulated (6V max) ok?
    Anything else besides xtal, eeprom, prop, 3v3 reg ?
    Is 32KB eeprom ok?
    Does it need to be 32KB???
    Should the pinout placement be identical? (Prop exceptions of course)
    Can they be shipped from Australia by unregistered airmail (10-14 days to US)?
    edited 2012-05-21 17:53
    -- Gordon
    Can it be a 'kit' board that uses PTH components? It would be relatively easy to make a PTH board with DIP components, etc, but your space constraints are rather small.
    People tend to forget that the Arduino is an 8bit, so the required package/die space is lessened, not to mention I/O. A PTH DIP Propeller board would be easy to assemble, perhaps giving a sense of achievement completing that step as well.
    The PropKey isn't a low height design at present, since it is double sided and has a rather tall uSD socket on it. If you skip the uSD socket, it could be shorter, especially with an SMD reset button.
    Anyway, I'm open to suggestions from forum members on which outfits are good for assembly/board production. Advanced Circuits/4PCB sent me an email the other day about that, so I was inclined to get in contact with them, although the are rather pricey for just PCBs.
    edited 2012-05-21 18:02
    I feel your pain, G-Man.
    There are several Forum members who've done, or were going to do, SpinStamp-like boards, but I couldn't get anyone to appreciate the need for solder pads for wires (oh, and a couple of #2 or #4 holes for mounting with) instead of stuffing pins in them.
    [I have to partly except MacTuxLin, but his board used the QFN instead of the LQFP, and I don't know if he ever produced complete product with it.]
  • richaj45richaj45 Posts: 179
    edited 2012-05-22 07:56
    Hello:
    How about cutting the center of the Parallax demo board. Maybe Parallax will sell the demo board with only the center parts populated.
    Not cost effective but a nice small size for embedded application were no PC connection is required.
    rich
    edited 2012-05-22 13:43
    richaj45: That is pretty much what my CpuBlade does (plus extras) - its 1" sq which is smaller than the center of the protoboard which I think you meant to refer to.
    edited 2012-05-22 13:59
    Hello Gordon,
    I made this board quite a while back but since it is in a 40-pin format it is probably too big. This board put the Propeller in a BS2p40 footprint and has an onboard MAX3232 so it can use the same serial connection that a Stamp would for Programming. It has small pads at each I/O pin that can accomodate a small resistor, cap, or solder bridge depending upon how you want it configured. Made a few prototypes but there didn't seem to be enough interest to justify making a run of boards.
    http://forums.parallax.com/showthread.php?92127-NEW-40-pin-Propeller-prototype-module-Most-hackable-yet
    Robert
  • MacTuxLinMacTuxLin Posts: 821
    PJ Allen wrote: »
    Hello PJ,
    Yeap. I did produced a couple of this board & they are also populated. Prop1ModRev2Ext. I have about >30pcs left on-hand. I did brought some over to Parallax Expo 2012...
