Minmal PCB carrier for BS2
Britannicus
Hi All,
I'm looking to do a rather compact piece of work with my trusty BS 2 stamp - working this into controlling a hexapod.
Initially I have the parallax servo driver but it leaves a very little space for the BS2 - To date I've always used my BOE, but I'm after a very minimal implementation.
I'm looking for a schematic, or better still a PCB template that I can etch my own board.
- I'd like to be able to programme the Stamp in situ,
- I need to have all 16 pins available as pin outs but not necessarily anything more than a pin I can connect to later
my plan is to mount my BS 2 esentially on a small PCB with 24 Pins - I could then manufacture a programming socket to Sout, Sin ATN and VSS connection just to plug onto pins 1 to 4 for programming purposes. Pin 4 would also connect to earth of my on board battery.
Then
To Vin : I'd connect a clean 6V - I have 9V on board so would use a voltage regulator - is that the correct voltage ?
To Vss I'd conntect to the onboard earth,
to Res - connect to earth via a contact switch
to Vdd - connect to earth via 1000 uF capacitor
(not even sure if I need these last 3 )
This would seem to replicate all I need from my BOE to drive my servo controller and a few other bits I'm planning on by connecting to the pins.
Frankly I'm a bit scared to experiment here 'cos I don' twant to fry my stamps !
Have I got the right idea here ??? - as always I could really do with a helping hand.
Then
V_in supply as required, lead out the I/O to a header or what have you.
Basic Stamp Carrier Board
Basic Stamp Super Carrier Board
Looking at PJ's diagram - are the capacitors 0.1uF ?? - just can't quite make out your notation.
The carrier seems to take raw 9 V direct from the battery - my BOE uses a voltage regulator - I'm assuming this is OK if I hook my stamp up to 9V direct ? - is there a max current it will take - my 9V on board supply is a bit more than a standard 9V box battery.
I'm figuring to build the smallest board I can - and then use the pins 1,2,3 for parallel communicationwith the associated capacitors connected to my plug rather than to the board - seem OK ??
Yes.
Ray Marston, an Englander, has promulgated that format of not using decimals/periods/full-stops. He figured the dots would go missing through copiers, JPGs of JPGs, and so on. So, 0.1uF is expressed as 0u1; 1.5kΩ as 1K5; 3.3V as 3V3. The letters/symbols hold out better than little dots do.
As long as that all makes the same electrical contact it's a go.
The product page for the BASIC Stamp 2 has the input voltage listed for the Vin pin and the Vdd pin depending on which you use to feed power to the stamp. You can feed the stamp up to 15 volts on the Vin pin. Keep in mind that the more current you pull from the IO pins, the more work the BS2's regulator will have in dropping the input voltage.
Power Requirements: 5.5 to 15 VDC (Vin), or 5 VDC (Vdd)
I don't know why values weren't expressed as nF, "the new thing", but I'm not going to start.
Picofarad used to be expressed as uuF, micro-micro farad, till somewhat recently.
