Gadget Gangster Propeller Platform USB - Going Away? - Page 3 — Parallax Forums
135
  • RaymanRayman Posts: 16,033
    edited 2012-03-29 16:31
    I'd like to know more about how the contact current rating scales with voltage...
    The switch I've been using is rated at 0.25 A at 125 VAC... This one is rated at 0.3 A at 6 VDC and 0.1 A at 30 VDC.
    Ideally, I'd like a switch that can handle the allowed USB load of 0.5 A at 5 VDC.
    Does my 125 VAC switch handle this? Well it does, but maybe it won't last the spec'd number of cycles?
    Or, does the 125 VAC rating mean it can handle a lot more at 5 V? I'm not sure...
    Anyway, I hope you find a good SMT switch, because I may use it, if it works...
    I think I'd leave off the switch entirely, like with the Quickstart... Or else, just leave the pads to mount it, unpopulated...
  • cavelambcavelamb Posts: 724
    edited 2012-03-29 16:33
    Worth the added cost - in my humble opinion.
    edited 2012-03-29 17:34
    Took another stroll through Digikey and I think Martin picked out a good switch.
    You pay a hefty price to get something rated for more that 300 mA it seems...
  • jazzedjazzed Posts: 11,803
    edited 2012-03-29 19:20
    Rayman wrote: »
    I've used the through-hole version of that switch. It seems pretty solid except that the top plate can pop off.
    edited 2012-04-02 10:57
    Attached is a first draft Diptrace layout.
    Changes made:
    • Power switch to SMT
    • Reset switch to PTH. (Holes for either straight or right angle.)
    • Added 150 ohm resistors to RX/TX between Propeller and FT232.
    • Added single 'activity' LED to USB circuit.
    • Changed uSD card pull-ups to SIP socket.
    • Added reset pins to lower header.
    • Adjusted signal traces to 10/10 mil
    • Enlarged a few power traces.
    • Increased via sizes on power nets.
    • Added pads for SMT electrolytic caps while keeping holes for TH caps.
    ppusb.zip
  • TubularTubular Posts: 4,771
    edited 2012-04-02 14:19
    Martin (not Jazzed),
    Why not add the reset pin between P31 and Vss, as well as/instead of P0 and Vss?
    edited 2012-04-02 14:34
    Tubular wrote: »
    Jazzed,
    Tubular (not Pedward,)
    The idea was to provide a little bit of keying to help prevent boards from being plugged in backwards. Nothing is set in stone at this point.
  • pedwardpedward Posts: 1,642
    edited 2012-04-02 14:44
    Pedward,
    LOL! The PropKey must've been on your mind!
    edited 2012-04-02 14:49
    LOL, sorry Martin got your post mixed with the one immediately above it. It's early here, no coffee yet.
    Ok, so keying is perhaps a good idea. Is there a reason to put the reset pin near P0, rather than P31?
    edited 2012-04-02 15:16
    Reset by P31 is better isn't it? Let's you plug in a PropPlug, if you fry the USB chip...
    edited 2012-04-02 17:40
    Rayman wrote: »
    Oh that's right, we talked about that already. Durr :innocent:
    edited 2012-04-02 18:16
    I got a question, right now I don't bring 28-31 out to the pin header on the PropKey because those are consumed by peripherals. Now that I have a uSD socket, there are 4 pins used by that, with pullups. Do you think I should expose the 4 uSD pins on the socket/header or the 4 other pins?
    EDIT: oooh, I got an idea, I'll bring the 4 uSD pins out under where the uSD plugs in and expose the other 4 on the standard header. If you use a uSD, you don't use the pins, but if you use the pins, the uSD isn't plugged in!
    edited 2012-04-02 18:35
    pedward wrote: »
    That makes sense. And sometimes you want to mount a SD or uSD socket near the edge of an enclosure. You could see if its possible to take vss/vdd too to make it really easy
    edited 2012-04-02 20:08
    If i was a diptrace user I might be able to look at this. Print to PDF ?
    Changes made:
    ppusb.zip
    The middle three words seem to be missing. <-- edited.
    edited 2012-04-02 20:34
    Here's a pdf. The scaling is slightly less than 100% (at least when I print it out. Believe the correct board size is 2.8" x 2.5")
    Jazzed, what do you mean about the middle three words missing?
    edited 2012-04-02 21:00
    Tubular wrote: »
    Thanks Tubular. Seems my brain is on holiday today ....
    edited 2012-04-02 22:25
    Hi guys, I did some layout changes to the PropKey, to include the p28-p31 pins on the layout. I'm really on the fence about this change, since the previous layout is a lot cleaner and less crowded. I was hoping you guys might be able to take a quick comparison look and give me your thoughts in that thread.
    edited 2012-04-05 21:36
    Minor update. Moved the reset header to the proper location and connected the uSD socket to 16-19.
    (This PDF is sans copper pour for clarity.)
    ppusb_20120406.pdf
    edited 2012-04-06 00:05
    With your layout change the pinouts/usage are identical between the PropKey and what you've done. Did you move the uSD to 16-19 so the first 16 port pins are contiguous?
    edited 2012-04-06 00:08
    Martin, can I talk you into moving SD back to P0..P3? I think all of my shields use the upper row of pins...
    Actually, I bet all existing shields leave P0..P3 alone, expecting SD there...
    Also, you'd have software incompatibility with all the existing Prop Platfrom USB code...
    edited 2012-04-06 00:28
    It could be routed both ways, with a jumper block to select the pins. I felt there was a real tangible benefit to having p0-p15 available and contiguous, for various interfacing reasons.
  • g3cwig3cwi Posts: 262
    edited 2012-04-06 02:19
    If there is a re-design going on can I suggest:
    1) the inclusion of a protection diode on the power input. A Schottky diode will have a nice low forward volt drop. Reason: I blew a board up due to a faulty walwart that dumped 12V AC into it.
    2) moving the crystal further from the regulators. Reason: radio hams are using this board for transmitting and the regulators heat the crystal causing it to drift.
    Cheers
    Richard
    edited 2012-04-06 02:42
    g3cwi wrote: »
    Cheers
    Richard
    Who is doing transmitting with the Prop? The crystal drift should only be a problem with direct modulation.
    edited 2012-04-06 02:46
    edited 2012-04-06 09:08
    @Pedward. I suspected there would be some controversy over moving the SD card. I was a bit hesitant myself. I had been mulling over using this (or something similar) and a single jumper.
    The options I see are
    1. Leave it alone
    2. Switch it permanently to 16-19
    3. Use the 4PDT analog switch
    4. Use a 3x4 block of solder jumpers in a 4PDT arrangement.
      (Cheap, but more difficult for the user and requires extra step in mfg to set a default.)
    5. Use a 3x4 male header with 4 movable shunts.
      (Huge, may not be room.)
    @g3cwi, wouldn't it be a better solution to move the heat away from the crystal instead of the other way around? A simple external power supply fed into the V33 header would accomplish that. The diode is a good idea, I have a stock of those too.
    edited 2012-04-06 09:22
    In case you missed it, I vote #1 (leave it on P0..P3).
    As an aside, what I would do actually, is leave off the pull-up resistors. That way, it doesn't interfere if somebody want's to use P0..P15 for somethings special.
    Or, I see you have the pull-ups as something that could be soldered in after the fact...
    edited 2012-04-06 10:26
    For the xtal, I'd recommend simply making it a dual package layout so you could put a half-size can oscillator next to the chip.
    edited 2012-04-06 10:56
    @Rayman, I was planning on putting a sip socket at the RP1 location so that the pull-ups can be removed. However maybe just leaving it unpopulated would be better. I've never had any problems without pull-ups.
    edited 2012-04-06 11:00
    Somebody said (cluso maybe?) it's actually better without the pullups because there's a way to detect the presense of the card using one of the pins...
    edited 2012-04-06 11:34
    ppusb_20120406.pdf
    Excellent. Without these changes, may as well not do another board.
