Sticker Design Contest - win a PropBOE: Smart Sticker for Dumb Cable (veho360) - Page 3 — Parallax Forums
135
    edited 2012-03-28 00:37
    Here's my contribution:
    The idea is that the label, with peel-off backing can be taped to the Veho360 box, or just included loose in the shipment. Once the user trims off the top part, he can peel off the backing and stick it to the cable.
    500 x 189 - 15K
  • bsnutbsnut Posts: 521
    edited 2012-03-28 01:23
    Phil,
    I see a winner with this one
  • John BoardJohn Board Posts: 371
    edited 2012-03-28 01:43
    With all my youthful enthusiasim and determination to win I am going to design a ton of stickers! Surely you will be able to find something you like out of the ones that I'm gonna make!
  • pedwardpedward Posts: 1,642
    edited 2012-03-28 03:01
    Here's my entry, it's a play on engrish and adequately expresses the stupidity of the chinese supplier (or dumb designer that said "yeah, we only need power").
    I can provide as PDF or Open Office Draw format.
    a%3E
    edited 2012-03-28 03:04
    Here's my first lot! Remember, they are all 2" x 1". They *should* fit within what you need. If there are any you like, but they are not quite right, just tell me and I'll tweak them to your satisfaction ;)
    They are also all .png files:
    Heh.. I'm getting into the swing of making these... I foresee a good 10+ more to come...
    Note: Not all of them are my original idea, i.e. "Step 1: Plug both ends.." that one was from the first poster's comment!
    [FONT=arial, sans-serif]
    -John
    [/FONT]
    601 x 301 - 82K
    600 x 300 - 52K
    600 x 300 - 63K
    600 x 300 - 54K
    600 x 300 - 46K
    600 x 300 - 59K
    600 x 300 - 69K
    600 x 300 - 68K
    600 x 300 - 118K
    edited 2012-03-28 03:06
    pedward wrote: »
    a>
    Darn! That is a good one. I am now afraid of loosing!
    -John
    edited 2012-03-28 03:08
    John Board wrote: »
    -John
    I glad someone found it humorous! :)
    edited 2012-03-28 03:15
    Well, never to fear, I'm currently "pirating" your sticker idea, but changing the font...
    edited 2012-03-28 04:35
    +1 For Phil's.
    edited 2012-03-28 04:38
    Think about it... It wouldn't work...
    Never the less, its a clever idea.
  • doggiedocdoggiedoc Posts: 2,246
    edited 2012-03-28 04:50
    @John Board - Actually it could work but would require Parallax staff to trim the backing from each label by hand so the the adhesive under the cut away section was still intact. That would likely triple or even quadruple the man-hours required to apply the labels.
    edited 2012-03-28 05:06
    doggiedoc wrote: »
    They can have them printed with the backing already split. I really think they need to do something other than a sticker that says throw it away. It sends the message that they made you pay for something you didn't need.
    I also think they need to include a proper USB cable for programming, and it should have a tag identifying it as the proper cable for programming.
    The current plan has a user getting a cable they are told to throw away, yet has no cable to do what they need.
    Think of it as providing a "Positive" solution, versus a "Negative" solution.
    "Don't use that" doesn't give the user what they need, "Use this" does.
    C.W.
  • schillschill Posts: 741
    edited 2012-03-28 05:31
    I think you should forget the sticker completely. You have a group of enthusiastic Parallax fans showing up there in a couple weeks for the robotics and expo. Make them do some work.
    Make everyone who shows up open at least one package and remove or swap out the cable or they can't attend. If they work on more than one package, they get other benefits. You could have different levels. If they do enough, they get to meet MattG, Ken, Chip, etc. Whoever does the most gets a free Prop BOE.
    You'll probably have plenty of kids there who would do it just to see who could do the most in 15 minutes.
    You will need to stock up on round clear stickers to reseal the packages.
    (By the way, none of this is motivated by the fact that I had to cancel my plans to show up for UPEW.)
    edited 2012-03-28 06:39
    "Pay to come to our expo, and get put to work! Bring your kids! Fun for the whole family! Spend hours of fun repacking speakers!"
    edited 2012-03-28 07:41
    I like roboworkshops NOTICE with a smaller diagram of Tracy's without the wording in black
    Perhaps the wording could be...
    The included USB cable is for charging theVeho Speakers.
    This cable lacks the wires to do communications, so it will not work with your PropBOE, or any other USB device.
    edited 2012-03-28 08:00
    @Phil: Regardless if you win or not, I'm printing this and putting it on mine.
    edited 2012-03-28 08:47
    Winner to be announced at 1:07 PM TODAY...
    -Temporary Holder of (1) Prop BoE
    edited 2012-03-28 09:13
    Here is what I mean by the heat shrink tag. This started as 1/2" tubing and a sharpie, and that slips over the mini-USB and shrinks down to a secure marker.
    For preprinted lengths, three lines at most for impact as a reminder.
    Power!
    Shrink on cable
    only!
    576 x 172 - 25K
  • WBA ConsultingWBA Consulting Posts: 2,937
    edited 2012-03-28 09:35
    Matt/Ken, I have two rolls left from an 8 roll pack of Zebra 18928 labels that can be donated for this if needed. They were excessed from inventory about 2 years ago and I hung on to them because they are perfect size for propeller pinout stickers. I was working on a project to use a propeller board to send serial data to a Zebra printer with these labels loaded. Then, at the expo, an attendee could push a button and have a propeller print it's own label! Just never got around to finishing the project.
  • Wa_MoWa_Mo Posts: 17
    edited 2012-03-28 10:23
    I still think that my idea is the best :cool:
    I modified it ever so slightly :
    It may not be exactly humorous but it has the advantage of being multi-lingual.
    And in any case, who wants to read a lengthy report on a small label ?
    edited 2012-03-28 10:31
    I'll submit one more version:
    400 x 300 - 15K
    edited 2012-03-28 13:09
    Bidding is Closed....Judges are now going into deliberation...
    -Judge MattG
    edited 2012-03-28 14:55
    Judges are evenly split thus far... 9 judges, 9 differing opinions...
    -Chief Justice MattG
    edited 2012-03-28 15:02
    Pick me! Pick me! Pick me!
    @WhateverYourNameWhichICan'tCurrentlyRemember: As you said, it is possible to print them, then have the Parallax staff cut the back... but... also as you said, it would quadrouple the production time... not really worth it...
    (I'm getting desperate and trying anything now!)
    I would have put in some more designs.. but it so happens that while I was asleep o'er here in Aust. you guys had all day to be making good stickers :/
    edited 2012-03-28 15:20
    I don't know about it's size... but I think that one is pretty good ;)
    @Phil: If it could work, I think that one would be great too
  • Ken GraceyKen Gracey Posts: 7,412
    edited 2012-03-28 15:51
    MattG, MattG! One benefit of crowd-sourcing is to save money, but this is getting expensive. And the winner is?
    edited 2012-03-28 15:56
    They're all winners! Everyone who submitted gets a shiny new car!
    I'll bring a bunch of Hot Wheels to Expo. Winners get first pick!
    edited 2012-03-28 16:39
    The suspense is killing me!
  • idbruceidbruce Posts: 6,197
    edited 2012-03-28 17:00
    Crack that whip Ken!
    278 x 273 - 15K
    edited 2012-03-28 17:04
    These are the last 2!
    600 x 300 - 39K
    599 x 299 - 247K
