Problem - EasyBT-001 - Commands
I have an EasyBT Bluetooth Module EasyBT-001
I have made a connection using my Laptop and the module to my PIC16F877A
and it worked fine.
But now I want to, say change its name, or search for another EasyBT
I alerady know how the command is made and have read the user manual
If I understood it correctly, when the bluetooth is ON, and not yet have made a connection, it is supposed to be in the Idel, Automatic mode
so the UART is already in the "Command Mode"
But when I send a command, it dose not confirm or even done
Like when I cahnge the name it dose not change nor it cinfirm
I already checked that the bluetooth module is not connected to any other devices
So it it supposed to be in the Idel Automatic mode
What I am doing wrong so for?
Please Help, and THANKS in advance
and it worked fine.
Thanks for your replay
and yes I am sure, it is sendinig and receiving correct data
to and from the PC and I even excuted compled funtions
But still I can't figured it out
The command format said to have (Little_Endian) format, that's means the order of bits ti to be sent from Least to Most
So my question now, is the End delimiter is the least byte so I have to send it first??
I dose not make any sense!!
