excel help
I am trying my best to plot a function in excel. Can someone give me an example?
I want to plot these data using a transverse equation. Most of the variables will be static yet I want to be able to view the changes.
Starting at row 1 column A
With the equation
[TABLE="width: 128"] [TR] [TD="width: 64"]Vin[/TD] [TD="width: 64, align: right"]2.5[/TD] [/TR] [TR] [TD]Rf[/TD] [TD="align: right"]15[/TD] [/TR] [TR] [TD]Rc[/TD] [TD="align: right"]15[/TD] [/TR] [TR] [TD]Vref[/TD] [TD="align: right"]2.5[/TD] [/TR] [TR] [TD]Vout[/TD] [TD="align: right"]2.5[/TD] [/TR] [/TABLE]
With the equation
=(-B1 * (B2/B3) )+(B4 *((B2+B3)/B3))
Arrange your data on the spreadsheet so the two data sets are side by side (x and y), select the data, click the graphing wizard icon and use a X,U scatter plot.
You could have any of the values in your equation be the dependent ("X") value but you'll probably need to use a different graph for each dependent value. The other values in your equation would be treated as constants.
EDIT: Here is spreadsheet with some VBA code to vary the Rf Vin value and the chart will reflect the new value.
Option Explicit Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long) Private Sub CommandButton1_Click() Dim i As Single Dim temp As Single Range("b1").Select ActiveCell.Interior.Color = RGB(204, 153, 204) temp = Range("b1").Value For i = 0.5 To 3 Step 0.25 Range("b1").Value = i ActiveSheet.Calculate Sleep 500 Next ActiveCell.EntireRow.Interior.ColorIndex = xlColorIndexNone MsgBox "Done" Range("b1").Value = temp 'restore original value ActiveSheet.Calculate End SubYou can only make a two dimensional plot with Excel (as far as I know). You can have multiple data sets ploted on the same graph but I don't think you can graph your function with multiple changing variables.
Here's my attempt at plotting some data.
The above is the graph of the result based on two different changing variables (but only one changing variable per graph).
I used one graph with points and the other with just a line for some variety. Many of the data sets aren't very interesting since they just produce a horizontal line.
I'm not sure what she is looking for either, but this version has two scrollbars to control Vin and Rc.
More scrollbars could be added...
That's very cool. I don't think I've seen scroll bars used like that in Excel before.
I've often wanted to graph equations that use more than one dependent variable. It's seems very awkward to have to make a different graph for each variable being changed.
Ron Czapala,
Wow that is a cool feature using the scroll bars like that.
Duane Degn,
You have the correct plot.
If I could use Ron's scroll feature and Duane's plot this might work.
Thanks guys.
Bits,
I'm glad you found it useful. I really don't use Excel a lot so it was an interesting challenge - the Excel Object Model is complex.
I tweaked the VBA code in post #10 to handle clicking the arrows on the scroll bars in addition to the slider,
and if you change the values in a cell, the scollbar reflects the new value.
The scrollbars MAX/MIN properties should be set appropriately - I multiplied/divided them by 10 in the code so values could be adjusted to one decimal position.
Here is the code:
Option Explicit Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long) Private Sub CommandButton1_Click() Dim i As Single Dim temp As Single Range("b1").Select ActiveCell.Interior.Color = RGB(204, 153, 204) temp = Range("b1").Value For i = 0.5 To 3 Step 0.25 Range("b1").Value = i ActiveSheet.Calculate Sleep 500 Next ActiveCell.EntireRow.Interior.ColorIndex = xlColorIndexNone MsgBox "Done" Range("b1").Value = temp 'restore original value ActiveSheet.Calculate End Sub Private Sub ScrollBar1_Change() Range("b1") = ScrollBar1.Value / 10 End Sub Private Sub ScrollBar1_Scroll() Range("b1") = ScrollBar1.Value / 10 End Sub Private Sub ScrollBar2_Change() Range("b3") = ScrollBar2.Value / 10 End Sub Private Sub ScrollBar2_Scroll() Range("b3") = ScrollBar2.Value / 10 End Sub Private Sub Worksheet_Activate() ScrollBar1.Value = Range("b1") * 10 ScrollBar2.Value = Range("b3") * 10 MsgBox ("help") End Sub Private Sub Worksheet_Calculate() ' MsgBox ("calc") End Sub Private Sub Worksheet_Change(ByVal Target As Range) On Error Resume Next ' MsgBox (Target.Address) Select Case Target.Address Case "$B$1" ScrollBar1.Value = Range("b1") * 10 Case "$B$3" ScrollBar2.Value = Range("b3") * 10 End Select End SubI modified the code to create the same data and chart three different ways.
In one the cell names are hardcoded (e,g. "A1").
The second uses a for..next loop and uses the format "Range(Cells(x,y),Cells(x,y)).Select"
The third uses a for..next loop but builds the cell name as a string and uses the format "Range(varname).Select"
You could write code to vary your Vin, Rf, etc values and calculate the Vout value and put them in a range of cells, then dynamically create the appropriate type of chart.
Option Explicit Private Sub CommandButton1_Click() ' createColumnChart3 ' createColumnChart3 createColumnChart3 MsgBox ("Done") End Sub Sub createColumnChart() Dim myChart As Chart Range("A1").Select ActiveCell.Value = "Chart Data 1" Range("A2").Select ActiveCell.Value = "1" Range("A3").Select ActiveCell.Value = "2" Range("A4").Select ActiveCell.Value = "3" Range("A5").Select ActiveCell.Value = "4" Range("B1").Select ActiveCell.Value = "Chart Data 2" Range("B2").Select ActiveCell.Value = "5" Range("B3").Select ActiveCell.Value = "6" Range("B4").Select ActiveCell.Value = "7" Range("B5").Select ActiveCell.Value = "8" Range("B6").Select Set myChart = Charts.Add With myChart .Name = "Chart Data" .ChartType = xlColumnClustered .SetSourceData Source:=Sheets("Sheet1").Range("A1:B5"), PlotBy:=xlRows .HasTitle = True .ChartTitle.Text = "=Sheet1!R1C2" .Axes(xlCategory, xlPrimary).HasTitle = True .Axes(xlCategory, xlPrimary).AxisTitle.Characters.Text = "Chart Data 1" .Axes(xlValue, xlPrimary).HasTitle = True .Axes(xlValue, xlPrimary).AxisTitle.Characters.Text = "Chart Data 2" End With End Sub Sub createColumnChart2() Dim myChart As Chart Dim i As Integer Range("A1").Select ActiveCell.Value = "Chart Data 1" For i = 2 To 5 Range(Cells(i, 1), Cells(i, 1)).Select ActiveCell.Value = i - 1 Next Range("B1").Select ActiveCell.Value = "Chart Data 2" For i = 2 To 5 Range(Cells(i, 2), Cells(i, 2)).Select ActiveCell.Value = i + 3 Next Range("B6").Select Set myChart = Charts.Add With myChart .Name = "Chart Data" .ChartType = xlColumnClustered .SetSourceData Source:=Sheets("Sheet1").Range("A1:B5"), PlotBy:=xlRows .HasTitle = True .ChartTitle.Text = "=Sheet1!R1C2" .Axes(xlCategory, xlPrimary).HasTitle = True .Axes(xlCategory, xlPrimary).AxisTitle.Characters.Text = "Chart Data 1" .Axes(xlValue, xlPrimary).HasTitle = True .Axes(xlValue, xlPrimary).AxisTitle.Characters.Text = "Chart Data 2" End With End Sub Sub createColumnChart3() Dim myChart As Chart Dim i As Integer Dim cellname As String Range("A1").Select ActiveCell.Value = "Chart Data 1" For i = 2 To 5 cellname = "A" & CStr(i) Range(cellname).Select ActiveCell.Value = i - 1 Next Range("B1").Select ActiveCell.Value = "Chart Data 2" For i = 2 To 5 cellname = "B" & CStr(i) Range(cellname).Select ActiveCell.Value = i + 3 Next Range("B6").Select Set myChart = Charts.Add With myChart .Name = "Chart Data" .ChartType = xlColumnClustered .SetSourceData Source:=Sheets("Sheet1").Range("A1:B5"), PlotBy:=xlRows .HasTitle = True .ChartTitle.Text = "=Sheet1!R1C2" .Axes(xlCategory, xlPrimary).HasTitle = True .Axes(xlCategory, xlPrimary).AxisTitle.Characters.Text = "Chart Data 1" .Axes(xlValue, xlPrimary).HasTitle = True .Axes(xlValue, xlPrimary).AxisTitle.Characters.Text = "Chart Data 2" End With End SubConstants: Rf = 15 Rc=15 & Vref=2.5
The Vin and Vout values are placed in the A & B columns and the chart is created.
(All data and chart are created by program code).
Option ExplicitPrivate Sub CommandButton1_Click() ' createColumnChart3 ' createColumnChart3 createColumnChart3 MsgBox ("Done") End Sub Sub createColumnChart3() Dim myChart As Chart Dim i As Integer Dim cellname As String Dim cRange As String Dim Vin As Single Dim Rf As Single Dim Rc As Single Dim Vref As Single Dim Vout As Single ClearChart Rf = 15 Rc = 15 Vref = 2.5 Range("B1").Select ActiveCell.Value = "Vout" Range("A1").Select ActiveCell.Value = "Vin" Vin = 1.5 i = 1 Do i = i + 1 cellname = "A" & CStr(i) Range(cellname).Select ActiveCell.Value = Vin Vout = (-Vin * (Rf / Rc)) + (Vref * ((Rf + Rc) / Rc)) cellname = "B" & CStr(i) Range(cellname).Select ActiveCell.Value = Vout Vin = Vin + 0.1 Loop Until Vin >= 5.5 cRange = "A2:B" & CStr(i) Range("A1").Select Set myChart = Charts.Add With myChart .Name = "Chart Data" .ChartType = xlXYScatter .SetSourceData Source:=Sheets("Sheet1").Range(cRange), PlotBy:=xlColumns .HasTitle = True .ChartTitle.Text = "Vout based on Vin from 1.5 to 5.5" .HasLegend = False .Axes(xlCategory, xlPrimary).HasTitle = True .Axes(xlCategory, xlPrimary).AxisTitle.Characters.Text = "Vout = (-Vin * (Rf / Rc)) + (Vref * ((Rf + Rc) / Rc))" ' .Axes(xlValue, xlPrimary).HasTitle = True ' .Axes(xlValue, xlPrimary).AxisTitle.Characters.Text = "Chart Data 2" End With End Sub Private Sub CommandButton2_Click() ClearChart End Sub Sub ClearChart() Dim i As Integer Worksheets("Sheet1").Columns(2).Clear 'Delete Worksheets("Sheet1").Columns(1).Clear 'Delete For i = 1 To Charts.Count If Charts(i).Name = "Chart Data" Then Application.DisplayAlerts = False ' Charts(i).ChartArea.Clear Charts(i).Delete Application.DisplayAlerts = True End If Next End Sub
