PropGCC-SimpleIDE - Page 3 — Parallax Forums
PropGCC-SimpleIDE
13567
  • jazzedjazzed Posts: 11,803
    edited 2012-02-18 07:56
    Rsadeika wrote: »
    Still getting the "failed to open" error.
    Do you see this file in your explorer window? C:/Documents and Settings/Ray/My Documents/MyProgs/CC++/PropUI/a.out
    Do you have google+ or yahoo messenger? It would be easier to resolve this via chat. Send me a PM.
  • JonnyMacJonnyMac Posts: 9,584
    edited 2012-02-19 07:39
    Steve,
    Again, I really appreciate that you've done this -- I just have to catch up on my knowledge of C so that I can translate the dozens of Spin objects I have, and it a way that makes sense to the C community.
    Q: Would it be possible to add a tab size to the properties dialog? I find four spaces per tab a bit unwieldy for my liking. I would love to use two.
    edited 2012-02-19 09:11
    JonnyMac wrote: »
    Steve,
    Hi Jon, I was thinking about adding a tabbed pane to the properties dialog for this and other things. The IDE converts all tabs to 4 spaces now. Please use the space bar for less than 4 spaces until I have time to add this. Some other issues like the terminal problem are a higher priority at the moment.
  • Tony B.Tony B. Posts: 356
    edited 2012-02-19 17:10
    jazzed wrote: »
    Hi All.
    Version 0_3_3 of SimpleIDE is now posted: http://code.google.com/p/propside/downloads/list
    Please uninstall the old program before installing this one. The name was changed by request.
    This version mainly fixes the loader hang that everyone has seen. Here is the fixed issue list.
    1
    Defect
    IDE stalls while loader running. Performance
    5
    Enhanc
    User requests number of bytes for image size.
    6
    Defect
    Compiler properties dialog title wrong
    8
    Defect
    Some syntax highlighting
    12
    Defect
    "New" then "Save" file doesn't work.
    Please verify these issues are fixed so I can close them.
    I'm still having trouble with the serial port close eating CPU.
    If you see the CPU usage jump just click the connect button twice.
    This is a big problem, and I'm considering a different approach to fix it.
    @JonnyMac, Glad to see the IDE is helpful. I'm anxious to help with any questions.
    --Steve
    Steve I tested this version 0_3_4 on my Win 7 i7 6G machine. Install went without incident. Tested hello.c on Protoboard, Spin Stamp, Quickstart board. Worked just fine showing results in terminal. Loaded very quickly. Defects 1, 6, 12 were fixed for me. Never noticed defect 8 and enhancement 5 worked as well.
    Like Jon I had issues with the terminal. When I clicked OK or used the red X to close it down it didn't close all the way. By this I mean the window disappeared, but the terminal button remained in the down position and stopped tool tips from showing and when I clicked a menu item an outline of the drop down menu would show but nothing in it. If I moved the mouse to an adjacent menu item the menu would show correctly. If I moved back to the original selected menu item then it would show correctly. When I closed and restarted SIDE the menu and tooltips worked just fine, but I hadn't used the terminal. Just had an idea. Will see if the terminal close from this error state if I unplug the board.
    Also if I opened a new file and saved it it didn't appear in the recently opened file area on the File menu.
    Hope this helps and I will continue to learn and work with SIDE and C programing.
    Thanks for the work!
    Tony
    edited 2012-02-19 17:23
    Steve,
    Just tried building the hello.c by changing Memory Mode from Cog to LMM. The program size went from 1,960 to 14,352. That's almost half of the available Hub ram correct? Am I doing something wrong? Do I have something wrong in my numbers or my understanding of how LMM works. 14,352 seems like a lot of bytes for a simple program.
    Tony
    edited 2012-02-19 18:13
    Hi Tony,
    Thanks for your very detailed report above. I especially appreciate your verifying bug fixes.
    I'm still slogging away at the terminal close CPU hog issue. I figured out why some characters
    are missing from the terminal and I could post a SimpleIDE.exe update here if that would help.
    You can select the Simple Printf option in the IDE to get a smaller image from GCC.
    We are using a standard C library compliant and thread safe printf by default. That takes a lot of code.
    The Simple Printf option is not fully compliant and not thread safe.
    The limits of Simple Printf are described here: http://propgcc.googlecode.com/hg/doc/Library.html#printf
    We can always use the Spin-like functions for printing and they do save code memory to a point.
    Hope this helps.
    --Steve
    Tony B. wrote: »
    Steve,
    Tony
  • denominatordenominator Posts: 242
    edited 2012-02-20 15:19
    Tony B. wrote: »
    Steve,
    Tony
    As Steve mentioned, compiling with Simple Printf saves a bunch of space (it should reduce the code size from about 14K to about 8K). Considering the 2.5K minimum overhead for the LMM kernel and C runtime, the extra overhead of of 5.5K for basic a printf still seems like a lot, especially if you're not using all the bells and whistles of printf.
    You can get the overhead down to about 1K by using an even simpler (though still not thread-safe) printf(). Here is the trick:
    The library code up on Google (at http://code.google.com/p/propgcc/source/browse/lib/cog) contains two C source files that don't seem to be included in the library: cogserial.c and miniprintf.c. Grab the code from inside these files and combine it to form two new files:
    tinyprintf.h:
    extern unsigned int _rxpin;
    extern unsigned int _txpin;
    extern unsigned int _baud;
    int printf(const char *fmt, ...);
    tinyprintf.c
     * very simple printf, adapted from one written by me
     * for the MiNT OS long ago
     * placed in the public domain
     *   - Eric Smith
    #include <stdarg.h>
    #include <cog.h>
    #include "tinyprintf.h"
    #define _WaitCnt(a,b) __builtin_propeller_waitcnt(a,b)
    /* globals that the loader may change; these represent the default
     * pins to use
    unsigned int _rxpin = 31;
    unsigned int _txpin = 30;
    unsigned int _baud = 115200;
    unsigned int _bitcycles;
    int putchar(int origval)
      int value = origval;
      int i;
      int txmask = (1<<_txpin);
      int bitcycles;
      int waitcycles;
      if (origval == '\n')
        putchar('\r');
      _DIRA |= txmask;
      _OUTA |= txmask;
      if (_bitcycles == 0)
        _bitcycles = _clkfreq / _baud;
      bitcycles = _bitcycles;
      waitcycles = _CNT + bitcycles;
      value = (value | 256) << 1;
      for (i = 0; i < 10; i++)
          waitcycles = _WaitCnt(waitcycles, bitcycles);
          if (value & 1)
            _OUTA |= txmask;
          else
            _OUTA &= ~txmask;
          value >>= 1;
      return origval;
     * very simple printf -- just understands a few format features
    static int
    PUTC(int c) {
        putchar(c);
        return 1;
    static int
    PUTS(const char *s) {
        int r = 0;
        while (*s) {
          putchar(*s++);
          r++;
        return r;
    static int
    PUTL(unsigned long u, int base, int width, int fill_char)
        int r = 0;
        static char obuf[32];
        char *t;
        t = obuf;
        do {
            *t++ = "0123456789abcdef"[u % base];
            u /= base;
            width--;
        } while (u > 0);
        while (width-- > 0) {
            putchar(fill_char);
            r++;
        while (t != obuf) {
            putchar(*--t);
            r++;
        return r;
    static int
    _doprnt( const char *fmt, va_list args )
        char c, fill_char;
        char *s_arg;
        int i_arg;
        long l_arg;
        int width;
        int outbytes = 0;
        while( (c = *fmt++) != 0 ) {
            if (c != '%') {
                outbytes += PUTC(c);
                continue;
            c = *fmt++;
            width = 0;
            fill_char = ' ';
            if (c == '0') fill_char = '0';
            while (c && isdigit(c)) {
                width = 10*width + (c-'0');
                c = *fmt++;
            if (!c) break;
            switch (c) {
            case '%':
                break;
            case 'c':
                i_arg = va_arg(args, int);
                outbytes += PUTC(i_arg);
                break;
            case 's':
                s_arg = va_arg(args, char *);
                outbytes += PUTS(s_arg);
                break;
            case 'd':
            case 'u':
                l_arg = va_arg(args, int);
                if (l_arg < 0 && c == 'd') {
                    outbytes += PUTC('-');
                    width--;
                    l_arg = -l_arg;
                outbytes += PUTL(l_arg, 10, width, fill_char);
                break;
            case 'x':
                    l_arg = va_arg(args, unsigned int);
                outbytes += PUTL(l_arg, 16, width, fill_char);
                break;
        return outbytes;
        va_list args;
        int r;
        va_start(args, fmt);
        r = _doprnt(fmt, args);
        va_end(args);
        return r;
    Add these files to your project, and change your #include <stdio.h> to #include "tinyprintf.h". A simple "Hello World" program should now be just about 3.5K, which seems much more reasonable!
    edited 2012-02-20 22:13
    Good news everyone! (Dr. Farnsworth - Futurama)
    I've made good progress on the IDE serial troubles and compile time troubles too.
    I'll make a release in the morning.
    I'll post a zip on this thread for those who have Admin privileges to replace the main SimpleIDE.exe program.
    ... Add these files to your project. A simple "Hello World" program should now be just about 3.5K, which seems much more reasonable!
    That's pretty cool. :cool: I forgot about those. Thanks.
    edited 2012-02-21 05:44
    Thanks denominator for the ideas. Since I'm new to using C I was hoping there was another way to print that didn't use so much of the memory resources.
    Tony
    edited 2012-02-21 15:27
    Hello.
    I've been testing a new SimpleIDE.exe for windows. It has several enhancements.
    The biggest improvements are in compile-time and load time IDE performance.
    This should fix the problem where the terminal can leave the program running on exit.
    A small compromise comes though for slower machines like my netbook.
    That is if you click Play and the terminal window appears and the output is very fast
    it is possible that the window will stall for a moment if you try to drag it around.
    I've added an Enable/Disable button to the terminal. Clicking it when it says Disable
    will disconnect the terminal but it will not reset the Propeller board.
    I'm not ready to upload a new package yet. It would be very useful for everyone to test
    this SimpleIDE.exe by copying it to your C:\Program Files\SimpleIDE\bin folder.
    The program does not include several of the other requested improvements.
    This SimpleIDE.exe should solve many hang problems for people who have already
    installed the 72MB package. Please test it when you can.
    --Steve
    edited 2012-02-21 19:43
    Seems to be working much better in my old WinXP system. Thanks, Steve.
    edited 2012-02-21 20:12
    It seems very snappy (objective performance terminology) on my big laptop. I'll try it on my netbook tomorrow.
    Thanks for all the hard work, it's becoming a favorite tool.
    edited 2012-02-21 20:29
    Indeed. Those using the Arduino wanting to try the Propeller now have a tool that should work for them.
    edited 2012-02-21 20:42
    Thanks guys!
    On another note (not C#!) ....
    I've been using the SimpleIDE in my virtual-box Debian Linux tonight.
    David reports his Mac was able to compile and download a toggle demo.
    These are early results. Don't get too excited yet!
    --Steve
    edited 2012-02-22 00:56
    Too late!! I got excited!!
    Let me know if you need Linux or OS X guinea pigs.
  • RsadeikaRsadeika Posts: 3,877
    edited 2012-02-22 03:15
    In general, the new version seems to be working much better. But, a couple of problems, I tried the keyboard program, in COG mode it works as expected. In LMM mode, their is no improvement, still have to press at least four keypresses before it comes up on the screen.
    So, I am not sure if this is still a problem with the terminal, or something has to be changed in the keyboard program.
    The other problem, my perception, when you close a file, using the X tab, and save a new file which you just started, the save part works great, but does not create an .side file. Even using F4, and Set Project has no affect, you have to close the file, and then reopen it, at which point the project gets created. It seems like a lot of extra steps to get an .side file.
    Ray
    edited 2012-02-22 06:09
    mindrobots wrote: »
    I have Steve's IDE mostly working under Mac OS X. There are some issues with paths because the Mac OS doesn't display the /opt directory in its file browser but that's not really a SimpleIDE problem as much as a Mac installation problem. I think we'll probably have to move the GCC install to /Applications/Parallax rather than /opt on the Mac.
  • trodosstrodoss Posts: 577
    edited 2012-02-22 07:06
    @Jazzed,
    I just had a chance to try he new executable and it is much faster at compiling (has not stalled yet). I was finally able to build vgademo without having to use propeller-elf-gcc.exe on the command line. Also, I really appreciate it showing the bytes compiled. Thanks!
    The serial window seems to work better as well. A few things that might be nice in the serial window:
    Baud Rate Select
    DTR/RTS options, Parity, etc.
    Echo toggle (on/off)
    Ability to save a log file
    ..those are not at all critical, considering that tools like PST (or HyperTerminal if non Win7, etc.) could be used for that sort of thing. If it is like other IDE's with a serial terminal built-in it is for quick verification (or simple serial demos).
    Thanks for your hard work!
    edited 2012-02-22 09:17
    trodoss wrote: »
    @Jazzed,
    I just had a chance to try he new executable and it is much faster at compiling (has not stalled yet). I was finally able to build vgademo without having to use propeller-elf-gcc.exe on the command line. Also, I really appreciate it showing the bytes compiled. Thanks! ....
    Excellent! I'm glad this is working out better for you and everyone else so far.
    "SimpleIDE" for the user should mean very few adjustments if any. It should just work "as is" out of the box.
    However, I understand the compulsion to be more generic and have planned an advanced button for preferences similar to PST. Baud rate and other items will be in the dialog rather than cluttering the terminal. There will not be any concept of wait for port to be available before connecting. I'll probably change Disable/Enable to a graphic Connected/Disconnected button. Most likely I'll add a "power reset switch" graphic that toggles DTR.
    Achieving stability is the most important factor right now.
    Thanks.
    --Steve
    edited 2012-02-22 09:41
    jazzed wrote: »
    Right on! Definately focus on stability, and your "target platform" (PropBOE ?) first. SCOPE CREEP BAD!
    Provided that all of the example code matches the default baud rate and that you are using it communicate with the device you are programming (a safe assumption) you do not need to support serial port selection, or baud rate selection. Those sorts of things could easily be relegated to configuration (if they are even added at all).
    If you didn't want to increase the complexity of the serial monitor in the code, you could (eventually) add the ability to launch an external serial terminal/monitor instead of the built-in terminal and save having to build/support that sort of functionality (as part of advanced settings).
    edited 2012-02-22 15:51
    Here's another SimpleIDE.exe[1] for testing.
    I got tired of opening another editor for Find/Replace and there was a request. So, the new .exe adds a find/replace feature: see Menu->Edit->Find Replace or Ctrl-R.Currently find is case insensitive and will replace any text. Will add case and word only later.
    I've also made Find Ctrl-F pick up any highlighted word and put it into the find text box.Find/Replace has more power than find.As always please point out any problems.
    --Steve
    Notes:
    1. You must have previously installed a package to use the .exe. I'm cleaning up some old copies now to save bytes.
    2. The COGID highlight is doctored since print-screen didn't capture it.
    trodoss wrote: »
    You must have clicked on the Help->About link :)
    Rsadeika wrote: »
    Ray, I'm looking into this. I'll be adding some real project manager stuff (Project New, Open, Save, Recent, etc...), so most of these concerns will go away.
    915 x 604 - 144K
    edited 2012-02-23 06:54
    Not sure if this is already mentioned or not but I keep running into a bug where when I open and close the Serial terminal after downloading a program to the Prop, the IDE seems to go into 'super-slow-mo' and menus don't work. When I check processes then the IDE will be eating my CPU. I have to kill the process and start over. Seems to happen pretty frequently.
    I'm using a Netbook with 2G Ram and Win7 32bit.
    Otherwise I'm pretty elated to see my prop running C++ code!
    edited 2012-02-23 07:09
    photomankc wrote: »
    Hi photomankc.
    Do you see this behavior with the SimpleIDE.exe posted above in message #82? The .exe in the 72MB package is less reliable.
    --Steve
    edited 2012-02-23 08:47
    Steve,
    Yes, I am using that version. I downloaded it and replaced the original EXE in the program 'bin' folder.
    -Kyle
    edited 2012-02-23 09:01
    Kyle,
    Do you happen to have the exact steps to re-create this issue? I used a normal Propeller Proto Board for testing this.
    I tried:
    1) Open "SimpleIDE.exe"
    2) Select "File...Open" and selected "hello\hello.side" from the "Open File Dialog"
    3) Selected the "Run" icon. (application compiled and uploaded)
    4) Selected the "Port Status" icon
    5) (watched the terminal for a bit) Selected the red "X" at the top (without using "Clear," "Disable," or "OK" in the window)
    ...and did not have a slowness issue, even after repeating the process several times. If you have Process Explorer installed, you might try running that and see which process(es) are taking up time on your machine. If there is a specific path through the application/pattern that is triggering this, and it can be narrowed down, I am sure it will help Jazzed with the issue.
    --trodoss
    edited 2012-02-23 09:34
    I'll try to get that for you all. I've just bumped into in putzing around with it so I was not focused on repeating it. I'll see if can make it happen again and give you the steps involved when it happens and dig a little deeper into what it's doing.
    edited 2012-02-23 10:12
    photomankc wrote: »
    I think all one needs to do is open the hello demo (one that repeats printing hello world number), then click the blue debug button or F8. The terminal is the main issue. I had to trade the possibility of a zombie program (responsive until dead, then eating brain/CPU time) for a somewhat CPU hogging non-zombie. I'll see what I can do - this is a key problem.
    edited 2012-02-23 13:14
    Ok, here's another SimpleIDE.exe to try.
    I've used it on my 1.6GHz Atom, 1GB RAM, WinXP Netbook (and other machines).
    It's working much, much better for me now.
    Try this program first and then see how it works as you reduce the waitcnt time.
     * This demo uses waitcnt instead of sleep so it will fit in a COG.
     * It also repeats printing every 200ms and prints the iteration.
     * Some computers may not be fast enough for the terminal to catch
     * the serial input after loading the Propeller, so you may not see
     * "Hello World 1", but you will see something on the terminal.
    #include <stdio.h>
    #include <propeller.h>
    int main(void)
        int n = 1;
        while(1) {
            waitcnt(CLKFREQ/5+CNT);
            //waitcnt(CLKFREQ/50+CNT);   // faster
            //waitcnt(CLKFREQ/500+CNT);  // murderous
            printf("Hello World %d\n", n);
            n++;
        return 0;
    --Steve
    edited 2012-02-23 19:50
    I loaded the new .exe on my I7 8GB laptop......
    sometimes, murderous is hell! :lol:
    Hello World 5646 Hello World 5647
     Hello World 5648
     Hello World 5649
     Hell
     Hello World 5770
     Hello World 5771
     Hello World 5772
    Works well, now I need to try it on my Netbook.
    edited 2012-02-23 23:09
    mindrobots wrote: »
    Hi Rick! Thanks for the feedback - hope to have more before making yet another 72MB package.
    I've been testing on my I7 and Netbook with waitcnt(CLKFREQ/5000+CNT); // redrum-helter-skelter
    Don't move the window when it's so busy ;)
    I noticed Disable/Enable is broken and have a fix for it.
