Working on Servo/Sensor board for Propeller Platform: Comments requested - Page 2 — Parallax Forums
2»
  • SONIC the HedgehogSONIC the Hedgehog Posts: 321
    edited 2012-02-09 19:25
    Wow! That looks fantastic!
  • John AbshierJohn Abshier Posts: 1,116
    edited 2012-02-10 09:10
    The three way power selection is cool! When can we preorder.
    John Abshier
    edited 2012-02-10 09:12
    Now that's where it's at!
    edited 2012-02-10 09:21
    John Abshier
    @John, I'm trying to work in Jon's cap idea. Looks like it should sit across Vin/Gnd.
    OBC
    723 x 541 - 107K
    edited 2012-02-10 09:23
    @John, I'm trying to work in Jon's cap idea. Looks like it should sit across Vin/Gnd. Running out of room again.
    OBC
    Didn't you say something about there being slots or holes that were designed for connecting other boards together?
    edited 2012-02-10 09:33
    I like having some connectors on the edge of the board (now on the right) which allow me to connect a ribbon cable or another board using male/female pin headers. It's common on many PCBs, just not the Protoplus, so I'm implemented it here.
    OBC
    edited 2012-02-10 09:37
    OBC
    See I was just going at maybe if you're running out of room, you can get another board and do what you need to do, the add more pin headers and daisy chain if you would have too.
    edited 2012-02-10 10:47
    Hey Sonic,
    I'm not sure you know that this sits on top of the Propeller Platform, and another board can be added on top of that for more I/O's. Many I/O's abound.
    If you already knew that, then tell me to shut up. :)
    Jim
    edited 2012-02-10 10:59
    Hey Sonic,
    Jim
    Oh, I i didn't realize it sat on top of the board. Well that changes then what I said because it would already have the necessary holes for daisy chaining. Well alright, thanks a bunch Jim.
    edited 2012-02-10 11:03
    Think Shields. :)
    edited 2012-02-10 11:05
    @Publison By board I meant propeller platform. Im using one of those from gadget gangster actually! And I didn't realize he was using the protoplus module either. So he's using that with the servo board?
    edited 2012-02-10 11:24
    It looks like it is an add-on the the Propeller Platform, the Proto Plus is an option if you need addition real estate on top of the Servo/Sesor board.
    Jim
    edited 2012-02-10 11:28
    Publison wrote: »
    Jim
    So is the servo board bigger than the platform or is it one of those square sized modules?
    edited 2012-02-10 12:20
    ..Nods..
    Yes, the servo/sensor board is designed to be longer on one end so it can be sandwiched between other boards and still get your servos/sensors plugged in.
    You're getting the picture..
    OBC
    edited 2012-02-10 12:23
    ..Nods..
    OBC
    Hey I am getting the picture! It makes sense now. So did you get the kinks out?
    edited 2012-02-10 12:29
    Yes, It's under a "peer review" right now and then it'll be ready to send out to production to have the PCBs made.
    OBC
    723 x 543 - 105K
    711 x 530 - 87K
    edited 2012-02-10 12:30
    OBC
    Epicness!
    edited 2012-02-10 13:22
    OBC
    Jeff,
    On the back side of the board, I see mostly two island and a couple of three island thermals for ground. A four island thermal would be better and wouldn't take up any more space.
    Jim
  • JonnyMacJonnyMac Posts: 9,804
    edited 2012-02-10 14:59
    Since you have your board done and a large copper fill on the bottom, you can put text and graphics into the mask layer so that it shows up as silver against green -- looks really cool.
    edited 2012-02-10 16:41
    @Jon,
    That's the last bit I'm working on now... Great suggestion.. thanks!
    Oh, and I'm adding a thick line on the top mask which indicates the power rail so it's visible.
    OBC
