QuickStart Board PASM Toggle with Buttons
doggiedoc
A while back I was working through the manual and the assembly language example. Tonight I modified the original AssemblyToggle.spin to work with the QS board and it built in buttons. The new code toggles the LED at P16 slowly ramping down and up the toggle rate. Pressing any of the buttons on the QS Board changes the active LED to the corresponding LED.
Forgive me if someone else has already done something like this.
{{ QS_Buttons_ AssemblyToggle.spin
alternate version of AsseblyToggle using QS board's buttons to select a pin to toggle
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
long thePin, theCog
PUB Main | sameVal
thePin := 16
theCog := cognew (@Toggle, @thePin) 'start with LED on P16
repeat
sameVal := thePin 'set var for checking if thePin value has changed
GetButton 'check buttons
if sameVal <> thePin 'if thePin value has changed b/c a button press
cogstop (theCog) 'then stop the current cog and start again with new pin
waitcnt(clkfreq / 10 + cnt)
PUB GetButton | buttonPressed
dira [7..0]~
buttonPressed := ina [7..0]
case buttonPressed
%10000000:
thePin := 23
%01000000:
thePin := 22
%00100000:
thePin := 21
%00010000:
thePin := 20
%00001000:
thePin := 19
%00000100:
thePin := 18
%00000010:
thePin := 17
%00000001:
thePin := 16
DAT
{Toggle LED on selected pin}
org 0 'Begin at Cog RAM addr 0
Toggle rdlong ScratchMem, par
shl Pin, ScratchMem
mov dira, Pin 'Set Pin to output
mov ScratchMem, cnt 'Calculate delay time
add ScratchMem, #9 'Set minimum delay here
Increment waitcnt ScratchMem, Delay 'Wait
add Delay, IncValue 'Increment Delay value
max Delay, MaxDelay wc 'Set Maximum Delay
xor outa, Pin 'Toggle Pin
if_nc jmp #Decrement 'jump to Decrement loop
jmp #Increment
Decrement waitcnt ScratchMem, Delay 'Wait
sub Delay, IncValue 'Increment Delay value
min Delay, IncValue wc 'Set minimum Delay
if_c jmp #Increment 'jump to increment loop
jmp #Decrement
Pin long 1 'Pin variable
Delay long 1_000_000 'Clock cycles to delay
IncValue long 50_000 'increment value
MaxDelay long 20_000_000 'maximum delay
ScratchMem res 1 'System Counter Workspace
That's it, I'm too tired now.
Paul
Neat little program Paul!
Too bad your patient's paws are too big to keep them occupied in the waiting room
