First Trial of a C - Interface to the VGA 64 Driver from OBEX
Hi,
Try to built a C interface to the VGA64 driver from OBEX
( the origin author will forgive me ;-)
Basicly works and my first goal was a closer understand of the mailbox interface to pasm code.
Reinhard
/** Trial of a C - Interface to the VGA 64 Driver from OBEX VGA64 6 Bits Per Pixel Engine ORIGIN: Author: Kwabena W. Agyeman Updated: 11/17/2010 Designed For: P8X32A Version: 1.0 Copyright (c) 2010 Kwabena W. Agyeman -------------------------------------------------- Code from PUB PIXEngineStart(pinGroup) is go to main very experimental, basicly works */ #include <stdlib.h> #include <propeller.h> //////////////////////////////////////////////////////////////////////// // Mailbox //////////////////////////////////////////////////////////////////////// static unsigned int directionState; static unsigned int videoState; static unsigned int frequencyState; static unsigned int * displayPtr; static unsigned int *syncIndicatorAdress; static unsigned int *displayIndicatorAdress; //////////////////////////////////////////////////////////////////////// unsigned int DISPLAY_BUFFER[(160 * 120) / 4]; unsigned int sync_indi; unsigned int display_indi; //////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////// unsigned int _rotl( unsigned int value, int shift) { if ((shift &= sizeof(value)*8 - 1) == 0) return value; return (value << shift) | (value >> (sizeof(value)*8 - shift)); } //////////////////////////////////////////////////////////////////////// int start(unsigned int *ptr) { extern unsigned int binary_vga64_pix_dat_start[]; return cognew(&binary_vga64_pix_dat_start, ptr); } //////////////////////////////////////////////////////////////////////// void usleep(int t) { if(t < 10) // very small t values will cause a hang return; // don't bother function delay is likely enough waitcnt((CLKFREQ/1000000)*t+CNT); } //////////////////////////////////////////////////////////////////////// void main (void) { int tmp,i,x,y; // Preset the mailbox parameters directionState = 0xFF << 16; videoState = (0x300000FF | (2 << 9)); tmp = (25175000 + 1600) / 4; frequencyState = 1 ; for(i = 0; i < 32; i++) { tmp = tmp << 1; frequencyState = _rotl(frequencyState,1); if(tmp >= _clkfreq) { tmp = tmp - _clkfreq; frequencyState += 1; } } displayPtr = DISPLAY_BUFFER; syncIndicatorAdress = &sync_indi; displayIndicatorAdress = &display_indi; // start the Driver start(&directionState); while(1) { for (y = 0; y < 120;y++) { for (x = 0; x < 160;x++) { while((0x80 >> 5) & sync_indi); //DISPLAY_BUFFER[x + 160 * y] = 0xFF; // set a white pixel at (x,y) *(unsigned char *)(DISPLAY_BUFFER + x + 160 * y) = 0x30; // Lightgreen } } } } ////////////////////////////////////////////////////////////////////////
Reinhard
there is a bug in my program near the DISPLAY_BUFFER size
seems a problem with int/byte access.
work on it, sorry
Reinhard
If I come to the rotl operator I searched for builtins, but do not found.
So I get the rotl function with a short web search and take it as it is, without censorious check.
Heater, what you write make sense, I changed it.
On the screen I see the green stripes, with black spaces between.
My expectation is a full green screen.
I guess the problem is my write into the DISPLAY_BUFFER is different to the spin code:
displayBuffer.byte[.....] I think only 1/4 from Buffer is used by my C program ?!
Try tomorrow a solution.
Reinhard
found " Nyamekye " also in the origin VGA - sourcecode
hi Kye, nice to meet you
feel a little bit like this ...
http://german.about.com/library/blgzauberl.htm
Reinhard
if I replace the line:
DISPLAY_BUFFER[x + 160 * y] = 0x30; with DISPLAY_BUFFER[x + 160 * y] = 0x30303030;
the screen is filled full green,
because the pasm read a long ( I mean this is a int32 in C )
and if I write only 8 Bit into Buffer, the remaining 24 Bits are unused.
So with a little workaround in the interface, the proper setting can done.
Reinhard
Oddly enough there isn't; but the compiler is smart enough to compile into a single rotl instruction.
Eric
Was a long way, but now I have what I want.
A simple Graphic Interface , like at the good old TurboC Times.
Reinhard
have now combined the sigma_delta driver with the vga driver, similar to the microphoneToVGA Demo in the spin example package from parallax.
Basicly works, but I have no idea how to clear the screen.
thanks for any suggestions
Reinhard
Hi Reinhard! Happy New Year.
Some drivers use double buffering. That is, divide a big buffer in half to make 2 screens, draw to each screen, and just change the pointer to display a new screen. The graphics demo does that.
Cheers.
--Steve
Oh, man. I did the exact same thing when I was learning 32-bit x86 assembly code when I was a teenager. I loaded a 32-bit register with a byte value and expected 32-bit memcpy()-style code to "just work" and got vertical stripes down the screen.
I get to study the graphic demos with double buffering !
@plainsteve: Hi, was also a learning process for me.
Interesting to see on neptun are the same pitfalls . . .
Reinhard
