First Trial of a C - Interface to the VGA 64 Driver from OBEX — Parallax Forums
ReinhardReinhard Posts: 489
edited 2012-01-04 02:00 in Propeller 1
Try to built a C interface to the VGA64 driver from OBEX
( the origin author will forgive me ;-)
Basicly works and my first goal was a closer understand of the mailbox interface to pasm code.
    VGA64 6 Bits Per Pixel Engine
ORIGIN:
    Author: Kwabena W. Agyeman
    Updated: 11/17/2010
    Designed For: P8X32A
    Version: 1.0
    Copyright (c) 2010 Kwabena W. Agyeman
    Code from PUB PIXEngineStart(pinGroup)
    is go to main
    very experimental, basicly works
#include <stdlib.h>
#include <propeller.h>
//  Mailbox
static unsigned int directionState;
static unsigned int videoState;
static unsigned int frequencyState;
static unsigned int * displayPtr;
static unsigned int *syncIndicatorAdress;
static unsigned int *displayIndicatorAdress;
unsigned int DISPLAY_BUFFER[(160 * 120) / 4];
unsigned int sync_indi;
unsigned int display_indi;
unsigned int _rotl( unsigned int value, int shift)
    if ((shift &= sizeof(value)*8 - 1) == 0)
      return value;
    return (value << shift) | (value >> (sizeof(value)*8 - shift));
int start(unsigned int *ptr)
    extern unsigned int binary_vga64_pix_dat_start[];
    return cognew(&binary_vga64_pix_dat_start, ptr);
void usleep(int t)
    if(t < 10)  // very small t values will cause a hang
        return; // don't bother function delay is likely enough
    waitcnt((CLKFREQ/1000000)*t+CNT);
void main (void)
    int tmp,i,x,y;
    // Preset the mailbox parameters
    directionState = 0xFF << 16;
    videoState = (0x300000FF | (2 << 9));
    tmp = (25175000 + 1600) / 4;
    frequencyState = 1 ;
    for(i = 0; i < 32; i++)
        tmp = tmp << 1;
        frequencyState = _rotl(frequencyState,1);
        if(tmp >= _clkfreq)
            tmp = tmp - _clkfreq;
            frequencyState += 1;
    displayPtr = DISPLAY_BUFFER;
    syncIndicatorAdress = &sync_indi;
    displayIndicatorAdress = &display_indi;
    // start the Driver
    start(&directionState);
    while(1)
        for (y = 0; y < 120;y++)
          for (x = 0; x < 160;x++)
            while((0x80 >> 5) & sync_indi);
            //DISPLAY_BUFFER[x + 160 * y] = 0xFF; // set a white pixel at (x,y)
            *(unsigned char *)(DISPLAY_BUFFER + x + 160 * y) = 0x30; // Lightgreen
Reinhard
  • ReinhardReinhard Posts: 489
    edited 2011-12-30 12:28
    ups, I was to fast....
    there is a bug in my program near the DISPLAY_BUFFER size
    seems a problem with int/byte access.
    work on it, sorry
    Reinhard
  • KyeKye Posts: 2,200
    edited 2011-12-30 13:22
    Shouldn't there be a builtin rotl function?
    edited 2011-12-30 14:11
    @kye, that surprised me to as I've been trying to learn c and try to be helpful to the propgcc project. Before the holidays, I was trying to port some I2C routines and needed the rotr and rotl functions and all my searching led to user provided functions like Reinhard used. It seems to be a common standard solution that everybody provides in their own code.
    edited 2011-12-30 14:22
    Shouldn't that:
    be:
     if ((shift &= sizeof(value)*4 - 1) == 0)
    As value is an int which is 32 bits which is 4 bytes.
    edited 2011-12-30 15:57
    I translate the spin code step by step into C.
    If I come to the rotl operator I searched for builtins, but do not found.
    So I get the rotl function with a short web search and take it as it is, without censorious check.
    Heater, what you write make sense, I changed it.
    On the screen I see the green stripes, with black spaces between.
    My expectation is a full green screen.
    I guess the problem is my write into the DISPLAY_BUFFER is different to the spin code:
    displayBuffer.byte[.....] I think only 1/4 from Buffer is used by my C program ?!
    Try tomorrow a solution.
    Reinhard
    edited 2011-12-30 19:53
    Kye wrote: »
    found " Nyamekye " also in the origin VGA - sourcecode
    hi Kye, nice to meet you
    feel a little bit like this ...
    http://german.about.com/library/blgzauberl.htm
    Reinhard
    edited 2012-01-01 05:52
    seems my theory is right
    if I replace the line:
    DISPLAY_BUFFER[x + 160 * y] = 0x30; with DISPLAY_BUFFER[x + 160 * y] = 0x30303030;
    the screen is filled full green,
    because the pasm read a long ( I mean this is a int32 in C )
    and if I write only 8 Bit into Buffer, the remaining 24 Bits are unused.
    So with a little workaround in the interface, the proper setting can done.
    Reinhard
  • ersmithersmith Posts: 6,286
    edited 2012-01-02 05:07
    Kye wrote: »
    Oddly enough there isn't; but the compiler is smart enough to compile
    a = (a << b) | (a >> (32-b))
    into a single rotl instruction.
    Eric
    edited 2012-01-03 07:11
    Ready.
    Was a long way, but now I have what I want.
    A simple Graphic Interface , like at the good old TurboC Times.
      VGA Graphic Demo with Parallax VGA_512x384_Bitmap Interface
      for DemoBoard Wiring
      reimay / January 2012
    //  Mailbox
    static unsigned int sync;
    static unsigned int reg_dira;
    static unsigned int reg_vcfg;
    static unsigned int * pixel_ptr;
    static unsigned short * color_ptr;
    unsigned int   PIXEL_BUFFER[6144];
    unsigned short COLOR_BUFFER[192];
    void plot( unsigned int x, unsigned int y)
     int tmp = x % 32;
     if(x >= 0 && x < 512 && y >= 0 && y < 384)
       PIXEL_BUFFER[(x/32) + (y*16)] |=  1<<tmp;
        extern unsigned int binary_vga_dat_start[];
        return cognew(&binary_vga_dat_start, ptr);
    void main (void)
      unsigned int z,i,x,y;
      sync = 0;
     reg_dira = 0x00FF0000;
     reg_vcfg = 0x200000FF + (16 << 6);
      // Fill Color Buffer
     for(i = 0; i < 192; i++)
      COLOR_BUFFER[i] = 0x2804 ;
      pixel_ptr = PIXEL_BUFFER;
     color_ptr = COLOR_BUFFER;
     // start the Driver
     start(&sync);
      Graphic Demo :
      plot the sierpinsky triangel with binary adresses
      for( y = 0; y <= 255; y++)
        for(x = 0;x <= y;x++)
         z = x & ( y -x) ;
         if(z==0)
          plot(x+ (256-y/2),y+30);
    Reinhard
    edited 2012-01-03 14:04
    have now combined the sigma_delta driver with the vga driver, similar to the microphoneToVGA Demo in the spin example package from parallax.
    Basicly works, but I have no idea how to clear the screen.
    thanks for any suggestions
    Reinhard
  • jazzedjazzed Posts: 11,803
    edited 2012-01-03 15:33
    Reinhard wrote: »
    Hi Reinhard! Happy New Year.
    Some drivers use double buffering. That is, divide a big buffer in half to make 2 screens, draw to each screen, and just change the pointer to display a new screen. The graphics demo does that.
    Cheers.
    --Steve
  • plainsteveplainsteve Posts: 34
    edited 2012-01-03 19:00
    Oh, man. I did the exact same thing when I was learning 32-bit x86 assembly code when I was a teenager. I loaded a 32-bit register with a byte value and expected 32-bit memcpy()-style code to "just work" and got vertical stripes down the screen. :D Thanks, Reinhard, for digging up a fun memory; I haven't thought about those times in a while.
    @jazzed: Hi Steve, thank's for your response.
    I get to study the graphic demos with double buffering !
    @plainsteve: Hi, was also a learning process for me.
    Interesting to see on neptun are the same pitfalls . . . :smile:
    Reinhard
