"Graphical" solve of nonlinear differentialequation with the propeller
Reinhard
Hi,
if someone not interesst in math, skip it ;-))
I think about a alternative solution to do the numerical integration with integer by use the counter ( PSHA += FREQA) property.
Will try it, but now I have go to work .
best regards
Reinhard
Solve the Differential Equation x'(t) = r * x(t) * ( 1 - x(t) )
with Euler method and send x(t) as Analog out to P0
(RC lowpass recommended )
(P0 observed with an oszi)
#include <propeller.h>
#include <math.h>
#define P0 1<<0
#define CRTMODE (1<<28) + (1<<27) + 0
#define scale 16777216 // 2^32 / 256
typedef float (*Fct)(float x);
void msleep(int t)
waitcnt((CLKFREQ/1000)*t+CNT);
float Log_EQ (float x)
float dt = 0.001;
float r = 0.7;
return x + dt * r * (1.0 - x);
void main ()
int duty;
Fct eulerstep;
float x;
int it;
DIRA |= P0; // P0 = OUTPUT
CTRA = CRTMODE; // set Counter Mode: DUTY SINGLE ENDED
while(1)
x = 0.1;
eulerstep = Log_EQ;
for (it = 0; it <= 4000; it ++)
x = eulerstep(x);
duty = (int)(x * 255);
FRQA = (duty * scale); // set FRQA Register
FRQA = 0;
msleep(100);
best regards
Reinhard
(It's great to see that someone is testing our floating point code, too. :-))
Eric
here is the fixed point version (much smaller and faster)
/* A Simple C program to illustrate the use of Fixed Point Operations */ /* Solve the Differential Equation x'(t) = r * x(t) * ( 1 - x(t) ) with Euler method and send x(t) as Analog out to P0 (RC lowpass recommended ) (P0 observed with an oszi) compile & load with: propeller-elf-gcc -mlmm -Os -o euler_fix.elf euler_fix.c -lm propeller-load -pcom7 -r euler_fix.elf ------------------------------------------------------------------ */ #include <propeller.h> #include <math.h> #define P0 1<<0 #define CRTMODE (1<<28) + (1<<27) + 0 /* DEFINE THE MACROS */ /* The basic operations perfomed on two numbers a and b of fixed point q format returning the answer in q format */ #define FADD(a,b) ((a)+(b)) #define FSUB(a,b) ((a)-(b)) #define FMUL(a,b,q) (((a)*(b))>>(q)) #define FDIV(a,b,q) (((a)<<(q))/(b)) /* The basic operations where a is of fixed point q format and b is an integer */ #define FADDI(a,b,q) ((a)+((b)<<(q))) #define FSUBI(a,b,q) ((a)-((b)<<(q))) #define FMULI(a,b) ((a)*(b)) #define FDIVI(a,b) ((a)/(b)) /* convert a from q1 format to q2 format */ #define FCONV(a, q1, q2) (((q2)>(q1)) ? (a)<<((q2)-(q1)) : (a)>>((q1)-(q2))) /* the general operation between a in q1 format and b in q2 format returning the result in q3 format */ #define FADDG(a,b,q1,q2,q3) (FCONV(a,q1,q3)+FCONV(b,q2,q3)) #define FSUBG(a,b,q1,q2,q3) (FCONV(a,q1,q3)-FCONV(b,q2,q3)) #define FMULG(a,b,q1,q2,q3) FCONV((a)*(b), (q1)+(q2), q3) #define FDIVG(a,b,q1,q2,q3) (FCONV(a, q1, (q2)+(q3))/(b)) /* convert to and from floating point */ #define TOFIX(d, q) ((int)( (d)*(double)(1<<(q)) )) #define TOFLT(a, q) ( (double)(a) / (double)(1<<(q)) ) void msleep(int t) { waitcnt((CLKFREQ/1000)*t+CNT); } void main () { int duty; float x; int it; float dt = 0.001; float r = 0.7; int q = 14; int DT,R,X,ONE,T0,T1,T2,T3; DIRA |= P0; // P0 = OUTPUT CTRA = CRTMODE; // set Counter Mode: DUTY SINGLE ENDED while(1) { x = 0.1; DT = TOFIX(dt,q); R = TOFIX(r,q); ONE = TOFIX(1.0,q); X = TOFIX(x,q); for (it = 0; it <= 4000; it ++) { T3 = FSUB(ONE,X); // perform x = x + dt * r * (1.0 - x) T2 = FMUL(R,T3,q); // with fixed point operations T1 = FMUL(DT,T2,q); T0 = FADD(X,T1); X = T0; duty = X; FRQA = (duty << 18); // set FRQA Register in full range msleep(1); // sleep a while, avoid be to fast for the RC Lowpass on P0 ! } FRQA = 0; msleep(100); } }used macros found on ARM website:
Propeller Version 1 on com7
Writing 588 bytes to Propeller RAM.
Verifying ... Upload OK!
/* no comment */ ;-)
Thank you for this tip, because I'm very lazy, I use it.
Reinhard
Your program looks very nice. It makes me wonder how much can be packed into a cog C program. It would be interesting to have a contest to see who could produce the largest or most interesting C program that fits in a cog.
Dave
Back to the thread, Reinhard, thank you for posting this! It is neat to see complex math being done on the Propeller. Complex being more than just algebra
