Looking for a prop board
DiverBob
I need a prop board with on board ADC, minimum of 4 channels. Power input should be capable of hadling between 9 and 14 vdc. The width if the board can be no more than 2.75 inches, length is a bit more flexible.
I wanted to see if there is anything out there, otherwise I'll have to make my own (it's almost always cheaper to buy than design, test and build your own).
Any recommendations?
Bob
Bob
It will hold 2x 2 channel MCP3802 ADC with minor wire modifications.
The input regulator is rated from 4.5 to 15 VDC (or 1.5 to 3.9 VDC).
Will build and test one for you if you like.
Bob
Thanks for the info, do you have any specs and photos? What price are we talking about here?
Bob
