Looking for a prop board — Parallax Forums
DiverBobDiverBob Posts: 1,127
edited 2011-12-07 18:25 in Propeller 1
I need a prop board with on board ADC, minimum of 4 channels. Power input should be capable of hadling between 9 and 14 vdc. The width if the board can be no more than 2.75 inches, length is a bit more flexible.
I wanted to see if there is anything out there, otherwise I'll have to make my own (it's almost always cheaper to buy than design, test and build your own).
Any recommendations?
Bob
  • blittledblittled Posts: 697
    edited 2011-12-05 14:37
    Have you looked at Martin Hodge's Propeller ASC http://www.1mgh.com/ ?
  • jazzedjazzed Posts: 11,803
    edited 2011-12-05 14:49
    I have a DIP32 size Propeller board that has 2 SO8 footprints.
    It will hold 2x 2 channel MCP3802 ADC with minor wire modifications.
    The input regulator is rated from 4.5 to 15 VDC (or 1.5 to 3.9 VDC).
    Will build and test one for you if you like.
  • DiverBobDiverBob Posts: 1,127
    edited 2011-12-07 18:23
    blittled wrote: »
    thanks for the link, the8 channel ADC is a good thing as ivefound that I'll need additional inputs now. I do some more checking but this may work. I don't see a board dimension listed but the photo looks relatively small also
    Bob
    jazzed wrote: »
    Thanks for the info, do you have any specs and photos? What price are we talking about here?
    Bob
