Looking for ideas on how to locate a weld-seam on sheet metal... — Parallax Forums
MicksterMickster Posts: 2,898
edited 2011-11-23 19:21 in General Discussion
  • Optical is out, too many issues with ambient light, oil streaks, etc.
  • Needs to be non-contact
  • Some sort of technology that will pick up on the difference between the steel and the weld.
Thanks for any suggestions.
Mickster
    edited 2011-11-22 08:00
    ....hmmmmm (thinking out loud) - would there be a difference in magnetic properties between welded and non-welded steel that could be detected by a Hall effect device?
    edited 2011-11-22 08:14
    ...well, there you go!
    Interesting thread.
  • wjsteelewjsteele Posts: 697
    edited 2011-11-22 08:28
    If the weld was done right, you shouldn't be able to detect a difference! :-)
    However, we've used ultrasonic detectors quite successfully in the past.
    Bill
    edited 2011-11-22 08:46
    If anyone has an IEEE membership, there appears to be some information here:
    http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=104591
  • $WMc%$WMc% Posts: 1,884
    edited 2011-11-22 16:38
    I'm with Bill...U.T....utrasonic testing.
  • MicksterMickster Posts: 2,898
    edited 2011-11-22 17:39
    wjsteele wrote: »
    Bill
    Don't suppose you could recommend a particular detector, could you?
    Thanks again
    Mickster
    edited 2011-11-22 20:28
    wjsteele wrote: »
    Bill
    Interesting, but I thought that ultrasonic testing required some sort of contact interface. That is why the nasty feeling goop they use when an ultrasound is performed in medical applications. (for those into TMI.... that is also why you are not supposed to eat for a certain time prior to an exam..... the ultrasound waves can not penetrate pockets of bowel gas)
    As for other non-contact, I thought that magna-flux was good for ferous materials like engine heads (I know, old skool), not sure about aluminum though. Actually on an unfinished, but cleaned surface I would have guessed that optical would have been the best bet due to discoloration of metal caused by the welding temps. One possibility if non-contact is not absolutely out could be a set of calipers with a fairly tight tolerance that could pickup the difference in thickness between the welded area and the surrounding sheet metal ......
    Hot $41t here is a way to do it non contact and at speed....
    LASER:
    Use a laser at angle to the sheet metal as it passes under a line of one or more lasers and use the slight deflection of the laser as the metal passes under it. When the weld passes it there should be at least a tiny difference in the deflection angle of the laser such that a sensor could pick it up. You would have to make sure that there is enough tolerances to account for variations in the normal sheet metal. Perhaps average the value and assume the weld will cause a spike in the output as it passed under the laser.
    Frank
    edited 2011-11-23 01:35
    LASER:
    Frank
    Optical: Some of these welds are so good, they are less prominent than say, surface scratches, oil streaks,etc. In some cases we have to deal with aluminized material which is applied after the welding.
    Caliper: The weld is scarfed on both sides and in many cases very difficult to detect with the human finger.
    Mickster
  • idbruceidbruce Posts: 6,197
    edited 2011-11-23 03:04
    That is a very interesting question, especially with the stipulation of non-contact. I would be interested in knowing the answer when you discover it.
    Anyhow, I am just thinking out loud, since I am not expert or that experienced in this field. My assumption would be that the base metal and the joining metal would have different alloy make up or density. I would guess that an ultra-sensitive proximity switch or metal detector set at a proper distance to detect the different density or different alloy might do the trick.
    Bruce
    edited 2011-11-23 03:48
    idbruce wrote: »
    Hmmm definitely want it to be a Propeller-based solution though because I want to use the video capabilities, etc. I love the sound of what Cenlasoft has been doing but it sounds like he switched from eddy-current to US and I couldn't find any account for that in all his posts. Anyway I've PM'd him so hopefully I'll hear back.
    In the meantime, I'll look in to those Baluff sensors!
    Thank you!
    Mickster
    edited 2011-11-23 04:01
    Mickster wrote: »
    Mickster
    Guess I won't suggest laser and interferometry, slightest vibration and it's done with. Only non-contact left is very high resolution xray to detect the weld.
    While I was looking at the possibility of Xray methods, I came across this article; it may be of interest to you.
    Frank
    http://www.ndt.net/article/wcndt00/papers/idn573/idn573.htm
    A
    lso, check this one under xray diffraction.
    http://www.engineershandbook.com/MfgMethods/ndtrt.htm
