Parallax now selling Pololu Dual Motor Driver MC33926 board
I just checked the New Products listing and saw that Parallax is now selling the Dual Motor Driver MC33926
I used it in my Homemade Stingray project and was happy with it. I probably could have used a higher amp driver in case of motor stall but so far so good.
As I recall, there are a couple of ways to use PWM with this board.
I contacted Pololu and the configuration I used is:
- Jumpers connected on "D1" and "D2" (also "EN")
- PWM "IN1" or "IN2" depending on desired rotation direction
CORRECTIONI think I tried PWM on D2 but there were issues. Here is my post on the Pololu forum Dual MC33926 question
I think I tried PWM on IN1/IN2 but it would not with higher frequencies.
Thanks for the info and the link to Pololu support.
I am using IN1/IN2 to drive the motors with PWM. I have all of the D pins pulled low, per the datasheet. It works great at less than 16kHz, but acts unpredictably above that. Might be the wiring, or the counter I am using to drive the PWM - I haven't figured it out yet.
I haven't tried pulsing the D pins yet, but will give it a try. The braking could be helpful
I am using the PWM_32_V4 object http://obex.parallax.com/objects/467/
Not sure what frequency this results in...
period = 10000 PWM.Duty(M2in2_PIN,rampR,period) 'PWM in2
