OMG! QuadCopter Catches PingPong Balls — Parallax Forums
alex123alex123 Posts: 102
edited 2011-09-23 16:12 in General Discussion
That looks really neat but it makes me wonder if all the misses were just edited out.
http://www.youtube.com/watch?feature=player_embedded&v=dL_ZFSvLXlU
Compring to this just building a QuadCopter seems like a walk in the park...
  • RS_JimRS_Jim Posts: 1,775
    edited 2011-09-23 08:55
    Too bad that you have to be an IEEE member to see the math behind it. Looks like they maybe using a video camera to "see" the ball so that they can predict its flight. Humm, looks like a bit more math power than the propeller can muster! I did find his paper on the berkeley site! That certainly dovetails into the other thread about home automation. The math for the airconditioning control is not that onorous and could probably be done on a prop. With 10 to 15 minutes a lot of math could be performed even by the prop.
    Jim
  • sylvie369sylvie369 Posts: 1,622
    edited 2011-09-23 09:13
    The sensor detecting the ball is in the quadcopter? A white ball against white walls? Or is it getting information about the ball's flight from elsewhere?
    This kind of thing suggests that the future will look very little like the present. Very impressive.
    edited 2011-09-23 09:20
    It's using an array of cameras (mounted around the room) and a computer running all the calculations then sends control commands to the quadcopter.
    edited 2011-09-23 09:39
    Roy Eltham wrote: »
    I'm still impressed, but that explains quite a bit. Thanks.
    I would think the Kinectix (hows it spelt) concept will cheapen this kind of thing. Lots of future for these cheap concepts.
    Anyway, I am impressed.
