Amazing Suction Capacity @ Parallax
Hey Everybody!
Scott (our lead machinist) and I wanted to share a major success in our production methods today...
Our Router table (Haas SR100) has a 4x8 foot vacuum table capacity. We typically draw a vacuum with a significantly smaller vacuum pump than is normally used - we can do this by using non-porous spoil-boards and non-porous finished product material.
However, one of the issues that we run into is the requirement to *coax* into place the material as it is being "sucked" down by the vacuum pump. The volume (if you can call it that) of vacuum is typically quite small, which necessitates a larger pump.
Today we created a very large "vacuum reservoir", which as the video shows, makes the "suck-down" a no-hands, no extra weights, no muss, no fuss, event!
This may be boring to some of you, but it really is a cool addition to our "arsenal" of in-house capabilities :-)
Check it out:
This dramatically enhances our ability to produce (in this case) Madeusa and Eddie Robot Bases, and various "coming attractions", as well as our Solar Panels, etc.
-Matt
Check it out:
-Matt
/ducks
OBC
BTW, May the suck be with you always
I'm so glad you put "vacuum reservoir" in quotes! But -- seriously -- what else can you call it? I've got one of those in the trunk of my car, since vacuum is what operates the door locks, trunk lock, gas cap lock, engine shutoff, brake assist, and heaven knows what else. Pulling up a floor mat reveals tiny plastic hoses running everywhere. So I've faced the same dilemma when explaining it to people: what do you call the tank that "stores" the vacuum "supply" when the engine isn't running?
Cool video, BTW!
Now all you need is a fixture that you can set on top with a few heating elements to hold some plastic sheets and you should be able to do some cool vacuum forming projects....
Robert
@ Matt, Did you get all the sand out of everything yet? That stuff sticks to everything..
Wife says, its fire ring and chairs next time, Our treat..:)
-Tommy
@ Robert - My thoughts exactly! A very good, long time friend built his first vacuum forming machine in 1962 - He's still using it - he develops educational equipment for the UC Berkeley Lawrence Hall of Science...
I do see a Vacuum Former in Parallax's future :-)
@ Tommy -
Delightful time @ Pismo! Thanks for joining us :-) Next time? You're on!
And no. We still have sand everywhere - my wife's purse still has 1/2 cup, at least
@ the rest of you -
Yeah, you're all correct - in this case, we suck
-Matt
Thanks. Thanks a lot
-Matt
-Tommy
-Matt
(All: Hi Chrome user)
-Tor
That being a vacuum gauge, it actually measure how much nothing you have in the reservoir? Cool!
In this application it is obvious that the more nothing you have, the better
-Matt
Vs my roomba .
Peter ..
Just about every good airplane movie could have used one, in fact there is a scene in star wars that could have used the gauge tapper...
-Tommy
Nice cnc btw. very nice
Chewy! engage the gauge tapper! we're getting outa' here.
I'd call it a container of "anti-pressure"!
Somewhere on the 'net a cat picture gets posted.......
Kirk: Spock, get ready to charge the anti-pressure vessels!
Spock: Captain, that's illogical.
Kirk: Ok, then we'll discharge the anti-presure vessels.
Spock: Captain, that won;t work either.
Kirk: Damnit, Spock! I'm a thespian, not a physicist!
Seriously ... pumpkins? ... talk about a Pandora's box
