MTY - Robotic Puppet — Parallax Forums
MacTuxLinMacTuxLin Posts: 821
edited 2011-09-19 18:37 in Robotics
Done another module for our prop-powered controller. This time is a robotic puppet using our old ver2 proto-type board. Basically, once I touched the make-shift switch, it will start sensing all 16 servos & record to uSD. And when I touch the switch again, it will playback. This plus other modules will be included in our final version (finally...-_-"...), MTY Controller Lite, which is also ready for sale soon on our web-site (once its ready...-_-"...)
Pretty obvious I'm a lousy puppeteer ... :lol:
http://www.youtube.com/watch?v=51iDwJuMiQ8
    edited 2011-09-06 10:34
    Fantastic job! How much memory does that take to record such a sequence?
  • SapiehaSapieha Posts: 2,964
    edited 2011-09-06 13:01
    Hi.
    VERY NICE
    MacTuxLin wrote: »
  • MacTuxLinMacTuxLin Posts: 821
    edited 2011-09-06 18:00
    Thanks erco. That's about a 60 seconds motion capture & it takes 32k. I think the data could be further optimized but its way down my to-do list.
    Sapieha wrote: »
    Hi.
    VERY NICE
    Thanks Sapieha.
  • GeorgeCollinsGeorgeCollins Posts: 132
    edited 2011-09-09 19:57
    What kind of servos are you using on that robot? I was just wondering because besides Dynamixels, I didn't know what other kind of servos you could get position information form
  • BamseBamse Posts: 561
    edited 2011-09-18 13:18
    Awesome bot, I'm curious to about the servos, how do you get the position ?
    Bamse wrote: »
    Hey,
    Pardon the long delay due to work :depressed: These are a lesser-known wck servo from megabuilder. It is similar to ax-12 but instead of half-duplex, its a full duplex.
    Getting the position is the same as ax-12, by issuing command to retrieve the current position of each servo.
