MTY - Robotic Puppet
Done another module for our prop-powered controller. This time is a robotic puppet using our old ver2 proto-type board. Basically, once I touched the make-shift switch, it will start sensing all 16 servos & record to uSD. And when I touch the switch again, it will playback. This plus other modules will be included in our final version (finally...-_-"...), MTY Controller Lite, which is also ready for sale soon on our web-site (once its ready...-_-"...)
Pretty obvious I'm a lousy puppeteer ...
http://www.youtube.com/watch?v=51iDwJuMiQ8
VERY NICE
Thanks erco. That's about a 60 seconds motion capture & it takes 32k. I think the data could be further optimized but its way down my to-do list.
Thanks Sapieha.
Hey,
Pardon the long delay due to work :depressed: These are a lesser-known wck servo from megabuilder. It is similar to ax-12 but instead of half-duplex, its a full duplex.
Getting the position is the same as ax-12, by issuing command to retrieve the current position of each servo.
