Propplug to program BasicStamp1
Is it possible to modify a Propplug to program a BS1 Module?
My understanding is that it can be done but I wonder if I would damage the Propplug, plus it would be nice to know if someone has tried this before.
My computer only has USB ports and I don't have an adapter to use an RS232 or Parallel port over USB. I'd like to save the expense or buying an adapter if something I already own will work.
Thank you
Thank you
Heck, for $10 you can buy an old working 286 laptop with a direct-connection Parallel port, and program BS1s & BS2s in monochrome DOS!
I have an old Compaq 286 LTE which I use on rare occasions, it still works swimmingly. Parallax may not officially support the DOS editor any longer, but it was and remains quite stable & useful.
Erco, that is dedication!
Dedication? Twisted, more like it!
No, just common sense. You can't get a blue screen of death on a DOS monochrome LCD display!
This is my program
' {$STAMP BS1} ' {$PBASIC 1.0} Main: DEBUG CLS, "This is working " ' display PAUSE 50 ' short delay GOTO Main ' repeat forever END
Seems to me that a Spin Stamp, an inverter, and a tunnel diode might be used to generate antimatter. Could you please look into that next?
