Propeller Assembly for beginners - Page 10 — Parallax Forums
17810121329
  • HarpritHarprit Posts: 539
    edited 2011-08-09 19:11
    Thanks for the clarifications guys. I needed that.
    @Jazzed, of course we had gone over this before but I had a serious senior moment. Maybe it will stick this time.
    Harprit
    edited 2011-08-10 18:00
    Creating pulses or generating frequencies
    Here is about the fastest frequency you can generate in PASM. The signal will be outputted on pin 24. We can increase the frequency slightly by removing the NOP but then the on-off signals will not be the same length. The NOP in the loop is needed to compensate for the extra time it takes the routine to jump back to OUT1
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    VAR
      long  freq_gen
    PUB wavelength
    cognew(@prog_gen, @freq_gen)           'start new cog
    dat
                org        0
    prog_gen    mov        dira,     set_dira
    out1        mov        outa,     on
                nop
                mov        outa,     off
                jmp        #out1
    set_dira   long        %00000001_00000000_0000000_00000000
    on         long        %00000001_00000000_0000000_00000000
    off        long        %00000000_00000000_0000000_00000000
    We can decrease the frequency be adding delays.
    We will do that next time.
    HSS
    edited 2011-08-10 18:31
    Harprit wrote: »
    Not quite, current limit is clkfreq/8 (2 instructions) :)
  • jazzedjazzed Posts: 11,803
    edited 2011-08-10 20:29
    Don't forget to use the special registers CTRA, FRQA, etc... to generate even higher frequencies.
    Also VSCL, VCFG, & waitvid can be used for parallel/serial conversion.
    edited 2011-08-11 09:37
    Question for experts
    Why does
    mov    mem,   cnt
    wrlong   mem,  par
    work and
    wrlong   cnt,  par
    does not.
    I cannot find anything in the Prop manual that says that the counter cannot be written directly to PAR as a long.
    Harprit
  • tonyp12tonyp12 Posts: 1,951
    edited 2011-08-11 10:03
    Maybe it has do with that cnt can not be in the des field.
    Though in wrlong the dest field is used as the "source", it still reads from the cnt's shadow register.
    I think the assembler should give a waring anytime the special registers that should normaly not be in the dest field.
    edited 2011-08-11 10:12
    tonyp12 is correct :)
    Register CNT is readonly (practically speaking except for the "shadow").
    By having CNT be the destination "D" of "wrlong D, S" you are saying write to CNT.
    While this is not a bug, it is very annoying. You'll see the same problem with "wrlong INA, PAR".
    You can say "rdlong CNT, PAR" but that won't work either because CNT is readonly.
    You can say "rdlong OUTA, PAR" however.
    The only real hint about what is happening with this problem AFAIK comes from the Propeller Datasheet (v1.2) bottom of page 16 table Special Purpose Registers. Remember the Datasheet is a manual too :)
    Harprit wrote: »
    edited 2011-08-11 10:18
    Hmmmmmmmmmmmm
    That took me a day.
    H
    edited 2011-08-11 10:42
    I takes some time to get used to "shadow", call it ghost or overlapping.
    A special register like CNT, have kind of multiplexing gate depending if you have it in the Dest or Source field.
    So you have a single memory address but it have two different values in it.
    The dest field version (aka shadow) could be used as a free storage ram as it's not used anyway.
    This will work:
    mov cnt, cnt ' move the value of the running Counter to ram location of what cnt address represents.
    wrlong cnt, par ' the snap shoot of cnt above is moved to the hub address.
    edited 2011-08-11 11:02
    In a PASM book for beginners I would leave all talk of "shadow registers" to some later advanced chapter. Unless you have to say "don't do that" and then reference the advanced chapter.
    edited 2011-08-11 11:26
    Heater. wrote: »
    Indeed. Can't fault anyone for stumbling over the need for an explanation though :)
    edited 2011-08-11 11:41
    Jazzed,
    Indeed, and this is the brilliant concept of having a beginner in PASM writing a beginners book on PASM. All those "gotchas" that hang beginners up for hours and days can be pointed out along the way by the author who has recently been bitten by them. An expert old hand may well have forgotten such trip ups by the time he writes his book.
    All the best with this project Harprit.
    edited 2011-08-11 11:56
    Heater. wrote: »
    Jazzed,
    It's only brilliant (in a non-sarcastic sense) if it is properly critiqued, vetted, and serves the community positively.
    I won't repeat any of my other opinions in this area.
    I marvel at the usage of "brilliant" by some posters though.
    Some of the contexts are not even in urban dictionary.
    edited 2011-08-11 17:18
    @Heater
    I'm with you 100%. This is for beginners and though very valid points have been made by Steve and all, we need to keep it as simple and uncomplicated as I possibly can. After the beginners get their feet wet, they can discover all sorts of things. Maybe even read the manual and the data sheet! I myself have been through the data sheet a couple of times but would not say I have read it and it would be ridiculous to say that I understand it and even more so to say that I could get out of it what experienced programmers can. What you see in the forest is conditioned by what you have seen in other forests. I think jazzed has something like this to say at the end of every post.
    Book progress: As for the book, I think I can get it done now. I have spent a few days beating my head against the wall but I have also figured out how to look at what I want without a debugger! Now on its pretty much just slugging through the mud for me. I can see the other side of the swamp now. I kinda understand how I will do the stuff in PASM now. Besides I am getting great help and encouragement.
    Note to readers: I am kind of following the format of my SPIN book so when we get done we can actually compare the same or similar programs written in the two languages and see how much faster one is than the other etc etc.
    Will publish it electronically on the web. Taking advise now. Expect availability by the end of the year. Maybe!
    I'm on page 70 of about 250. It will go faster now.
    Present estimate and wild guess.
    Harprit.
    edited 2011-08-11 19:28
    Here is the code to add a delay between turning the signal on and turning it off. Thus changing the frequency.
    You change the value of 'deltime' to change the frequency.
    If 'deltime' is a voltage dependent, we have a voltage controlled oscillator.
    If it is a programmed function it will respond to any function.
    Next time we will add another cog to this program to read the frequency of this signal.
    The console displays the count and the delay number. The number is an arbitrary selection of 10_000 at this time
    CON
    var
      long  freq_gen
      long countup
    OBJ
      fds : "FullDuplexSerial"
    '+++++++++++++++++++++++++Cog 0+++++++++++++++++++++++++++++++++
    PUB wavelengths
    fds.start(31,30,0,115200)       'start console at 115200 for debug output
    dira := %00000000_10000000_00000000_00000000
    waitcnt(clkfreq/4+cnt)
      repeat                        'loop
        fds.tx($1)                  'home to 0,0
        fds.dec (countup)           'checks to see if cog is looping per Stephan
        fds.tx($0d)                 'new line
        fds.dec(freq_gen)           'print value or PAR as decimal
        fds.tx($0d)                 'space
        countup := countup + 1      'increment unused counter
        waitcnt(clkfreq/60+cnt)     'flicker free wait
    '++++++++++++++++++++++++++Cog 1++++++++++++++++++++++++++++++++
    dat
                org        0
    prog_gen    mov        dira,     set_dira  'to set directions
    out1        or         outa,     mask        'turn on pin
                call       #clkdelay           'wait
                andn       outa,     mask        'turn off pin
                wrlong     deltime,  par       'delay time
                jmp        #out1
    clkdelay    mov        time, deltime       'the delay subroutine, load deltime into time
    take4       sub        time, #1   wz       'sub 1 from time and set flag if 0
         if_nz  jmp        #take4              'if flag not 0 go back to take4
    clkdelay_ret           ret                 'return for delay subroutine
    deltime     long   10_000                'time of delay
    set_dira    long   %00000000_10000000_00000000_00000000
    mask        long   %00000000_10000000_00000000_00000000     'mask
    time       res     1
    Harprit.
    edited 2011-08-11 19:46
    About explaining things. An anecdote.
    He was known in the department as Quiet John. Quiet John Bardeen, the inventor of the transistor taught at the Uni of Ill, the same university where I did my graduate work. One of his doctoral students, a friend of mine told me that Quiet John would explain the most mundane things to you in the detail you needed without hesitation or talking down to you at your request. But he would do it only once! You were expected to pay full attention and understand it in one round. He had no patience with not paying close attention. (His first doctoral student is the inventor of the LED.) His two Nobel prizes were for work in physics (transistor, superconductivity) . He did not have a degree in physics.
    Harprit.
    edited 2011-08-11 21:07
    jazzed wrote: »
    No, it does not. Its the idea, not the book.
    H
    edited 2011-08-12 06:33
    Extending the program gives us the following code.
    The program adds a second PASM cog to read the wavelength being generated. You have to look at the INA register three times to get the wave length. It may be necessary to look at it four times. See question at end of listing.
    CON
    var
      long  freq_gen, freq_red
      long countup
    OBJ
    PUB wavelengths
    dira := %00000000_10000000_00000001_00000000
    cognew(@prog_red, @freq_red)           'start new cog
      repeat                        'loop
        fds.dec (countup)
        fds.tx($0d)                  'space
        fds.dec(freq_gen)              'print value as decimal
        fds.tx($0d)                  'space
        fds.dec(freq_red)              'print value as decimal
        fds.tx(" ")                  'new line
    dat
                org        0
    out1        or         outa,     on
                call       #clkdelay           'turn on pin
                andn       outa,     off
                call       #clkdelay
                wrlong     deltime,  par       'turn off pin
                jmp        #out1
    deltime    long   10_000                   'time of delay (constant for now)
    on         long   %00000000_10000000_00000000_00000000
    off        long   %00000000_10000000_00000000_00000000
    time       res     1
    '+++++++++++++++++++++++++++Cog 2++++++++++++++++++++++++++++++++
    dat
                org        0
    prog_red    mov    dira,  set_dira1      'to make sure pin 23 is an input
    out2        mov    temp,  ina            'look at INA register
                and    temp, mask23  wz      'look at only pin 23
        if_z    jmp     #out2                'stay here while it is low
                mov    mem,   cnt            'just turned high so read timer
    out3        mov    temp,  ina            'look at INA register
         if_nz   jmp    #out3                'stay here while high
    out4        mov    temp,  ina            'look at INA register
        if_z    jmp    #out4                 'stay here while low
                mov    mem1,   cnt           'just turned high so read timer
                sub    mem1, mem             'figure time interval
                wrlong   mem1,  par          'write it to PAR
                jmp    #out2                 'do it again
    set_dira1   long   %00000000_10000000_00000001_00000000
    mask23      long   %00001111_11111111_11111111_11111111
    temp        res    1       'for looking at pin
    mem         res    1       'for first CNT reading
    mem1        res    1       'for second CNT reading
    I have a question on this program.
    When you run it and look at the console you will see that the wave length varies between 160000 and 160024 cycles. Why is this not constant?
    Harprit
    edited 2011-08-12 06:48
    Harprit wrote: »
    dat
                org        0
    prog_red    mov    dira,  set_dira1      '[COLOR="red"]to make sure pin 23 is an input[/COLOR]
                and    temp, mask23  wz      '[COLOR="orange"]look at only pin 23[/COLOR]
    [COLOR="red"]set_dira1   long   %00000000_10000000_00000001_00000000[/COLOR]
    [COLOR="orange"]mask23      long   %00001111_11111111_11111111_11111111 [/COLOR]
    The way you sample the pin introduces a certain amount of overhead. Imagine the pin change just before it's sampled and just afterA and follow the code (delay). Anyway, for this type of task waitpxx is THE way to go.
    A sampling only happens once every 12 cycles
    edited 2011-08-12 07:19
    So much for my faith in the repeatability of digital systems!
    That possibly accounts for 12 cycles
    So is there an uncertainty on the wave generation side also?
    Harprit.
    edited 2011-08-12 07:29
    Harprit wrote: »
    You got what you asked for. Note that [thread=126265]there are ways[/thread] to account for the loop overhead but what exactly is wrong with using waitpxx in this situation (which would give you a +/- 1 cycle accuracy)?
    Harprit wrote: »
    For a given delay the waveform is certain/repeatable. That said, it won't necessarily be what you expect as you have a hubop in your loop i.e. there may not be a simple relationship between delay and frequency generated (I haven't checked the exact timing though).
    edited 2011-08-13 09:38
    @kuroneko
    waitpxx. I will add optimization techniques as I go along in the book but for now I want to keep it as BASIC like as I can for beginners.
    Question. If I have a HUBOP in my code, why does that make things indeterminate. Why does the HUBOP not act the same way through each cycle. And, could a synchronizing technique be used to improve duplication. ie make it more exact
    Harprit.
  • TorTor Posts: 2,010
    edited 2011-08-13 10:09
    I'm not sure I agree with considering waitpxx an optimization technique.. to me it's more about the Right Way and the Wrong Way. A polling loop which checks for bits to change is almost always the Wrong Way, and I don't think it's a good direction in which to steer beginning programmers. Habits learned early have a tendency to stick..
    -Tor
    edited 2011-08-13 11:10
    I am going to re post the code for reading a potentiometer with the MCP 3208 chip. This time around, the code has been optimized and all unnecessary items and subroutines have been removed. This code is in intended to run in a separate cog and provide the resistance of the potentiometer to 12 bits in a global variable called POT_RES available to all users.
    We need to be able to read a potentiometer, because essentially there are two kinds of variables. We have control of one kind, as represented by a potentiometer and we do not have direct control of the other kind as might be represented by a temperature or the level in a large tank or any number of other variables that change as time goes on, but we cannot vary them with the turn of a knob.
    As we progress, my plan is to use the potentiometer reading directly as an input into the frequency generating program and see if we cannot write a program that will give us the frequency that we specify with the potentiometer. Essentially, it means that the two variables displayed on the console will be the same. Since the potentiometer reading can go from 0 to 4095 we will have to make allowances for that in our program.
    You can start playing with this since, all the information that we need has already been posted and you may want to develop the skills to put it all together in a useful way without assistance. In the next few days I will work this out myself to and post my results. For now, let us say that our goal is to be able to generate a frequency from 1000 to 2000 cycles per second as the potentiometer varies from zero to 4095. That's the results we get if we read the potentiometer to 12 bits.
    Program to read a pot OPTIMIZED, installs in separate cog.
    Resistance to 12 bits appears in POT_RES global variable
    August 13 2011
    Sandhu
    CON
    VAR
      long POT_RES
      long stack1[25]         'space for oscope
      long stack2[25]         'space for speaker
    OBJ
    PUB null | P_VAL
      cognew(@generate, @P_Val)     'new cog at "generate" and read variable into P_Val
      repeat                        'loop
        POT_RES:=P_VAL              'endless loop to display data
        fds.bin(P_val,12)           'print value to the PST in binary to match LEDs
        fds.tx($d)                  'new line
        fds.dec(P_val)              'print value as decimal
        fds.tx(" ")                 'space
    DAT           org       0                  'sets the starting point in Cog
    generate      mov       dira,    set_dira  'sets direction of the prop pins
                  or        outa ,   chs_Bit   'Makes Chip select high
                  andn      outa,    chs_Bit   'makes chip select low
                  andn      outa ,   clk_bit   'ANDN it with the Clock Bi to make low
                  or        outa ,   din_Bit   'Makes the Din high
                  call      #Tog_clk           'clk hi-lo to read data
                  call      #Tog_Clk           'clock line hi then low to read in the data
                  andn      outa ,   din_Bit   'makes Din low  000 for line 0
                  mov       dat_red,  #0       'Clear register we will read data into
                  mov       count,    #12      'Counter for number of bits we will read
    read_bit      mov       temp,    ina       'read in what is in all the input lines
                  andn      temp,    mask26 wz 'mask off all except Dout line. Set Z flag
                  shl       Dat_red,  #1       'shift register left 1 bit ready for next bit
            if_nz add       Dat_red,  #1       'if value is still pos add 1 to data register
                  call      #Tog_Clk           'toggle clock to get next bit ready in Dout
                  sub       count,    #1 wz    'decrement the "bits read" counter. Set Z flag
            if_nz jmp       #read_bit          'go up and do it again if counter not yet 0
                  mov       mem,      par      'get address of mem
                  wrlong    dat_red,  mem       'write it in PAR to share it as P.Val
                  jmp       #generate           'go back to do it all again
    Tog_Clk       or        outa,     clk_bit   'make clock bit high
                  andn      outa,     clk_bit   'make clock bit low
    Tog_Clk_ret             ret                 'return from this subroutine
    Set_dira      long      %00001011_00000000_00000000_00000000   'Set dira register
    Chs_Bit       long      %00000001_00000000_00000000_00000000   'Chip select bit     24
    Din_Bit       long      %00000010_00000000_00000000_00000000   'Data in bit         25
    Dout_Bit      long      %00000100_00000000_00000000_00000000   'Data out bit        26
    Clk_Bit       long      %00001000_00000000_00000000_00000000   'Clock bit           27
    mask26        long      %11111011_11111111_11111111_11111111   'Mask for reading the Dout bit only
    temp          res       1       'temporary storage variable, misc
    count         res       1       'temporary storage variable, read bit counter
    Dat_Red       res       1       'temporary storage variable, data being read
    mem           res       1       'memory
    Harprit
    edited 2011-08-13 11:20
    @ Tor
    That is a really tough call. We need an acceptable book for beginners. ALL beginners think PASM is an impossible monster. It is NOT, even though I was very hesitant to learn even the basics, even though many encouraged me to follow the SPIN book up with a PASM book. Please keep in mind that this is not a textbook. It is and introduction for hobbyists. How the reader uses it not up to the writer.
    As to bad habits. Yes of course, but I am not going to be able to fix bad habits. Those interested enough will develop, read more, become good at it or whatever. Even maybe write a much better book. My job is to get the started. To suggest to them that they can learn this language.
    HSS
    edited 2011-08-13 11:40
    New problem?
    I can read a value generated in a PASM cog and use in in SPIN. Done
    I can't seem to find how to take a value in SPIN and put it into a PASM Cog variable.
    HSS
    edited 2011-08-13 11:45
    You've got to pass the address of the variable to the COG.
    Typically, this is done with par, and offsets to par.
    Put the variable in a DAT section, pass that address to the PASM COG with @variable in the COGNEW.
    In the PASM COG:
    rdlong variable, PAR
    Of course, you also need a defined place in the PASM COG to put it. There are various naming schemes for this. One really easy one is to define the address at the higher level as a label in the DAT section thus:
    DAT
    MyVar long 0
    And in the PASM COG
    _MyVar res 1
    Or some similar thing.
    Multiple values are best done with a loop, where they are fetched one by one, adding to par each time, and adding to the base address in the COG each time, variables kept in sequence. (*which I get caught not doing, unless I really need the code space)
    edited 2011-08-13 11:50
    cogs have their COG-RAM absolutely exclusivly. The only way I know (maybe kuroneko knows more ;-) ) is to read a HUB-RAM-long into COG-RAM using the PASM-command RDLONG.
    This means the PASM-Cog has to poll for it using RDLONG. Automatic pushing does not work.
    The only way of pushing I can think of is using IO-PINS to "push" a byte towards PASM-code.
    The special purpose registers INB and OUTB could be used.
    keep the questions coming
    best regards
    Stefan
    edited 2011-08-13 12:02
    There is no way I could have got this far without the help of ALL the great helpers on this forum
    Thanks guys
    @Holly Minkowski. This book was requested by you among others. How come no comments so far?
    HSS
    edited 2011-08-13 12:06
    Question/comment
    One thing that occurred to me was as I puzzled this was that I could write to a long in high memory in the hub and then read the same address in a PASM cog
    Does that make sense? Can one do things like that?
    HSS
