Propeller Keeps rebooting — Parallax Forums
primisprimis Posts: 4
edited 2011-08-01 12:11 in Propeller 1
Hi, I'm new to the propeller. I set it up on a breadboard, and it worked well for about 10 minutes. I hooked it up to a TV and tested the ntsc output, that worked well. Then it went downhill...
I unplugged the 9v batery I was using as a supply while I moved it to a different tv. When I plugged it back in, the signal didn't register, just a white line flickered about once a second. I thought maybe it was the TV, so I moved it back to the original one, no good.
Then I tried a different demo, the serial terminal, that outputted about 4 letters to terminal, then reset, repeatedly.
Any ideas on how to fix this? or is it a dead chip?
  • LeonLeon Posts: 7,620
    edited 2011-07-31 15:48
    Try a proper power supply.
    edited 2011-07-31 15:51
    primis,
    Welcome to the forum!
    I assume this problem occurs only when the USB port is disconnected from your PC; am I right? If so, this is a known issue. See these threads for more info:
    edited 2011-07-31 15:58
    It could be you just need a new 9 volt battery.
  • primisprimis Posts: 4
    edited 2011-07-31 16:06
    Leon, it is a proper power supply, I built a two tier (5v and 3.3v regulators) with capacitors and everything, I just don't have a barrel jack that fits in a breadboard.
    and Phil, I'm actually not using a prop plug, I'm using a serial line with DTS hooked up to the reset line, much cheaper if you ask me.
    Thank you all for responding so quickly, I thought I'd have to wait at least a week to hear back!
    And Electric, you were right, I never thought it could be the battery XD
    edited 2011-07-31 16:09
    primis wrote: »
    primis,
    welcome to the forum, and welcome to reality. If it makes you feel any better, I spent 3 hours late Friday night freaking out about a project.... until I realized the power to the chip wasn't on.
    edited 2011-07-31 16:25
    primis wrote: »
    I meant that you should use a proper supply instead of a 9V battery. They don't last very long.
    edited 2011-07-31 16:26
    I agree you don't need a prop plug, but is that line connected directly to the prop, or via a resistor/capacitor high pass filter, or with a transistor? Could you post a schematic?
    Also, have you checked the volts on the 9V battery while it is running?
    edited 2011-07-31 20:45
    I got the schematic for the DTS programmer from a project called pocketerm. You need a .01 uF capacitor, two 10k resistors, and a NPN transitor. You can find the schematics here: http://www.brielcomputers.com/files/PTschematic.pdf all the stuff you need to know can be found in the upper-left.
    You'll also need a TTL serial level converter to change the +12/-12 VDC coming from your computer down to +5/0 VDC. The one used here is a MAX232 dual serial converter, you can buy one from almost anywhere, so I'm not going to endorse a specific link. (Lower left in schematic)
    edited 2011-07-31 21:24
    My circuits are derived from the pocketerm as well, and it seems a pretty reliable circuit. So (like Leon) I'd be suspecting the power supply next. Is the reset repeatable, and can you measure the battery volts?
    edited 2011-07-31 23:12
    Just to be certain, you do not have an FT232 chip on the pcb, do you?
    It seems to have stopped, (bad cap on the power line, whoops!) but thanks for all the help!
    (and no FT232 chip, just a MAX3232 for level conversion on the serial)
