Propeller Keeps rebooting
Hi, I'm new to the propeller. I set it up on a breadboard, and it worked well for about 10 minutes. I hooked it up to a TV and tested the ntsc output, that worked well. Then it went downhill...
I unplugged the 9v batery I was using as a supply while I moved it to a different tv. When I plugged it back in, the signal didn't register, just a white line flickered about once a second. I thought maybe it was the TV, so I moved it back to the original one, no good.
Then I tried a different demo, the serial terminal, that outputted about 4 letters to terminal, then reset, repeatedly.
Any ideas on how to fix this? or is it a dead chip?
Welcome to the forum!
I assume this problem occurs only when the USB port is disconnected from your PC; am I right? If so, this is a known issue. See these threads for more info:
http://forums.parallax.com/showthread.php?131950
and Phil, I'm actually not using a prop plug, I'm using a serial line with DTS hooked up to the reset line, much cheaper if you ask me.
Thank you all for responding so quickly, I thought I'd have to wait at least a week to hear back!
And Electric, you were right, I never thought it could be the battery XD
primis,
welcome to the forum, and welcome to reality. If it makes you feel any better, I spent 3 hours late Friday night freaking out about a project.... until I realized the power to the chip wasn't on.
I meant that you should use a proper supply instead of a 9V battery. They don't last very long.
I agree you don't need a prop plug, but is that line connected directly to the prop, or via a resistor/capacitor high pass filter, or with a transistor? Could you post a schematic?
Also, have you checked the volts on the 9V battery while it is running?
You'll also need a TTL serial level converter to change the +12/-12 VDC coming from your computer down to +5/0 VDC. The one used here is a MAX232 dual serial converter, you can buy one from almost anywhere, so I'm not going to endorse a specific link. (Lower left in schematic)
(and no FT232 chip, just a MAX3232 for level conversion on the serial)
