What Are You Going To Do With The New WiFi?
All--
What are your plans for Parallax's new WiFi module? I have many, but my first is a Parallax micro-controlled machine using Stamps or the Propeller to monitor sensors, sending input to a desktop or laptop. The PC will execute code which will precisely maneuver the robot about a "known" room. I have an old--circa 1979--idea using beacons (probably laser reflection targets) for navigation that I would like to implement. (I had the idea in 1979. I think it is common-place today.)
I am interested in your plans and ideas about this exciting product!
--Bill
--Bill
I'm clueless about WiFi so I'm just curious how the general set-up works. For example, would you have Propeller+Wifi.Module able to talk directly to another Propeller+Wifi.Module? or would it need a router? or what sort of things will this let us do?
So yes, prop to prop will be possible. Or even prop to your home wifi router, so you can "talk" prop to pc, or even prop to iphone/android!
The router is just a convenient way to join many devices together, and might also include some other convenience features like a dhcp or voip server, and often also provide internet connectivity. But you can also join devices directly. Perhaps consider the usb hub... Without the hub you can plug one usb device to your pc, but add the hub and several usb devices can talk together.
Thanks, Maxwin, that is indeed good news!
Thats what I'm talking about!!!!
The WiFi module will really reduce the amount of interface devices that I have in place now.
