Balancing Bot - Page 4 — Parallax Forums
Balancing Bot
124»
    edited 2011-06-06 10:05
    Check this nimble balancing bot...
    edited 2011-06-06 11:29
    Nifty! Nimble and quite stable, even with a "whole lotta shakin' goin' on". Those motors (and control system) are a lot faster than mine. My servos max out at 60 RPM, which turns out to be the limiter.
    IOW, the limiter couldn't be my beloved BS2!!!
    edited 2011-06-07 08:48
    My little Amy is a real control freak. I have no idea where she gets it from.
    490 x 653 - 53K
  • WhitWhit Posts: 4,191
    edited 2011-06-08 17:44
    @erco, I will PM you... I think I have an idea. :lol:
  • Andrew GrossAndrew Gross Posts: 5
    edited 2012-08-23 11:00
    I have you successfully completed youre balance bot project?
    edited 2012-08-23 13:33
    Yessir Fredericksburg, I've moved on.
    BTW, I grew up in Woodbridge. Give my regards to the August heat & humidity!
