Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Balancing Bot - Page 4 — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Robotics
Balancing Bot
1
2
3
4
Ron Czapala
2,418
2011-06-06 10:05
edited 2011-06-06 10:05
Check this nimble balancing bot...
20,263
2011-06-06 11:29
edited 2011-06-06 11:29
Nifty! Nimble and quite stable, even with a "whole lotta shakin' goin' on". Those motors (and control system) are a lot faster than mine. My servos max out at 60 RPM, which turns out to be the limiter.
IOW, the limiter couldn't be my beloved BS2!!!
20,263
2011-06-07 08:48
edited 2011-06-07 08:48
My little Amy is a real control freak. I have no idea where she gets it from.
490 x 653
53K
52.6K
Whit
4,194
2011-06-08 17:44
edited 2011-06-08 17:44
@erco, I will PM you... I think I have an idea.
Andrew Gross
5
2012-08-23 11:00
edited 2012-08-23 11:00
I have you successfully completed youre balance bot project?
20,263
2012-08-23 13:33
edited 2012-08-23 13:33
Yessir Fredericksburg, I've moved on.
BTW, I grew up in Woodbridge. Give my regards to the August heat & humidity!
1
2
3
4
Sign In
Register
to comment.
