How wide is your Android phone ?
Tubular
I'm making a sleeve to hold a prop circuit that needs to be wider than the Android phones in use.
If you have an Android phone, can you please do a quick measurement of width including buttons, port covers (but not cables) etc. The datasheet data often ignore the buttons, and its important I allow for them
To kick things off, my Nexus S is 64mm including its buttons, 1mm more than the spec'd 63mm
Thanks in advance
tubular
Thanks in advance
tubular
Any Android phone. I'm making something that needs to fit at least 80% of the range, which is now hundreds of phones
If you've got one, please take a quick width measurement including buttons and post results here (phone make, and width in mm or inches)
tubular
